遇到一個長按的問題,單片機一通電就執行第一個顯示,然后通過長按進行兩個模式切換,求解一下
#define key_S 20
#define key_L key_S*50
uchar fen;
uint count;
bit a=0;
sbit key3 = P1^3;
sbit led0 = P1^0;
sbit led1 = P1^7;
sbit led2 = P1^6;
void delay(unsigned int t)//延時時間 = t*9+16 us
while(t--);
void Scan_key()
if(!key3)
count++;
if(count==key_L)
a=~a;
if(a)
Write_1621(29,0x20,4); //怎么使這代碼一開機就顯示,然后通過長按切換這兩個程序
Write_1621(29,0x40,4);
if(count>key_L)
count=key_L+1;
if(count>key_S && count<key_L)
if(++fen==4)
fen=0;
count=0;
switch(fen)
case 0:Write_1621(8,0x01,4);led0=1;led1=1;led2=1;break;
case 1:Write_1621(8,0x80,4);led0=0;led1=1;led2=1;break;
case 2:Write_1621(8,0x40,4);led0=1;led1=0;led2=1;break;
case 3:Write_1621(8,0x20,4);led0=1;led1=1;led2=0;break;
default:break;
delay(110);
void main( )
Init_1621(); //初始化
Port1Cfg(1,0); //端口推挽輸出
Port1Cfg(1,3);
Port1Cfg(1,6);
Port1Cfg(1,7);
Scan_key();
