查看: 2473|回復: 0
分享自己做的一個單片機串口助手和測試代碼
分享自己做的一個單片機串口助手和測試代碼 歡迎評論
  1. #include "stm32f10x.h"
  2. void delay(int i)
  3. {
  4.         int x;
  5.         while(i--)
  6.                 for(x = 0; x < 1000; x++);
  7. }
  8. int main()
  9. {
  10.         GPIO_InitTypeDef gpio;
  11.         USART_InitTypeDef usart1;
  12.         NVIC_InitTypeDef nvic;
  13.
  14.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);        //設置中斷分組,只能設置一次
  15.
  16.         //使能串口時鐘
  17.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
  18.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
  19.
  20.         //配置IO口為串口功能
  21.         //PA9--TX PA10--RX
  22.         gpio.GPIO_Pin = GPIO_Pin_9;
  23.         gpio.GPIO_Speed = GPIO_Speed_10MHz;
  24.         gpio.GPIO_Mode = GPIO_Mode_AF_PP;
  25.         GPIO_Init(GPIOA, &gpio);
  26.
  27.         gpio.GPIO_Pin = GPIO_Pin_10;
  28.         gpio.GPIO_Speed = GPIO_Speed_10MHz;
  29.         gpio.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  30.         GPIO_Init(GPIOA, &gpio);
  31.
  32.         //設置串口屬性
  33.         usart1.USART_BaudRate = 115200;
  34.         usart1.USART_WordLength = USART_WordLength_8b;
  35.         usart1.USART_StopBits = USART_StopBits_1;
  36.         usart1.USART_Parity = USART_Parity_No;
  37.         usart1.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  38.         usart1.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  39.         USART_Init(USART1, &usart1);
  40.
  41.         USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  42.
  43.         USART_Cmd(USART1, ENABLE);
  44.
  45.         //要使用串口中斷,那么就需要添加NVIC組
  46.
  47. //        NVIC_EnableIRQ();        //開啟NVIC中斷
  48. //        NVIC_SetPriority();                //設置搶占優先級
  49. //
  50.         nvic.NVIC_IRQChannel = USART1_IRQn;
  51.         nvic.NVIC_IRQChannelPreemptionPriority = 2;
  52.         nvic.NVIC_IRQChannelSubPriority = 2;
  53.         nvic.NVIC_IRQChannelCmd = ENABLE;
  54.         NVIC_Init(&nvic);
  55.
  56.         while(1);
  57. }
  58. void USART1_IRQHandler()
  59. {
  60.         unsigned char ch;
  61.         if(USART_GetITStatus(USART1, USART_IT_RXNE)){
  62.                 //接收數據
  63.                 ch = USART_ReceiveData(USART1);
  64.                 USART_SendData(USART1, ch);
  65.         }
  66.                 //使能RCC中相應的GPIOA的時鐘
  67.         *(int *)0x40021018 |= 1 << 2;
  68.
  69.         //配置相關的引腳 GPIOA5
  70.         //推挽輸出 速度10MHz
  71.         *(int *)0x40010800 &= ~(0xf << 20);
  72.         *(int *)0x40010800 |= 1 << 20;
  73.
  74.         while(1){
  75.                 //開燈
  76.                 *(int *)0x40010810 |= 1 << 5;
  77.                 *(int *)0x40010810 &= ~(1 << 21);
  78.                 delay(1000);
  79.                 //關燈
  80.                 *(int *)0x40010810 &= ~(1 << 5);
  81.                 *(int *)0x40010810 |= 1 << 21;
  82.                 delay(1000);
  83.         }
  84. }
  1. #include "widget.h"
  2. #include "ui_widget.h"
  3. #include <QDebug>
  4. #include <QMessageBox>
  5. Widget::Widget(QWidget *parent) :
  6.     QWidget(parent),
  7.     ui(new Ui::Widget)
  8. {
  9.     ui->setupUi(this);
  10.     ser_info = QSerialPortInfo::availablePorts();
  11.     foreach (const QSerialPortInfo &info, ser_info) {
  12.         ui->comboBox->addItem(info.portName());
  13.         qDebug() << info.portName();
  14.     }
  15. }
  16. Widget::~Widget()
  17. {
  18.     delete ui;
  19. }
  20. void Widget::on_pb_clicked()
  21. {
  22.     //打開串口
  23.     QString name = ui->comboBox->currentText();
  24.     serial.setPortName(name);
  25.     serial.setBaudRate(QSerialPort::Baud115200);
  26.     serial.setDataBits(QSerialPort::Data8);
  27.     serial.setFlowControl(QSerialPort::NoFlowControl);
  28.     serial.setStopBits(QSerialPort::OneStop);
  29.     serial.setParity(QSerialPort::NoParity);
  30.     if(serial.open(QIODevice::ReadWrite) != true){
  31.         QMessageBox::about(NULL, "警告", "打開串口失敗");
  32.         return;
  33.     }
  34.     qDebug() << "serial open success";
  35.     connect(&serial, SIGNAL(readyRead()), this, SLOT(recv_data()));
  36. }
  37. void Widget::recv_data()
  38. {
  39.     ui->lineEdit_2->setText(serial.readAll());
  40. }
  41. void Widget::on_pb_send_clicked()
  42. {
  43.     serial.write(ui->lineEdit->text().toStdString().c_str());
  44. }
源碼下載:
Serial Port.zip (975.1 KB, 下載次數: 9)
參與人數 1黑幣 +30 收起 理由
admin + 30 共享資料的黑幣獎勵!
收藏收藏2 分享淘帖 頂 踩
