查看: 1695|回復: 0
單片機按鍵控制點陣顯示數字
ID:974148 發表于 2021-11-23 21:04 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. #include<reg51.h>
  2. #include<intrins.h>
  3. typedef unsigned int u16;
  4. typedef unsigned char u8;
  5. sbit SRCLK=P3^6;
  6. sbit RCLK=P3^5;
  7. sbit SER=P3^4;
  8. #define GPIO_KEY        P1
  9. #define COMMONPORTS  P0
  10. sbit LSA=P2^2;
  11. sbit LSB=P2^3;
  12. sbit LSC=P2^4;
  13. u8 code TAB[8]  = {0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
  14. u8 code CHARCODE[18][8]=
  15. {
  16. {0x00,0x00,0x3e,0x41,0x41,0x41,0x3e,0x00}, //0
  17. {0x00,0x00,0x00,0x00,0x21,0x7f,0x01,0x00}, //1
  18. {0x00,0x00,0x27,0x45,0x45,0x45,0x39,0x00}, //2
  19. {0x00,0x00,0x22,0x49,0x49,0x49,0x36,0x00}, //3
  20. {0x00,0x00,0x0c,0x14,0x24,0x7f,0x04,0x00}, //4
  21. {0x00,0x00,0x72,0x51,0x51,0x51,0x4e,0x00}, //5
  22. {0x00,0x00,0x3e,0x49,0x49,0x49,0x26,0x00}, //6
  23. {0x00,0x00,0x40,0x40,0x40,0x4f,0x70,0x00}, //7
  24. {0x00,0x00,0x36,0x49,0x49,0x49,0x36,0x00}, //8
  25. {0x00,0x00,0x32,0x49,0x49,0x49,0x3e,0x00}, //9
  26. {0x00,0x00,0x7F,0x48,0x48,0x30,0x00,0x00}, //P
  27. {0x00,0x00,0x7F,0x48,0x4C,0x73,0x00,0x00}, //R
  28. {0x00,0x00,0x7F,0x49,0x49,0x49,0x00,0x00}, //E
  29. {0x00,0x00,0x3E,0x41,0x41,0x62,0x00,0x00}, //C
  30. {0x00,0x00,0x7F,0x08,0x08,0x7F,0x00,0x00}, //H
  31. {0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00}, //I
  32. {0x00,0x7F,0x10,0x08,0x04,0x7F,0x00,0x00}, //N
  33. {0x7C,0x48,0x48,0xFF,0x48,0x48,0x7C,0x00}  // ?
  34. };
  35. void delay(u16 time)
  36. {
  37.   u16 i,j;
  38.   for(i=0;i<time;i++)
  39.     for(j=0;j<121;j++);
  40. }
  41. void Hc595SendByte(u8 dat)
  42. {
  43.    u8 a;
  44.    SRCLK=0;
  45.    RCLK=0;
  46.    for(a=0;a<8;a++)
  47.    {
  48.      SER=dat>>7;
  49.      dat<<=1;
  50.      SRCLK=1;
  51.       _nop_();
  52.       _nop_();
  53.       SRCLK=0;
  54.    }
  55.       RCLK=1;
  56.       _nop_();
  57.       _nop_();
  58.       RCLK=0;
  59. }
  60. void InterruptTimer0 () interrupt 1
  61. {
  62.         unsigned char i = 0;
  63.         static unsigned char KeyBuf[4]={
  64.                 0xFF,0xFF,0xFF,0xFF
  65.         };
  66.         TH0 = 0xFC;
  67.         TL0 = 0x67;
  68.         KeyBuf [0] = (KeyBuf[0]<<1)|KEY_IN_1;
  69.         KeyBuf [1] = (KeyBuf[1]<<1)|KEY_IN_2;
  70.         KeyBuf [2] = (KeyBuf[2]<<1)|KEY_IN_3;
  71.         KeyBuf [3] = (KeyBuf[3]<<1)|KEY_IN_4;
  72.         for (i=0; i<4; i++)
  73.         {
  74.                 if ((KeyBuf[i]&0x0F) == 0x00)
  75.                         {
  76.                                 KeySta[i] = 0;
  77.                         }
  78.                         else if ((KeyBuf[i]&0x0F) == 0x0F)
  79.                                 {
  80.                                         KeySta[i] = 1;
  81.                                 }
  82.         }
  83. }
  84. void main()
  85. {
  86.         while(1)
  87.   {
  88.     for (i=0; i<4; i++)
  89.     {
  90.                         if (backup [i] != KeySta [i])
  91.                                 {
  92.                                         if(backup [i] != 0)
  93.                                                 {
  94.                                                         if(KeySta[0]==0)
  95.        {
  96.        TR1 = 0;
  97.        ENLED = 0;
  98.        ADDR3 = 1;
  99.        ADDR2 = 0;
  100.        ADDR1 = 0;
  101.        ADDR0 = 0;
  102.        if (KeySta[0]==0)
  103.        {
  104.        P0 = LedChar[cnt];
  105.        cnt++;
  106.        if(cnt >= 10)
  107.        cnt = 0;
  108.        }
  109.        }
  110.                                                 }
  111.                                 }
  112.                 }
  113.         }
  114. }
