查看: 1877|回復: 5
怎么樣把直流電動機調速的代碼整合到溫度傳感器的代碼中 求救!
ID:985176 發表于 2021-12-9 16:53 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
任務:代碼整合一份          完成溫度采集并顯示
          完成聲光報警
          按鍵調整溫度上下限
          直流電動機調速
前三個任務都可以
#include "reg52.h"
sbit DQ=P1^4;
unsigned char code tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff,0XBF};
unsigned char dspbuf[]={10,10,10,10,10,10,10,10};
unsigned char dspcom=0;
unsigned int num=0;
unsigned char low_temp=7;
unsigned char high_temp=26;
unsigned char intr;
void delayms(unsigned int x);
bit temper_flag=0;
void Delay_OneWire();
void Write_DS18B20();
bit init_ds18b20();
unsigned char rd_temperature();
sbit S7=P3^0;
sbit S6=P3^1;
sbit S5=P3^2;
sbit S4=P3^3;
void display(void);
void main(void)
        unsigned char temperature;
        TMOD|=0x01;
        TH0=(65536-2000)/256;
        TL0=(65536-2000)%256;
        EA=1;
        ET0=1;
        TR0=1;
                delayms(10);
                if(S7==0)
                        delayms(10);
                        if(S7==0)
                                low_temp+=1;
                                if(low_temp>26)
                                        low_temp=7;
                                dspbuf[0]=low_temp/10;
                                dspbuf[1]=low_temp%10;
                                while(!S7);
                if(S6==0)
                        delayms(10);
                        if(S6==0)
                                low_temp-=1;
                                if(low_temp>15)
                                        low_temp=07;
                        while(!S6);
                                if(S5==0)
                        delayms(10);
                        if(S5==0)
                                high_temp+=1;
                                if(high_temp>26)
                                        high_temp=7;
                                dspbuf[3]=high_temp/10;
                                dspbuf[4]=high_temp%10;
                        while(!S5);
                   if(S4==0)
                        delayms(10);
                        if(S4==0)
                                high_temp-=1;
                                if(high_temp>26)
                                        high_temp=7;
                        while(!S4);
        if(temper_flag)
                temper_flag=0;
                temperature=rd_temperature();
                dspbuf[6]=temperature/10;
                dspbuf[7]=temperature%10;
        if(temperature>=high_temp||temperature<=low_temp)
                P0=0XFF;
                P2=P2&0X1F|0XA0;
                P2&=0X1F;
                P0=0X00;
                P2=P2&0X1F|0X80;
                P2&=0X1F;
                P0=0X00;
                P2=P2&0X1F|0XA0;
                P2&=0X1F;
                P0=0XFF;
                P2=P2&0X1F|0X80;
                P2&=0X1F;
void isr_time_0(void) interrupt 1
        display();
        if(++intr==100)
                intr=0;
                temper_flag=1;
void display(void)
        P0=0XFF;
        P2=P2&0X1F|0XE0;
        P2=P2&0X1F;
        P0=0X01<<dspcom;
        P2=P2&0X1F|0XC0;
        P2=P2&0X1F;
        P0=tab[dspbuf[dspcom]];
        P2=P2&0X1F|0XE0;
        P2=P2&0X1F;
    if(++dspcom==8)
    dspcom=0;
void Delay_OneWire(unsigned int t)
        unsigned char i;
        while(t--)
                for(i=0;i<12;i++);
void Write_DS18B20(unsigned char dat)
        unsigned char i;
        for (i=0;i<8;i++)
                  DQ=0;
                  DQ=dat&0x01;
