查看: 3596|回復: 20
求助哪位大師幫我看看單片機程序,怎樣保存按鍵值,搞了幾天沒頭緒
ID:879080 發表于 2022-1-10 17:40 | 顯示全部樓層 |閱讀模式
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. typedef unsigned char BYTE;
  4. typedef unsigned int WORD;
  5. //unsigned char table[8]={0xaa,0x55,0xaa,0x55,0xaa,0x55,0xaa,0x55};
  6. /*Declare SFR associated with the IAP */
  7. sfr  IAP_DATA      =   0xC2;       //Flash data register
  8. sfr  IAP_ADDRH     =   0xC3;             //Flash address HIGH
  9. sfr  IAP_ADDRL     =   0xC4;               //Flash address LOW
  10. sfr  IAP_CMD       =   0xC5;                //Flash command register
  11. sfr  IAP_TRIG       =   0xC6;                 //Flash command trigger
  12. sfr  IAP_CONTR     =   0xC7;             //Flash control register
  13. /*Define ISP/IAP/EEPROM command*/
  14. #define   CMD_IDLE      0                         //Stand-By
  15. #define   CMD_READ      1                      //Byte-Read
  16. #define   CMD_PROGRAM   2                 //Byte-Program
  17. #define   CMD_ERASE      3                      //Sector-Erase
  18. /*Define ISP/IAP/EEPROM operation const for IAP_CONTR*/
  19. //#define   ENABLE_IAP   0x80              //if SYSCLK<30MHz
  20. //#define   ENABLE_IAP   0x81              //if SYSCLK<24MHz
  21. //#define   ENABLE_IAP    0x82              //if SYSCLK<20MHz
  22.         #define   ENABLE_IAP   0x83              //if SYSCLK<12MHz
  23. //#define   ENABLE_IAP   0x84              //if SYSCLK<6MHz
  24. //#define   ENABLE_IAP   0x85              //if SYSCLK<3MHz
  25. //#define   ENABLE_IAP   0x86              //if SYSCLK<2MHz
  26. //#define   ENABLE_IAP   0x87              //if SYSCLK<1MHz
  27. //Start address for STC12C5A60S2 series EEPROM
  28. #define    IAP_ADDRESS   0x2000
  29. void Delay(BYTE n);
  30. void IapIdle();
  31. BYTE IapReadByte(WORD addr);
  32. void IapProgramByte(WORD addr, BYTE dat);
  33. void IapEraseSector(WORD addr);
  34. WORD i;
  35. void Delay(BYTE n)
  36. {
  37.       WORD x;
  38.       while (n--)
  39.       {
  40.             x = 0;
  41.             while (++x);
  42.       }
  43. }
  44. unsigned char RunMode;
  45. //**********************************System Fuction*************************************************
  46. void Delay1ms(unsigned int count)
  47. {
  48.         unsigned int i,j;
  49.         for(i=0;i<count;i++)
  50.         for(j=0;j<120;j++);
  51. }
  52. unsigned char GetKey(void)
  53. {
  54.         unsigned char KeyTemp,CheckValue,Key = 0x00;
  55.         CheckValue = P3&0x32;
  56.         if(CheckValue==0x32)
  57.                 return 0x00;
  58.         Delay1ms(10);
  59.         KeyTemp = P3&0x32;
  60.         if(KeyTemp==CheckValue)
  61.                 return 0x00;
  62.         if(!(CheckValue&0x02))
  63.                 Key|=0x01;
  64.         if(!(CheckValue&0x10))
  65.                 Key|=0x02;
  66.         if(!(CheckValue&0x20))
  67.                 Key|=0x04;
  68.         return Key;
  69. }
  70. unsigned int TimerCount,SystemSpeed,SystemSpeedIndex;
  71. void InitialTimer2(void)
  72. {
  73.                 TMOD=0X01;
  74.                 TH0=(65536-5000)/256;
  75.                 TL0=(65536-5000)%256;
  76.                 ET0=1;
  77.                 TR0=1;
  78.         EA=1;
  79. }
  80. unsigned int code SpeedCode[]={        5,   8,  10,  14,  17,  20,  30,
  81.                                   40,  50,  60,  70,  80,  90, 100, 120, 140, 160,
  82.                               180, 200, 300, 400, 500, 600, 700, 800, 900,1000};//27
  83. void SetSpeed(unsigned char Speed)
  84. {
  85.
