查看: 1836|回復: 1
stm32壓力傳感器
ID:987440 發表于 2021-12-2 23:18 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
轉而采用了ADC1_AIN0(引腳PA0)采集模擬氣壓計MPXA6115A。
目前壓力變化與輸出變化符合氣壓計曲線( Vout = Vs x (0.009 x P - 0.095)
[code]
#include "main.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
#include <stdio.h>
#include <string.h>
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
ADC_HandleTypeDef hadc1;
SPI_HandleTypeDef hspi1;
TIM_HandleTypeDef htim1;
UART_HandleTypeDef huart1;
UART_HandleTypeDef huart2;
/* USER CODE BEGIN PV */
uint8_t SC_RxReg;
uint8_t Ticks;
uint8_t K1_Interval;
#define BMP180 0xEE
#define ID180  0xD0
//#define ADDR_24LCxx 0xA0
//#define ADDR_24LCxx_Read 0xA1
uint8_t WriteBuffer[8],ReadBuffer[8];
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_USART1_UART_Init(void);
static void MX_TIM1_Init(void);
static void MX_SPI1_Init(void);
static void MX_ADC1_Init(void);
static void MX_USART2_UART_Init(void);
/* USER CODE BEGIN PFP */
uint16_t Get_AdcValue(uint32_t ch);
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_USART1_UART_Init();
  MX_TIM1_Init();
  MX_SPI1_Init();
  MX_ADC1_Init();
  MX_USART2_UART_Init();
  /* USER CODE BEGIN 2 */
  HAL_GPIO_WritePin(Run_GPIO_Port, Run_Pin, GPIO_PIN_SET);
  K1_Interval=10;
  Ticks=K1_Interval;
        printf("\r\n***Pressure Sensor Testing***\r\n");
        //IIC_Read_Multiple(BMP180,ID180, ReadBuffer,1);
        //printf("0x%02X  ",ReadBuffer);
        HAL_TIM_Base_Start_IT(&htim1);
        HAL_UART_Receive_IT(&huart1, (uint8_t *)&SC_RxReg, 1);
        uint16_t adcvalue;
        float voltage,VREF=3.3,Vrefint=1.2;//VrefInt=1.2V, 1.16~1.26V,可以通過vrefint校準參
ID:262 發表于 2021-12-9 20:20 | 只看該作者
代碼還沒發完?
