查看: 2429|回復: 1
求一個stc8G1K08a單片機跑馬燈開暗到亮慢到快,關亮到暗快到滅,可切換亮燈模式
ID:1002664 發表于 2022-1-27 23:54 | 顯示全部樓層 |閱讀模式
50黑幣
本帖最后由 菜鳥一個622 于 2022-1-28 15:58 編輯
現大佬教51以有,用在8g1k08a上有更好的嗎
ID:1002664 發表于 2022-1-28 15:57 | 顯示全部樓層
#include <STC8G.h>
typedef unsigned char u8;  //0 to 255
typedef unsigned int u16;  //0 to 65535
typedef unsigned long u32;  //0 to 4294967295
sbit key1 = P5 ^ 4;
u16 TMR_XX_ACC;
u16 TMR_XX_PRE = 500;
u8 PWM = 1;
u8 index = 0;
u8 MODE = 1;
bit Power_On = 1;
unsigned char dat1[4] = {0xfe, 0xfd, 0xfb, 0xf7};
unsigned char dat2[4] = {0xfc, 0xf9, 0xf3, 0xf6};
unsigned char dat3[4] = {0xf1, 0xf2, 0xf4, 0xf8};
void key_Proc()
    static u16 Delay_XD = 0;    //消抖計數
    static u16 Min_T = 25;
    static u16 Max_T = 2500;
    if(!key1)
        if(Delay_XD < 0xFFFF)Delay_XD++;
       //else Delay_XD = 0;       //連按功能
        if(Delay_XD == Max_T)      //長按
//            MODE = ++MODE % 3;
                                        ++MODE;
                                        if(MODE>3)
                                                MODE=1;
    else            //按鍵抬起
        if(Delay_XD > Min_T && Delay_XD < Max_T)      //短按
            Power_On ^= 1;
        Delay_XD = 0;    //Delay_XD清0
void delayus(u8 x)
    while(x--);
    while (1)
        if(PWM > 0) {
            switch (MODE)
            case 0:
                P3 = 0xff;
                break;
            case 1:
                P3 = dat1[index];
                break;
            case 2:
                P3 = dat2[index];
                break;
                                                case 3:
                P3 = dat3[index];
                break;
            delayus(PWM);
        P3 = 0xFF;
        delayus(100 - PWM);
        key_Proc();
        if(++TMR_XX_ACC >= TMR_XX_PRE)
        {   TMR_XX_ACC = 0;
            if(Power_On)
                if(PWM < 99) PWM++;
            } else {
                if(PWM > 0) PWM--;
            index = ++index % 4;
            if(index == 0)
                if(Power_On)
                    if(TMR_XX_PRE > 50) //固定到快
                        TMR_XX_PRE -= 50;
                } else {
                    if(TMR_XX_PRE < 500) //固定到快
                        TMR_XX_PRE += 50;