  86.         SystemSpeed =SpeedCode[Speed];
  87.
  88. }
  89. void LEDShow(unsigned int LEDStatus)
  90. {
  91.         P1 = ~(LEDStatus&0xff);
  92. }
  93. void InitialCPU(void)
  94. {
  95.         RunMode = 0x00;
  96.         TimerCount = 0;
  97.         SystemSpeedIndex =10;
  98.
  99.         P3 = 0xff;
  100.         Delay1ms(500);
  101.         P1 = 0xFF;
  102.         P3 = 0xFF;
  103.         SetSpeed(SystemSpeedIndex);
  104. }
  105. //Mode 0
  106. unsigned int LEDIndex = 0;
  107. bit LEDDirection = 1,LEDFlag = 1;
  108. void Mode_0(void)
  109. {
  110.         LEDShow(0x01<<LEDIndex);
  111.         LEDIndex = (LEDIndex+1)%8;
  112. }
  113. //Mode 1
  114. void Mode_1(void)
  115. {
  116.         LEDShow(0x80>>LEDIndex);
  117.         LEDIndex = (LEDIndex+1)%8;
  118. }
  119. //Mode 2
  120. void Mode_2(void)
  121. {
  122.         if(LEDDirection)
  123.                 LEDShow(0x01<<LEDIndex);
  124.         else
  125.                 LEDShow(0x80>>LEDIndex);
  126.         if(LEDIndex==7)
  127.                 LEDDirection = !LEDDirection;
  128.    LEDIndex = (LEDIndex+1)%8;
  129. }
  130. //Mode 3
  131. void Mode_3(void)
  132. {
  133.         if(LEDDirection)
  134.                 LEDShow(~(0xff<<LEDIndex));
  135.         /*else
  136.                 LEDShow(~(0x80>>LEDIndex));*/
  137.         if(LEDIndex==8)
  138.                 LEDDirection = !LEDDirection;
  139.    LEDIndex = (LEDIndex+1)%9;
  140. }
  141. void TimerEventRun(void)
  142. {
  143.         if(RunMode==0x00)
  144.         {
  145.                 Mode_0();
  146.         }
  147.         else if(RunMode ==0x01)
  148.         {
  149.                 Mode_1();
  150.         }
  151.         else if(RunMode ==0x02)
  152.         {
  153.                 Mode_2();
  154.         }
  155.         else if(RunMode ==0x03)
  156.         {
  157.                 Mode_3();
  158.         }
  159. }
  160. void Timer2(void) interrupt 1 using 1
  161. {
  162.         TF0 = 0;                         //中斷標志清除( Timer2 必須軟件清標志!)
  163.                 TH0=(65536-2500)/256;
  164.                 TL0=(65536-2500)%256;
  165.         if(++TimerCount>=SystemSpeed)
  166.         {
  167.                 TimerCount = 0;
  168.                 TimerEventRun();
  169.            }
  170.
  171. }
  172. unsigned char MusicIndex = 0;
  173. void KeyDispose(unsigned char Key)
  174. {
  175.
  176.
  177.
  178.                 // WORD i;
  179.
  180.
  181.         if(Key&0x01)
  182.
  183.         {
  184.
  185.                 LEDDirection = 1;
  186.                 LEDIndex = 0;
  187.                 //LEDFlag = 1;
  188.                 RunMode = (RunMode+1)%4;
  189.
