查看: 2021|回復: 12
求大神看一下C語言程序到底哪里缺少分號了!
ID:999123 發表于 2022-1-15 13:01 | 顯示全部樓層 |閱讀模式
一個LCD顯示程序,編譯提示;第四行缺少分號,查了好幾遍,確實不缺少分號,請大神看看到底哪里少了分號。
                 #include"reg52.h"
                           #define uchar ansigned char
                           #define uint snsigned int
uchar  code table[]="LIAO JIA YUE";
  uchar code table1[]="LIAO TIAN QI";
                sbit lcde=P2^7;
                sbit lcdrw=P2^5;
                sbit lcdrs=P2^6;
  uchar num;
void delay(uint z)
        uint x, y;
        for(x=z;x>0;x--)
            for(y=110;y>0;y--);
  void write_ com(uchar com)
      lcdrs=0;
          P0=com;
           delay(5);
           lcden=1;
           delay(5);
           lcden=0;
  void write_ date(uchar date)
            lcdrs=1;
          P0=date;
          delay(5);
          lcden=1;
          delay(5);
          lcden=0;
  void init()
           lcden=0;
         write_ com(0x38);
         write_ com(0x0c);
         write_ com(0x06);
         write_ com(0x01);
           init();
         write_ com(0x80);
         for(num=0;num<12;num++)
            write_ date(table[num]);
              delay(5);
                   write com(0x80+0x40);
                   write_ date(table1[num]);
                                   delay(5);
                           while(!);
compiling aa.c...
AA.C(4): error C129: missing ';' before 'char'
aa.c - 1 Error(s), 0 Warning(s).
提示;
ID:53621 發表于 2022-1-15 14:39 | 顯示全部樓層
2 3行的 ansigned  snsigned
unsigned  ?
ID:53621 發表于 2022-1-15 14:40 | 顯示全部樓層
ansigned snsigned 改成  unsigned
ID:861234 發表于 2022-1-15 15:38 | 顯示全部樓層
數組是用花括號的,莫非你的編譯器特殊點
ID:999123 發表于 2022-1-15 16:18 | 顯示全部樓層
謝謝大家,我太粗心了。
ID:716656 發表于 2022-1-15 16:57 | 顯示全部樓層
小牢頭 發表于 2022-1-15 15:38
數組是用花括號的,莫非你的編譯器特殊點
這個是字符串數組
ID:517951 發表于 2022-1-15 21:26 | 顯示全部樓層
ansigned char 拼寫錯誤 要改為 unsigned char
ID:979299 發表于 2022-1-15 22:37 | 顯示全部樓層
錯好機個地方
#include"reg52.h"
sbit lcde=P2^7;
sbit lcdrw=P2^5;
sbit lcdrs=P2^6;
uchar num;
void delay(uint z)
    uint x, y;
    for(x=z;x>0;x--)
    for(y=110;y>0;y--);
void write_com(uchar com)
    lcde=0;
        lcdrs=0;
        lcdrw=0;
    P0=com;
    delay(5);
    lcde=1;
    delay(5);
    lcde=0;
void write_date(uchar date)
    lcde=0;
    lcdrs=1;
        lcdrw=0;
    P0=date;
    delay(5);
    lcde=1;
    delay(5);
    lcde=0;
void init()
     delay(15);
        //lcde=0;
    write_com(0x38);
         delay(5);
         write_com(0x38);
          delay(5);
    write_com(0x0c);
        write_com(0x38);
        write_com(0x38);
    write_com(0x08);
    write_com(0x01);
        write_com(0x06);
        write_com(0x0C);
        init();
    write_com(0x80);
                write_date(table[num]);
        delay(5);
    write_com(0x80+0x40);
     write_date(table1[num]);
    delay(5);
    while(1);
ID:917293 發表于 2022-1-16 22:50 來自觸屏版 | 顯示全部樓層
unsigned char拼寫錯誤
ID:192883 發表于 2022-1-17 09:53 | 顯示全部樓層
ID:407019 發表于 2022-1-17 14:38 | 顯示全部樓層
錯了  unsigned char 和unsigned int
ID:908826 發表于 2022-1-17 18:26 | 顯示全部樓層
宏定義那一塊拼錯了
ID:453974 發表于 2022-1-17 21:20 | 顯示全部樓層
#include"reg52.h"
sbit lcde=P2^7;
sbit lcdrw=P2^5;
sbit lcdrs=P2^6;
uchar num;
void delay(uint z)
    uint x, y;
    for(x=z;x>0;x--)
    for(y=110;y>0;y--);
    lcde=0;
        lcdrs=0;
        lcdrw=0;
    P0=com;
    delay(5);
    lcde=1;
    delay(5);
    lcde=0;
    lcde=0;
    lcdrs=1;
        lcdrw=0;
    P0=date;
    delay(5);
    lcde=1;
    delay(5);
    lcde=0;
void init()
     delay(15);
        //lcde=0;
    write_com(0x38);
         delay(5);
         write_com(0x38);
          delay(5);
    write_com(0x0c);
        write_com(0x38);
        write_com(0x38);
    write_com(0x08);
    write_com(0x01);
        write_com(0x06);
        write_com(0x0C);
        init();
    write_com(0x80);
        delay(5);
    delay(5);
    while(1);
