查看: 2226|回復(fù): 0
stm32f4標準庫開發(fā)—模擬iic
ID:235207 發(fā)表于 2022-1-8 00:24 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
stm32f4標準庫開發(fā)——模擬iic主要概念:
IIC總線:I2C總線是一種簡單、雙向二線制同步串行總線。它只需要兩根線即可在連接于總線上的器件之間傳送信息。
IIC總線定義:時鐘線:sck數(shù)據(jù)線:sda
軟件模擬:通過軟件控制普通GPIO 引腳高低點評切換,來模擬總線時序,從而達到與總線協(xié)議一樣的效果。
缺點:與使用硬件IIC 相比,會占用更多的 CPU 時間。
實驗?zāi)康模?/strong>
本實現(xiàn)通過軟件模擬IIC 時序,編寫 IIC 發(fā)送接收函數(shù)。
硬件電路:
本實驗的蜂鳴器為有源蜂鳴器
PB8-->  IIC_SCL
PB9-->  IIC_SDA
主要庫函數(shù)調(diào)用:
#define sda_in() {GPIOB->MODER&=~(3<<(9*2));GPIOB->MODER|=0<<9*2;} #define sda_out() {GPIOB->MODER&=~(3<<(9*2));GPIOB->MODER|=1<<9*2;} #define iic_sda_out(x) PBout(9)=x #define iic_scl_out(x) PBout(8)=x #define iix_read_sda() PBin(9) 代碼: //iic.c #include "iic.h" #include "base.h" #include "delay.h" //*********************************************************************** //移
植修改部分
#define sda_in() {GPIOB->MODER&=~(3<<(9*2));GPIOB->MODER|=0<<9*2;} #define sda_out() {GPIOB->MODER&=~(3<<(9*2));GPIOB->MODER|=1<<9*2;} #define iic_sda_out(x) PBout(9)=x #define iic_scl_out(x) PBout(8)=x #define iix_read_sda() PBin(9) static void iic_gpio_init(void) { GPIO_InitTypeDef GPIO_InitStructure; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_Init(GPIOB, &GPIO_InitStructure); } static void iic_gpio_deinit(void) { GPIO_InitTypeDef GPIO_InitStructure; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN; GPIO_InitStructure.GPIO_OType = GPIO_OType_OD; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIOB, &GPIO_InitStructure); }
//*********************************************************************** void iic_init(void) { iic_gpio_init(); iic_scl_out(1); iic_sda_out(1); } void iic_deinit(void) { iic_gpio_deinit(); iic_scl_out(1); iic_sda_out(1); } void iic_start(void) { sda_out(); iic_sda_out(1); iic_scl_out(1); delay_us(4); iic_sda_out(0); delay_us(4); iic_scl_out(0); } void iic_stop(void) { sda_out(); iic_scl_out(0); iic_sda_out(0); delay_us(4); iic_scl_out(1); iic_sda_out(1); delay_us(4); } uint8_t iic_wait_ack(void) { uint8_t ucerrtime = 0; sda_in(); iic_sda_out(1); delay_us(1); iic_scl_out(1); delay_us(1); while(iix_read_sda()) { ucerrtime++; if(ucerrtime > 250) { iic_stop(); return 1; } } iic_scl_out(0); return 0; } void iic_ack(void) { iic_scl_out(0); sda_out(); iic_sda_out(0); delay_us(2); iic_scl_out(1); delay_us(2); iic_scl_out(0); } void iic_nack(void) { iic_scl_out(0); sda_out(); iic_sda_out(1); delay_us(2); iic_scl_out(1); delay_us(2); iic_scl_out(0); } void iic_send_byte(uint8_t txd) { uint8_t t; sda_out(); iic_scl_out(0); for(t = 0; t < 8; t++) { iic_sda_out((txd & 0x80) >> 7); txd <<= 1; delay_us(2); iic_scl_out(1); delay_us(2); iic_scl_out(0); delay_us(2); } } uint8_t iic_read_byte(unsigned char ack) { unsigned char i, receive = 0; sda_in(); for(i = 0; i < 8; i++ ) { iic_scl_out(0); delay_us(2); iic_scl_out(1); receive <<= 1; if(iix_read_sda()) receive++; delay_us(1); } if (!ack) iic_nack(); else iic_ack(); return receive; }
//iic.h #ifndef _IIC_H #define _IIC_H #include "stdint.h" void iic_init(void); void iic_deinit(void); void iic_start(void); void iic_stop(void); void iic_send_byte(uint8_t txd); uint8_t iic_read_byte(unsigned char ack); uint8_t iic_wait_ack(void); void iic_ack(void); void iic_nack(void); void iic_write_one_byte(uint8_t daddr, uint8_t addr, uint8_t data); uint8_t iic_read_one_byte(uint8_t daddr, uint8_t addr); #endif
編譯運行:result
如下,編譯無報錯,無警告。
總結(jié):
理論上gpio操作加上精確的延時,能模擬出任何總線的時序
iic.c將移植部分單獨摘取出來,方便未來的移植開發(fā)
關(guān)注公號InsertingAll,獲取嵌入式學習資源,學習更多嵌入式知識