  190.
  191.         }
  192.
  193.         if(Key&0x02)
  194.
  195.         {
  196.
  197.                 if(SystemSpeedIndex>0)
  198.                 {
  199.                         --SystemSpeedIndex;
  200.                         SetSpeed(SystemSpeedIndex);
  201.
  202.                                          }
  203.
  204. }
  205.         if(Key&0x04)
  206.         {
  207.                 if(SystemSpeedIndex<26)
  208.                 {
  209.                         ++SystemSpeedIndex;
  210.                         SetSpeed(SystemSpeedIndex);
  211.
  212.                                 }
  213.         }
  214.
  215.
  216.
  217. }
  218. //***********************************************************************************
  219. main()
  220. {
  221.         unsigned char Key;
  222.         InitialCPU();
  223.        InitialTimer2();
  224.         while(1)
  225.         {
  226.                 Key = GetKey();
  227.
  228.                 if(Key!=0x00)
  229.                 {
  230.
  231.                         KeyDispose(Key);
  232.
  233. }
  234. }
  235. }
  236. void IapIdle()//關閉ISP,IAP功能
  237. {
  238.       IAP_CONTR = 0;       //Close IAP function
  239.       IAP_CMD = 0;              //Clear command to standby
  240.       IAP_TRIG = 0;                       //Clear trigger register
  241.       IAP_ADDRH = 0x80;                  //Data ptr point to non-EEPROM area
  242.       IAP_ADDRL = 0;                      //Clear IAP address to prevent misuse
  243. }
  244. /*----------------------------Read one byte from ISP/IAP/EEPROM area
  245. Input: addr (ISP/IAP/EEPROM address)
  246. Output:Flash data
  247. ----------------------------*/
  248. BYTE IapReadByte(WORD addr)//讀字節
  249. {
  250.       BYTE dat;                           //Data buffer
  251.       IAP_CONTR = ENABLE_IAP;   //Open IAP function, and set wait time
  252.       IAP_CMD = CMD_READ;         //Set ISP/IAP/EEPROM READ command
  253.       IAP_ADDRL = addr;                  //Set ISP/IAP/EEPROM address low
  254.       IAP_ADDRH = addr >> 8;        //Set ISP/IAP/EEPROM address high
  255.       IAP_TRIG = 0x46;                  //Send trigger command1 (0x5a)
  256.       IAP_TRIG = 0xb9;                    //Send trigger command2 (0xa5)
  257.       _nop_();                            //MCU will hold here until ISP/IAP/EEPROM
  258.           //operation complete
  259.       dat = IAP_DATA;              //Read ISP/IAP/EEPROM data
  260.       IapIdle();                          //Close ISP/IAP/EEPROM function
  261.       return dat;                          //Return Flash data
  262. }
  263. /*----------------------------Program one byte to ISP/IAP/EEPROM area
  264. Input: addr (ISP/IAP/EEPROM address)
  265.        dat (ISP/IAP/EEPROM data)
  266. Output:-----------------------------*/
  267. void IapProgramByte(WORD addr, BYTE dat)//寫字節
  268. {
  269.   IAP_CONTR = ENABLE_IAP;          //Open IAP function, and set wait time
  270.       IAP_CMD = CMD_PROGRAM;     //Set ISP/IAP/EEPROM PROGRAM command
  271.       IAP_ADDRL = addr;                  //Set ISP/IAP/EEPROM address low
  272.       IAP_ADDRH = addr >> 8;             //Set ISP/IAP/EEPROM address high
  273.       IAP_DATA = dat;                    //Write ISP/IAP/EEPROM data
  274.       IAP_TRIG = 0x46;                    //Send trigger command1 (0x5a)
  275.       IAP_TRIG = 0xb9;                    //Send trigger command2 (0xa5)
  276.       _nop_();                            //MCU will hold here until ISP/IAP/EEPROM
  277.           //operation complete
  278.       IapIdle();
  279. }
  280. /*----------------------------Erase one sector area
  281. Input: addr (ISP/IAP/EEPROM address)
  282. Output:-----------------------------*/
  283. void IapEraseSector(WORD addr)//擦除扇區
  284. {
  285.       IAP_CONTR = ENABLE_IAP;   //Open IAP function, and set wait time
  286.       IAP_CMD = CMD_ERASE;       //Set ISP/IAP/EEPROM ERASE command
  287.       IAP_ADDRL = addr;                //Set ISP/IAP/EEPROM address low
  288.       IAP_ADDRH = addr >> 8;          //Set ISP/IAP/EEPROM address high
  289.       IAP_TRIG = 0x46;                    //Send trigger command1 (0x5a)
  290.       IAP_TRIG = 0xb9;                    //Send trigger command2 (0xa5)
  291.       _nop_();                            //MCU will hold here until ISP/IAP/EEPROM
  292.           //operation complete
  293.       IapIdle();
  294. }
ID:526543 發表于 2022-1-10 18:12 | 顯示全部樓層
我可能語文不是太好  啥叫咋保存按鍵值?