                  Delay_OneWire(5);
                  DQ=1;
                  dat>>=1;
         Delay_OneWire(5);
unsigned char Read_DS18B20(void)
        unsigned char i;
        unsigned char dat;
        for (i=0;i<8;i++)
                DQ=0;
                dat>>=1;
                DQ=1;
                if(DQ)
                        dat|=0x80;
                Delay_OneWire(5);
        return dat;
bit init_ds18b20(void)
         bit initflag=0;
         DQ = 1;
         Delay_OneWire(12);
         DQ = 0;
         Delay_OneWire(80);
         DQ = 1;
         Delay_OneWire(10);
         initflag=DQ;
         Delay_OneWire(5);
         return initflag;
unsigned char rd_temperature(void)
        unsigned char low,high;
        char temp;
        init_ds18b20();
        Write_DS18B20(0xCC);
        Write_DS18B20(0x44);
        Delay_OneWire(200);
        init_ds18b20();
        Write_DS18B20(0xBE);
        low=Read_DS18B20();
        high=Read_DS18B20();
        temp=high<<4;
        temp|=(low>>4);
        return temp;
        unsigned int i,j;
        for(i=x;i>0;i--)
                for(j=110;j>0;j--);
直流電動機代碼
#include<reg52.h>
sbit S7=P3^0;
unsigned char Key_Num,PWM_ON,ms;
unsigned char code Tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xFF};
void delayms(unsigned int);
main()
        TMOD=0X01;
        TH0=0XFC;
        TL0=0X66;
        EA=1;
        ET0=1;
        TR0=1;
        P0=0X80;
        P2=P2&0X1F|0XC0;
        P2&=0X1F;
        P0=Tab[0];
        P2=P2&0X1F|0Xe0;
        P2&=0X1F;
                if(!S7)
                        delayms(30);
                        if(!S7)
                                if(++Key_Num>=5)
                                        Key_Num=1;
                                switch(Key_Num)
                                        case 1:PWM_ON=3;     //1μμ
                                                 break;
                                        case 2:PWM_ON=5;     //2μμ
                                                 break;
                                        case 3:PWM_ON=7;     //3μμ
                                                 break;
                                        case 4:PWM_ON=9;     //4μμ
                                                 break;
                                P0=Tab[Key_Num];
                                P2=P2&0X1F|0XE0;
                                P2&=0X1F;
                        while(!S7);
void T0_Int() interrupt 1
        TH0=0XFC;
        TL0=0X66;
        if(++ms>=10)
                ms=0;
        if(ms<PWM_ON)
                P0=P0|0X20;
                P0=P0&0X9F;
        P2=P2&0X1F|0XA0;
        P2&=0X1F;
        unsigned int i,j;
        for(i=x;i>0;i--)
           for(j=113;j>0;j--);
不會整合 求救一下
ID:262 發表于 2021-12-9 17:53 | 只看該作者
先看一下黑壇里面解決此問題的相關帖子吧, 舉一反三
MCU程序?多個功能如何組合http://m.raoushi.com/bbs/dpj-205474-1.html
單片機程序合并教程:http://m.raoushi.com/bbs/dpj-157117-1.html
整合2個程序:http://m.raoushi.com/bbs/dpj-192954-1.html
單片機怎么把兩個C程序整合到一起運行?http://m.raoushi.com/bbs/dpj-213562-1.html
ID:319585 發表于 2021-12-9 20:59 來自觸屏版 | 只看該作者
據我所知,一般的電機控制器都不會帶溫度傳感器,都是把溫度傳感器放到顯示控制面板上,然后通過串口發送溫度信息。那個ds18b20讀取數據需要延時,延時的時候電機控制器有可能就卡頓了吧?
ID:382454 發表于 2021-12-10 13:09 來自觸屏版 | 只看該作者
代碼那么多,看了眼花。就不看了,基本邏輯是這樣的,cpu熱行電機電流輸出,隔一鍛時間檢查溫度,或電機pwm速度控制,突然間媽喲高溫著火了,cpu執行關斷所有電流。
ID:985176 發表于 2021-12-10 14:56 | 只看該作者
heicad 發表于 2021-12-9 17:53
MCU程序?多個功能如何組合http://m.raoushi.com/bbs/d ...
時間不夠呀   希望您可以指導指導
ID:741880 發表于 2021-12-12 12:16 | 只看該作者
好久沒有看 這種 沒有任何操作系統的,硬循環了。 也行吧~
