查看: 857|回復: 0
求助各位單片機大神,我想讓第二個按鈕的倒放功能變成一秒鐘閃爍一次應該怎么改?
ID:978502 發(fā)表于 2021-11-25 15:58 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
大家?guī)臀铱纯磫h,謝謝各路大神了
#include<reg51.h>
#include<intrins.h>
#define data1 P0
#define data2 P2
sbit s1=P3^6;
sbit s2=P3^7;
bit fangxiang;
uint alt=0,net=0,sl=128;
bit mode;
uchar code tab[]={
0x20,0x08,0x24,0x10,0x22,0x60,0x21,0x80,0x26,0x41,0x39,0x32,0x02,0x04,0x0C,0x18,
0xF0,0x60,0x13,0x80,0x10,0x60,0x10,0x18,0x14,0x04,0x18,0x02,0x00,0x01,0x00,0x00,/*"歡",2*/
0x02,0x00,0x02,0x02,0x42,0x04,0x33,0xF8,0x00,0x04,0x00,0x02,0x3F,0xF2,0x20,0x22,
0x40,0x42,0x00,0x02,0x3F,0xFE,0x20,0x42,0x20,0x22,0x3F,0xC2,0x00,0x02,0x00,0x00,/*"迎",3*/
0x00,0x80,0x01,0x00,0x06,0x00,0x1F,0xFF,0xE0,0x00,0x02,0x08,0x04,0x30,0x18,0xC0,
0xF0,0x02,0x10,0x01,0x13,0xFE,0x10,0x00,0x10,0x80,0x14,0x60,0x18,0x18,0x00,0x00,/*"你",4*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",5*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",6*/
void delay(uint z)           //延時子函數(shù)
   uchar x;
   for(;z>0;z--)
   for(x=110;x>0;x--);
void xianshi()                        //顯示
        uchar aa,i;
        for(i=0;i<16;i++)
                P1=i; //列掃描
                data1=tab[net+aa]; //取出上8行數(shù)據(jù)輸出
                aa++;
                data2=tab[net+aa]; //取出下8行數(shù)據(jù)輸出
                aa++;
                delay(5);        //延時
                data1=0;  //清屏
                data2=0;  //清屏
                P1=0x00;  //消除余輝
                if(aa>30) aa=0;  //字模地址
void main()         //主函數(shù)
   ET1=1;         //使能定時器0
   EA=1;         //開啟總中斷
   TR1=1;        //開始計數(shù)
   while(1)         //無限循環(huán)
           xianshi();  //顯示
           if(s1==0)   //檢測按鍵
              delay(30);  //延時消抖
                  TR1=~TR1;          //按下暫停  ,暫按繼續(xù)
                  while(!s1)xianshi();
                  delay(30);
           if(s2==0)        //檢測按鍵
               delay(30);                        //延時消抖
                   fangxiang=~fangxiang;  //方向取反
                   while(!s2)xianshi();
                   delay(30);
void timer1() interrupt 3
   alt++;
   if(alt==10)                   //到一定的時間加以實現(xiàn)左移
     alt=0;
         if(fangxiang==0)         //如果是正向 正向移動
                 net=net+2;
             if(net>sl)  //字移動數(shù)量
             net=0;
         else                           //否則反向移動
             net=net-2;
                 if(net<2)
                 net=sl;          //字移動數(shù)量
