- #include <tiny13a.h>
- #include <delay.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define key PINB.1
- //#define LED PORTB.0
- uchar key_code = 0;
- uchar time_counter = 0;
- bit change_flag = 0;
- void key_scan(void)
- if(key)
- if((time_counter > 3) && (time_counter < 100))//短按
- if(change_flag)
- key_code++;
- if(key_code == 5) key_code = 1;
- time_counter = 0;
- else
- time_counter++;
- delay_ms(10);
- if(time_counter == 100)//長(zhǎng)按
- if (key_code != 0) //如果狀態(tài)不處于關(guān)機(jī)狀態(tài),則執(zhí)行關(guān)機(jī)
- key_code = 0;
- change_flag = 0;
- else
- key_code = 1; //如果已經(jīng)在關(guān)機(jī)狀態(tài)則執(zhí)行開機(jī)
- change_flag = 1;
- if(time_counter > 100)
- time_counter = 101;
- void main(void)
- // Input/Output Ports initialization
- // Port B initialization
- // Function: Bit5=In Bit4=In Bit3=In Bit2=In Bit1=In Bit0=Out
- DDRB=(0<<DDB5) | (0<<DDB4) | (0<<DDB3) | (0<<DDB2) | (0<<DDB1) | (1<<DDB0);
- // State: Bit5=T Bit4=T Bit3=T Bit2=T Bit1=P Bit0=0
- PORTB=(0<<PORTB5) | (0<<PORTB4) | (0<<PORTB3) | (0<<PORTB2) | (1<<PORTB1) | (1<<PORTB0);
- TCCR0A=0x03;
- TCCR0B=0x01;
- while (1)
- key_scan();
- switch (key_code)
- case 0x00: //初始關(guān)機(jī)狀態(tài)
- TCCR0A=0x03;
- PORTB.0 = 1;
- break;
- case 0x01:
- TCCR0A=0x83;
- OCR0A = 0x19; //10%亮度
- break;
- case 0x02:
- OCR0A = 0x40; //25%亮度
- break;
- case 0x03:
- OCR0A = 0x80; //50%亮度
- break;
- case 0x04:
- OCR0A = 0xc0; //75%亮度
- break;
- default:
- break;
評(píng)分
查看全部評(píng)分