ID:161164 發表于 2022-1-10 18:18 | 顯示全部樓層
110行改:RunMode = IapReadByte(IAP_ADDRESS);
212行加:IapEraseSector(IAP_ADDRESS);
213行加:IapProgramByte(IAP_ADDRESS, RunMode);
ID:879080 發表于 2022-1-10 19:40 | 顯示全部樓層
lkc8210 發表于 2022-1-10 18:18
先謝謝,我試一下看
ID:879080 發表于 2022-1-10 19:43 | 顯示全部樓層
123456ZXC1 發表于 2022-1-10 18:12
我可能語文不是太好  啥叫咋保存按鍵值?
可能我說法不太準確,這是個調速流水燈程序,我想保存每次調好燈速度與模式,困擾了好幾天,無從下手了
ID:879080 發表于 2022-1-10 19:49 | 顯示全部樓層
希望能掉電保存每次調好的模式與速度,求大師們指點。非常感謝您的參與。
ID:213173 發表于 2022-1-10 20:53 | 顯示全部樓層
  30. void IapIdle();
  34. /*
  35. WORD i;
  36. void Delay(BYTE n)
  37. {
  38.         WORD x;
  39.         while (n--)
  40.         {
  41.                 x = 0;
  42.                 while (++x);
  43.         }
  44. }*/
  45. unsigned char RunMode;
  46. //**********************************System Fuction*************************************************
  47. void Delay1ms(unsigned int count)
  48. {
  49.         unsigned int i,j;
  50.         for(i=0;i<count;i++)
  51.                 for(j=0;j<120;j++);
  52. }
  53. unsigned char GetKey(void)
  54. {
  55.         unsigned char KeyTemp,CheckValue,Key = 0x00;
  56.         CheckValue = P3&0x32;
  57.         if(CheckValue==0x32)
  58.                 return 0x00;
  59.         Delay1ms(10);
  60.         KeyTemp = P3&0x32;
  61.         if(KeyTemp==CheckValue)
  62.                 return 0x00;
  63.
