查看: 2409|回復: 7
如何改下單片機代碼,讓這張圖片(文字)能夠從12864屏幕右邊向左邊移動,謝謝大佬
回帖獎勵 200 黑幣 回復本帖可獲得 20 黑幣獎勵! 每人限 2 次
ID:992696 發表于 2022-1-7 14:36 | 顯示全部樓層 |閱讀模式
#include <reg51.h>
#define LCDLCDDisp_Off   0x3e
#define LCDLCDDisp_On    0x3f
#define Page_Add     0xb8
#define LCDCol_Add     0x40
#define Start_Line     0xC0
#define data_ora P0
sbit LCDMcs=P2^4 ;
sbit LCDScs=P2^3 ;
sbit LCDDi=P2^2 ;
sbit LCDRW=P2^1 ;
sbit LCDEnable=P2^0 ;
unsigned char code Bmp0[]=
      0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x40,0x42,0xCC,0x00,0x00,0x00,0xFE,0x92,
      0x92,0xFE,0x92,0x92,0xFF,0x02,0x00,0x00,
      0x24,0x24,0xA4,0xFE,0xA3,0x22,0x20,0x7E,
      0x42,0x42,0x42,0x42,0x42,0x7F,0x02,0x00,
      0x40,0x40,0x42,0xCC,0x00,0x40,0xA0,0x9F,
      0x81,0x81,0x81,0x9F,0xA0,0x20,0x20,0x00,
      0x40,0x40,0x42,0xCC,0x00,0x40,0x40,0x40,
      0x40,0xFF,0x40,0x40,0x40,0x60,0x40,0x00,
      0x00,0x00,0x3F,0x10,0x4A,0x22,0x12,0x0A,
      0x06,0xFF,0x06,0x0A,0x32,0x62,0x22,0x00,
      0x08,0x06,0x01,0xFF,0x00,0x43,0x41,0x49,
      0x49,0x49,0x7F,0x49,0x4D,0x69,0x41,0x00,
      0x00,0x00,0x00,0x7F,0xA0,0x90,0x40,0x43,
      0x2C,0x10,0x28,0x26,0x41,0xC0,0x40,0x00,
      0x00,0x00,0x00,0x7F,0x20,0x10,0x08,0x00,
      0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,
unsigned char code Bmp1[]=
      0x10,0x88,0xC4,0xA3,0xBC,0xA0,0xBF,0xA0,
      0xBC,0x20,0xD8,0x17,0x90,0x78,0x10,0x00,
      0x10,0x10,0xD0,0xFF,0x90,0x10,0x00,0xFC,
      0x04,0x04,0x04,0xFE,0x04,0x00,0x00,0x00,
      0x00,0x00,0xFE,0x02,0xE2,0xA2,0xB2,0xAE,
      0xA2,0xA2,0xA2,0xA2,0xF3,0x22,0x00,0x00,
      0x44,0x44,0xFC,0x46,0x44,0x00,0xFE,0x92,
      0x00,0x02,0x02,0x02,0xFE,0x02,0x02,0x02,
      0x42,0x72,0x4E,0x42,0xC0,0x00,0x00,0x00,
      0x00,0x00,0xFC,0x04,0x24,0xC4,0x04,0x15,
      0x66,0x84,0x04,0x04,0x84,0x76,0x04,0x00,
      0x00,0x00,0xFE,0x22,0x22,0x22,0x22,0xFE,
      0x22,0x22,0x22,0x22,0xFF,0x02,0x00,0x00,
      0x01,0x00,0xFF,0x40,0x3E,0x02,0x02,0x3E,
      0x90,0x48,0x33,0x0C,0x33,0xC0,0x40,0x00,
      0x04,0x03,0x00,0xFF,0x80,0x41,0x20,0x1F,
      0x00,0x00,0x00,0x3F,0x40,0x40,0x70,0x00,
      0x40,0x30,0x0F,0x40,0x23,0x1A,0x42,0x82,
      0x7E,0x02,0x02,0x0A,0x13,0x60,0x00,0x00,
      0x10,0x30,0x1F,0x08,0x48,0x48,0x44,0x44,
      0x44,0x7F,0x44,0x46,0x44,0x60,0x40,0x00,
      0x40,0x20,0x18,0x07,0x80,0x41,0x22,0x14,
      0x08,0x14,0x22,0x21,0x40,0xC0,0x40,0x00,
      0x40,0x30,0x0F,0x40,0x40,0x40,0x4F,0x40,
      0x40,0x63,0x50,0x4C,0x43,0x60,0x40,0x00,
      0x80,0x60,0x1F,0x02,0x02,0x02,0x02,0x7F,
      0x02,0x02,0x42,0x82,0x7F,0x00,0x00,0x00,
unsigned char code Bmp2[]=
void LCDdelay(unsigned int t)
        unsigned int i,j;
        for(i=0;i<t;i++);
        for(j=0;j<10;j++);
void CheckState()
   unsigned char dat,DATA;
   LCDDi=0;
   LCDRW=1;
   do
      DATA=0x00;
      LCDEnable=1;
          LCDdelay(2);
          dat=DATA;
