查看: 1865|回復: 2
52單片機用12864液晶制作時鐘,請大家幫忙看看,感謝error C141: syntax error near ...
ID:986164 發表于 2022-1-9 16:08 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
用keil uvision4編譯錯誤
Build target '時鐘'compiling main.c.....\BSP\24C02.H(13): error C141: syntax error near 'date', expected ')'
..\BSP\24C02.H(14): error C129: missing ';' before 'read_byte'
compiling pbdata.c.....\BSP\24C02.H(13): error C141: syntax error near 'date', expected ')'..\BSP\24C02.H(14): error C129: missing ';' before 'read_byte'
compiling 24c02.c.....\BSP\24C02.H(13): error C141: syntax error near 'date', expected ')'..\BSP\24C02.H(14): error C129: missing ';' before 'read_byte'
compiling key.c.....\BSP\24C02.H(13): error C141: syntax error near 'date', expected ')'..\BSP\24C02.H(14): error C129: missing ';' before 'read_byte'
compiling xianshi.c.....\BSP\24C02.H(13): error C141: syntax error near 'date', expected ')'..\BSP\24C02.H(14): error C129: missing ';' before 'read_byte'Target not created
頭文件
#ifndef __24C02_H_
#define __24C02_H_
bit write=0;        //寫24C02的標志
sbit sda =P2^0;
sbit scl =P2^1;
void delay0();
void start();                                        //開始信號
void stop();                                        //停止
void respons();                                        //應答
void init_24c02();                                //I^2C初始化函數
void write_byte(uchar date);        //寫一個字節函數
uchar read_byte();                        //讀一個字節函數
void write_add(uchar address,uchar date);        //指定地址寫一個字節
void read_add(uchar address);                                //指定地址讀一個字節
#endif
函數
#include "pbdata.h"
void delay0()
void start()                //開始信號
        sda=1;
        delay0();
        scl=1;
        delay0();
        sda=0;
        delay0();
void stop()                        //停止
        sda=0;
        delay0();
        scl=1;
        delay0();
        sda=1;
        delay0();
void respons()                //應答
        uchar i;
        scl=1;
        delay0();
        while((sda==1)&&(i<250))
                i++;
        scl=0;
        delay0();
void init_24c02()        //I^2C初始化函數
        sda=1;
        delay0();
        scl=1;
        delay0();
void write_byte(uchar date)                //寫一個字節函數
        uchar i,temp;
        temp=date;
        for(i=0;i<8;i++)
                temp=temp<<1;
                scl=0;
                delay0();
                sda=CY;
                delay0();
                scl=1;
                delay0();
        scl=0;
        delay0();
        sda=1;
        delay0();
uchar read_byte()                //讀一個字節函數
        uchar i,k;
        scl=0;
        delay0();
        sda=1;
        delay0();
        for(i=0;i<8;i++)
                scl=1;
                delay0();
                k=(k<<1)|sda;
                scl=0;
                delay0();
        return k;
void write_add(uchar address,uchar date)        //指定地址寫一個字節
        start();
        write_byte(0xa0);
        respons();
        write_byte(address);
        respons();
        write_byte(date);
        respons();
        stop();
void read_add(uchar address)        //指定地址讀一個字節
        uchar date;
        start();
        write_byte(0xa0);
        respons();
        respons();
        start();
        write_byte(0xa1);
        respons();
        date=read_byte();
        stop();
        return date;
ID:68189 發表于 2022-1-10 14:10 | 只看該作者
頭文件中的 uchar 沒有定義,而報錯.在前面定義一下:#define uchar unsigned char
ID:986164 發表于 2022-1-10 15:02 | 只看該作者
好的,知道了,感謝