  64.         if(!(CheckValue&0x02))
  65.                 Key|=0x01;
  66.         if(!(CheckValue&0x10))
  67.                 Key|=0x02;
  68.         if(!(CheckValue&0x20))
  69.                 Key|=0x04;
  70.         return Key;
  71. }
  72. unsigned int TimerCount,SystemSpeed,SystemSpeedIndex;
  73. void InitialTimer2(void)
  74. {
  75.         TMOD=0X01;
  76.         TH0=(65536-5000)/256;
  77.         TL0=(65536-5000)%256;
  78.         ET0=1;
  79.         TR0=1;
  80.         EA=1;
  81. }
  82. unsigned int code SpeedCode[]={5,   8,  10,  14,  17,  20,  30,
  83.                                   40,  50,  60,  70,  80,  90, 100, 120, 140, 160,
  84.                               180, 200, 300, 400, 500, 600, 700, 800, 900,1000};//27
  85. void SetSpeed(unsigned char Speed)
  86. {
  87.          SystemSpeed =SpeedCode[Speed];
  88. }
  90. {
  92. }
  94. {
  95.         RunMode = 0x00;
  96.         TimerCount = 0;
  98.         P3 = 0xff;
  99.         Delay1ms(500);
  100.         P1 = 0xFF;
  101.         P3 = 0xFF;
  102.         SetSpeed(SystemSpeedIndex);
  103. }
  104. //Mode 0
  105. unsigned int LEDIndex = 0;
  106. bit LEDDirection = 1,LEDFlag = 1;
  107. void Mode_0(void)
  108. {
  109.         LEDShow(0x01<<LEDIndex);
  110.         LEDIndex = (LEDIndex+1)%8;
  111. }
  112. //Mode 1
  113. void Mode_1(void)
  114. {
  115.         LEDShow(0x80>>LEDIndex);
  116.         LEDIndex = (LEDIndex+1)%8;
  117. }
  118. //Mode 2
  119. void Mode_2(void)
  120. {
  121.         if(LEDDirection)
  122.                 LEDShow(0x01<<LEDIndex);
  123.         else
  124.                 LEDShow(0x80>>LEDIndex);
  125.         if(LEDIndex==7)
  126.                 LEDDirection = !LEDDirection;
  127.         LEDIndex = (LEDIndex+1)%8;
  128. }
  129. //Mode 3
  130. void Mode_3(void)
  131. {
  132.         if(LEDDirection)
  133.                 LEDShow(~(0xff<<LEDIndex));
  134.         /*else
  135.         LEDShow(~(0x80>>LEDIndex));*/
  136.         if(LEDIndex==8)
  137.                 LEDDirection = !LEDDirection;
  138.         LEDIndex = (LEDIndex+1)%9;
  139. }
  140. void TimerEventRun(void)
  141. {
  142.         if(RunMode==0x00)
  143.         {
  144.                 Mode_0();
  145.         }
  146.         else if(RunMode ==0x01)
  147.         {
  148.                 Mode_1();
  149.         }
  150.         else if(RunMode ==0x02)
  151.         {
  152.                 Mode_2();
  153.         }
  154.         else if(RunMode ==0x03)
  155.         {
  156.                 Mode_3();
  157.         }
  158. }
  159. void Timer2(void) interrupt 1 using 1
  160. {
  161.         TF0 = 0;                         //中斷標志清除( Timer2 必須軟件清標志!)
  162.         TH0=(65536-2500)/256;
  163.         TL0=(65536-2500)%256;
  164.         if(++TimerCount>=SystemSpeed)
  165.         {
  166.                 TimerCount = 0;
  167.                 TimerEventRun();
  168.         }
  169. }
  170. unsigned char MusicIndex = 0;
  171. void KeyDispose(unsigned char Key)
  172. {
  173. // WORD i;
  174.         if(Key&0x01)
  175.         {
  176.                 LEDDirection = 1;
  177.                 LEDIndex = 0;
  178.                 //LEDFlag = 1;
  179.                 RunMode = (RunMode+1)%4;
  180.         }
  181.         if(Key&0x02)
  182.         {
  183.                 if(SystemSpeedIndex>0)
  184.                 {
  185.                         --SystemSpeedIndex;
  186.                         SetSpeed(SystemSpeedIndex);
  187.                 }
  188.         }
  189.         if(Key&0x04)
  190.         {
  191.                 if(SystemSpeedIndex<26)
  192.                 {
  193.                         ++SystemSpeedIndex;
  194.                         SetSpeed(SystemSpeedIndex);
  195.                 }
  196.         }
  197. }
  198. //***********************************************************************************
  199. void main()
