查看: 1597|回復: 3
請大家幫我看一下這個程序對不對,單片機初學者
ID:983020 發表于 2021-12-23 10:31 | 顯示全部樓層 |閱讀模式
  1. #include<reg52.h>
  2. #define LEDPort P0
  3. #define DataPort P1
  4. sbit LATCH1=P2^2;
  5. sbit LATCH2=P2^3;
  6. unsigned char code dofly_ShiWei[8]{ 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07 };
  7. unsigned char code dofly_GeWei[10]{ 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  8. unsigned char TempData[8]
  9. unsigned int num=0,cnt=0;
  10. void Delay(unsigned char t);
  11. void Display(unsigned char FirstBit,unsigned char Num);
  12. void Init_Timer0(void);
  13. void mian()
  14. {
  15. TMOD=0X01;
  16. TH0=(65536-50000)/256;
  17. TL0=(65536-50000)%256;
  18. EA=1;
  19. ET0=1;
  20. TR0=1;
  21. Init_Timer0();
  22. Timer0_isr();
  23. LEDPort=0x09;
  24. DataPort = 0x3f;
  25. unsigned char num=70,cnt=0;
  26. while(1)
  27.   {
  28.   cnt=++;
  29.         if(cnt==20)
  30.     {
  31.                 cnt=0;
  32.                 num--;
  33.                 if(LEDPory==0x09&&num<=10)
  34.                   {
  35.                         LEDPort=0x08;
  36.                         Delay(50000);
  37.                         LEDPort=0x09;
  38.                         Delay(5000));
  39.                         }
  40.                 if(LEDPort==0x09&&num<1)
  41.                   {
  42.                         num=5;
  43.                         LEDPort=0x10;
  44.                         }
  45.                 if(LEDPort==0x10&&num<1)
  46.                   {
  47.                         num=50;
  48.                         LEDPort=0x06;
  49.                         }
  50.                 if(LEDPort==0x06&&num<=10)
  51.                   {
  52.                         LEDPort=0x02;
  53.                         Delay(50000);
  54.                         LEDPort=0x06;
  55.                         Delay(50000);
  56.                         }
  57.                 if(LEDPort==0x06&&num<1)
  58.                   {
  59.                         num=70;
  60.                         LEDPort==0x09;
  61.                         }
  62.                         TempData[0]dofly_ShiWei[num/10];
  63.                         TempData[1]dofly_GeWei[num%10];
  64.                         Display(2,2)
  65.                 }
  66.         }
  67. }
  68. void Delay(unsigned int t)
  69. {
  70. unsigned int j,k;
  71. for(j=0;j<t;j++)
  72. for(k=0;j<1821;k++);
  73. }
  74. void Init_Timer0(void)
  75. {
  76. TMOD|=0x01;
  77. TH0=(65536-50000)/256;
  78. TL0=(65536-50000)%256;
  79. EA=1;
  80. ET0=1;
  81. TR0=1;
  82. }
  83. void Timer0_isr(void) interrupt 1 ()
  84. {
  85. TH0=(65536-50000)/256;
  86. TL0=(65536-50000)%256;
  87. Display(0,8);
  88. }
  89. void Display(unsigned char FirstBit,unsigned char Num)
  90. {
  91. static unsigned char i=0;
  92.              DataPort=0;
  93.        LATCH1=1;
  94.        LATCH1=0;
  95.
  96.        DataPort=dofly_WeiMa[i+FirstBit];
  97.        LATCH2=1;
  98.        LATCH2=0;
  99.
  100.        DataPort=TempData[i];
  101.        LATCH1=1;
  102.        LATCH1=0;
  103.
  104.              i++;
  105.        if(i==Num)
  106.                          i=0;
  107. }
ID:863362 發表于 2021-12-23 11:16 | 顯示全部樓層
main,不是mian
ID:450231 發表于 2021-12-23 14:19 | 顯示全部樓層
應該是void main
ID:297903 發表于 2021-12-23 19:57 | 顯示全部樓層
編繹跑一遍,所有問題程序就幫你提示出來了!!