      LCDEnable=0;
      dat=0x80 & dat;
    while(!(dat==0x00));
void write_com(unsigned char cmdcode)
    CheckState();
        LCDDi=0;
        LCDRW=0;
        P1=cmdcode;
        LCDdelay(2);
        LCDEnable=1;
        LCDdelay(2);
        LCDEnable=0;
void init_lcd()
        LCDdelay(100);
        LCDMcs=1;
        LCDScs=1;
        LCDdelay(100);
        write_com(LCDLCDDisp_Off);
        write_com(Page_Add+0);
        write_com(Start_Line+0);
        write_com(LCDCol_Add+0);
        write_com(LCDLCDDisp_On);
void write_data(unsigned char LCDDispdata)
    CheckState();
        LCDDi=1;
        LCDRW=0;
        P1=LCDDispdata;
        LCDdelay(2);
        LCDEnable=1;
        LCDdelay(2);
        LCDEnable=0;
void Clr_Scr()
        unsigned char j,k;
        LCDMcs=0;
        LCDScs=0;
        for(k=0;k<8;k++)
                write_com(Page_Add+k);
                  for(j=0;j<64;j++)
                      write_com(LCDCol_Add+j);
                        write_data(0x00);
void Bmp_Left_Disp(unsigned char page,unsigned char column, unsigned char code *Bmp)
        unsigned char j=0,i=0;
        for(j=0;j<2;j++)
                write_com(Page_Add+page+j);
                write_com(LCDCol_Add+column);
                for(i=0;i<64;i++)
                        write_data(Bmp[128*j+i]);
void Bmp_Right_Disp(unsigned char page,unsigned char column, unsigned char code *Bmp)
        for(j=0;j<2;j++)
                for(i=64;i<128;i++)
        init_lcd();
        Clr_Scr();
        LCDMcs=0;
        LCDScs=1;
          Bmp_Left_Disp(0,0,Bmp2);
    Bmp_Left_Disp(2,0,Bmp1);
    Bmp_Left_Disp(4,0,Bmp0);
    Bmp_Left_Disp(6,0,Bmp2);
        LCDMcs=1;
        LCDScs=0;
    Bmp_Right_Disp(0,0,Bmp2);
    Bmp_Right_Disp(2,0,Bmp1);
    Bmp_Right_Disp(4,0,Bmp0);
    Bmp_Right_Disp(6,0,Bmp2);
這是目前的效果圖,想讓12864的圖片從左向右移動
ID:526543 發表于 2022-1-8 15:08 | 顯示全部樓層
使用for循環 把地址以此改變就行了
ID:824490 發表于 2022-1-8 16:22 | 顯示全部樓層
這個函數的各個參數,你明白是做什么用的嗎?
unsigned char page是什么?
unsigned char column又是什么?
搞明白了你就會你要的動作了。
參與人數 1黑幣 +20 收起 理由
admin + 20
ID:1000957 發表于 2022-1-9 17:44 | 顯示全部樓層
弄清楚void Bmp_Right_Disp(unsigned char page,unsigned char column, unsigned char code *Bmp)
里各個參數的指代即可
ID:992696 發表于 2022-1-11 15:08 | 顯示全部樓層
差不多得了,不回答具體的就不要回答了,隔著干嘛呢
ID:992696 發表于 2022-1-11 17:17 | 顯示全部樓層
123456ZXC1 發表于 2022-1-8 15:08
使用for循環 把地址以此改變就行了
具體是怎么弄呀,我for循環總是出錯的
ID:1001440 發表于 2022-1-12 10:55 | 顯示全部樓層
dmclyx 發表于 2022-1-11 15:08
void Bmp_Right_Disp(unsigned char page,unsigned char column, unsigned char code *Bmp)函數里
unsigned char page 相當于行
unsigned char column相當于列
你都知道將 page 變成 0,2,4,6 將內容顯示在屏對應的行上,那是不是可以通過改變column將內容顯示在不同的列上,column動態變化起來內容是不是就移動顯示了。
人家不是藏著,是讓你思考起來,授人以魚不如授人以漁。要想在技術的路上走下去,學會自我學習才是最重要的。
ID:1001569 發表于 2022-1-12 19:22 | 顯示全部樓層
通過循環結構里頭按順序1,先調用函數寫一個清屏幕的程序2,每個字符對應的顯示點坐標向前+2個像素3,判斷是否最后一個文字是否滾動出屏幕4,如果3完成則接出第一個字符,否則繼續顯示下載一個字符