  200. {
  201.         unsigned char Key,Key1;
  202.         InitialCPU();
  203.         InitialTimer2();
  204.         Key1=IapReadByte(IAP_ADDRESS);
  205.         while(1)
  206.         {
  207.                 Key = GetKey();
  208.                 if(Key!=0x00 && Key!=Key1)
  209.                 {
  210.                         Key1=Key;
  211.                         IapEraseSector(IAP_ADDRESS);
  212.                         IapProgramByte(IAP_ADDRESS, Key1);
  213.                 }
  214.                 if(Key!=0x00)
  215.                 {
  216.                         KeyDispose(Key);
  217.                 }
  218.         }
  219. }
  220. void IapIdle()//關閉ISP,IAP功能
  221. {
  222.       IAP_CONTR = 0;       //Close IAP function
  223.       IAP_CMD = 0;              //Clear command to standby
  224.       IAP_TRIG = 0;                       //Clear trigger register
  225.       IAP_ADDRH = 0x80;                  //Data ptr point to non-EEPROM area
  226.       IAP_ADDRL = 0;                      //Clear IAP address to prevent misuse
  227. }
  228. /*----------------------------Read one byte from ISP/IAP/EEPROM area
  229. Input: addr (ISP/IAP/EEPROM address)
  230. Output:Flash data
  231. ----------------------------*/
  232. BYTE IapReadByte(WORD addr)//讀字節
  233. {
  234.       BYTE dat;                           //Data buffer
  235.       IAP_CONTR = ENABLE_IAP;   //Open IAP function, and set wait time
  236.       IAP_CMD = CMD_READ;         //Set ISP/IAP/EEPROM READ command
  237.       IAP_ADDRL = addr;                  //Set ISP/IAP/EEPROM address low
  238.       IAP_ADDRH = addr >> 8;        //Set ISP/IAP/EEPROM address high
  239.       IAP_TRIG = 0x46;                  //Send trigger command1 (0x5a)
  240.       IAP_TRIG = 0xb9;                    //Send trigger command2 (0xa5)
  241.       _nop_();                            //MCU will hold here until ISP/IAP/EEPROM
  242.           //operation complete
  243.       dat = IAP_DATA;              //Read ISP/IAP/EEPROM data
  244.       IapIdle();                          //Close ISP/IAP/EEPROM function
  245.       return dat;                          //Return Flash data
  246. }
  247. /*----------------------------Program one byte to ISP/IAP/EEPROM area
  248. Input: addr (ISP/IAP/EEPROM address)
  249.        dat (ISP/IAP/EEPROM data)
  250. Output:-----------------------------*/
  251. void IapProgramByte(WORD addr, BYTE dat)//寫字節
  252. {
  253.   IAP_CONTR = ENABLE_IAP;          //Open IAP function, and set wait time
  254.       IAP_CMD = CMD_PROGRAM;     //Set ISP/IAP/EEPROM PROGRAM command
  255.       IAP_ADDRL = addr;                  //Set ISP/IAP/EEPROM address low
  256.       IAP_ADDRH = addr >> 8;             //Set ISP/IAP/EEPROM address high
  257.       IAP_DATA = dat;                    //Write ISP/IAP/EEPROM data
  258.       IAP_TRIG = 0x46;                    //Send trigger command1 (0x5a)
  259.       IAP_TRIG = 0xb9;                    //Send trigger command2 (0xa5)
  260.       _nop_();                            //MCU will hold here until ISP/IAP/EEPROM
  261.           //operation complete
  262.       IapIdle();
  263. }
  264. /*----------------------------Erase one sector area
  265. Input: addr (ISP/IAP/EEPROM address)
  267. void IapEraseSector(WORD addr)//擦除扇區
  268. {
  270.       IAP_CMD = CMD_ERASE;       //Set ISP/IAP/EEPROM ERASE command
  273.       IAP_TRIG = 0x46;                    //Send trigger command1 (0x5a)
  274.       IAP_TRIG = 0xb9;                    //Send trigger command2 (0xa5)
  275.       _nop_();                            //MCU will hold here until ISP/IAP/EEPROM
  276.           //operation complete
  277.       IapIdle();
  278. }
ID:977804 發表于 2022-1-10 23:13 來自觸屏版 | 顯示全部樓層
看你的訴求不難,
ID:977804 發表于 2022-1-10 23:14 來自觸屏版 | 顯示全部樓層
簡單點,分3步。一,先做出按鍵能控制流水燈的速度,二,用內部eeprom讀寫,三,綜合利用,讀寫第一步的按鍵值
ID:624769 發表于 2022-1-11 00:13 | 顯示全部樓層
單片機型號?
0x46 是 89系列    但是寄存器是  ISP_TRIG
0x5A 是 1T系列指令,寄存器 是  IAP_TRIG  所以你注釋和內容不同,到底是什么型號的單片機?
ID:879080 發表于 2022-1-11 09:30 | 顯示全部樓層
188610329 發表于 2022-1-11 00:13
      IAP_TRIG = 0xb9;       ...
單片機是stc12c2052AD
ID:879080 發表于 2022-1-11 09:38 | 顯示全部樓層
感謝您的指導,這樣改還是不行
ID:879080 發表于 2022-1-11 09:40 | 顯示全部樓層
感謝!但是這樣還是不行
ID:1001210 發表于 2022-1-11 09:52 | 顯示全部樓層
1 搞清楚芯片型號
2 查找使用手冊
3 參考例程
4 修改程序,測試
ID:977804 發表于 2022-1-11 14:10 來自觸屏版 | 顯示全部樓層
我這個也是stc12c2052,邏輯是:按鍵值加一,擦除2000h區,寫入2000h區。每次上電讀取2000h的值附給顯示的值 你搜一下我發的帖:關鍵字  stc12c2052的eeprom
ID:624769 發表于 2022-1-11 16:01 | 顯示全部樓層
本帖最后由 188610329 于 2022-1-11 17:27 編輯
STC12C2052AD 的 IAP啟動指令是
ISP_TRIG = 0x46;
ISP_TRIG = 0xB9;
而不是你代碼中的: IAP_TRIG你應該確認一下 寄存器地址
ID:624769 發表于 2022-1-11 16:09 | 顯示全部樓層
多的不說了, 如果如你所說: STC12C2052AD 的話:
用的是ISP 指令, ISP_TRIG = 0x46; ISP_TRIG = 0xB9;
但是,ISP 寄存器,是不同于 IAP寄存器的,
看下圖修改你的  sfr 定義
ID:136485 發表于 2022-1-11 16:19 | 顯示全部樓層
STC的芯片先擦除,接著寫入,最后你要在什么時候讀出就行
value=0x01;
   _nop_();
   _nop_();
   IapProgramByte(0x0010, value);
  這是擦除和寫入,我的讀出是放在上電的時候
ID:879080 發表于 2022-1-11 16:34 | 顯示全部樓層
3花木城 發表于 2022-1-11 14:10
我這個也是stc12c2052,邏輯是:按鍵值加一,擦除2000h區,寫入2000h區。每次上電讀取2000h的值附給顯示的 ...
好的,謝謝
ID:899981 發表于 2022-1-11 16:54 | 顯示全部樓層
建議樓主先分解問題,就是把程序簡單化,例如一個按鍵,保存這個按下的反應值,例如按一下加一,否則這么長的程序哪有時間看?
ID:879080 發表于 2022-1-11 18:19 | 顯示全部樓層
188610329 發表于 2022-1-11 16:09
用的是ISP 指令, ISP_TRIG = 0x46; ISP_TRIG = 0xB9 ...
謝謝!我修改再試
