制作出來(lái)的實(shí)物圖如下:
直接上代碼
- // 低電平繼電器動(dòng)作,高電平繼電器釋放 小度語(yǔ)音 操作 成功,20211121
- #define BLINKER_WIFI
- #define BLINKER_MIOT_OUTLET
- #define BLINKER_DUEROS_OUTLET
- #define BLINKER_ALIGENIE_OUTLET
- #define BLINKER_PRINT Serial
- #include <WiFiManager.h>
- #include <Blinker.h>
- char auth[] = "--------";
- int relay = 2;
- int key = 0;
- int counter = 0;
- BlinkerButton Button1("btn-abc");
- WiFiManager wifiManager;
- char devname[] = "ESP8266_chazuo";
- void WebConfig() {
- Serial.println("Entered config mode...");
- wifiManager.setConfigPortalTimeout(60);
- wifiManager.autoConnect(devname);
- WiFi.hostname(devname);
- Serial.println("");
- Serial.print("ESP8266 Connected to ");
- Serial.println(WiFi.SSID());
- Serial.print("IP address:\t");
- Serial.println(WiFi.localIP());
- void button1_callback(const String & state)
- BLINKER_LOG("app操作了!: ", state);
- if (digitalRead(relay)==LOW) {
- BLINKER_LOG("滅燈!");
- digitalWrite(relay, HIGH);
- Button1.color("gray");
- Button1.text("插座已關(guān)閉");
- Button1.print("off");
- else if (digitalRead(relay)==HIGH) {
- BLINKER_LOG("亮燈!");
- digitalWrite(relay,LOW);
- Button1.color("red");
- Button1.text("插座已打開(kāi)");
- Button1.print("on");
- void miotPowerState(const String & state)
- BLINKER_LOG("小愛(ài)語(yǔ)音操作!");
- if (state == BLINKER_CMD_ON){
- BlinkerMIOT.powerState("on");
- BlinkerMIOT.print();
- else if (state == BLINKER_CMD_OFF){
- digitalWrite(relay,HIGH);
- BlinkerMIOT.powerState("off");
- void miotQuery(int32_t queryCode)
- BLINKER_LOG("MIOT Query codes: ", queryCode);
- switch (queryCode)
- case BLINKER_CMD_QUERY_ALL_NUMBER :
- BLINKER_LOG("MIOT Query All");
- BlinkerMIOT.powerState(relay ? "on" : "off");
- break;
- case BLINKER_CMD_QUERY_POWERSTATE_NUMBER :
- BLINKER_LOG("MIOT Query Power State");
- break;
- default :
- break;
- void duerPowerState(const String & state)
- BLINKER_LOG("小度語(yǔ)音操作!"); //串口打印
- BlinkerDuerOS.powerState("on"); //????
- BlinkerDuerOS.print();
- BlinkerDuerOS.powerState("off");
- void duerQuery(int32_t queryCode)
- BLINKER_LOG("DuerOS Query codes: ", queryCode);
- BLINKER_LOG("DuerOS Query All");
- BlinkerDuerOS.powerState(relay ? "on" : "off");
- break;
- BLINKER_LOG("DuerOS Query Power State");
- break;
- default :
- break;
- void aligeniePowerState(const String & state)
- BLINKER_LOG("天貓精靈語(yǔ)音操作!");
- BlinkerAliGenie.powerState("on");
- BlinkerAliGenie.print();
- BlinkerAliGenie.powerState("off");
- void aligenieQuery(int32_t queryCode)
- BLINKER_LOG("AliGenie Query codes: ", queryCode);
- BLINKER_LOG("AliGenie Query All");
- BlinkerAliGenie.powerState(relay ? "on" : "off");
- break;
- BLINKER_LOG("AliGenie Query Power State");
- default :
- break;
- void dataRead(const String & data)
- BLINKER_LOG("Blinker readString: ", data);
- Blinker.vibrate();
- uint32_t BlinkerTime = millis();
- Blinker.print("millis", BlinkerTime);
- void heartbeat()
- BLINKER_LOG("狀態(tài)同步!");
- Button1.text("繼電器打開(kāi)");
- else
- Button1.text("繼電器關(guān)閉");
- void sdms()
- if (digitalRead(relay)==HIGH&&digitalRead(key)==LOW)
- Blinker.delay(400);
- if (digitalRead(key)==HIGH)
- BLINKER_LOG("本地開(kāi)關(guān)動(dòng)作!");
- if (digitalRead(relay)==LOW&&digitalRead(key)==LOW)
- void setup()
- { Serial.begin(115200);
- delay(10);
- BLINKER_DEBUG.stream(Serial);
- BLINKER_DEBUG.debugAll();
- pinMode(relay, OUTPUT);
- digitalWrite(relay, LOW);
- pinMode(key,INPUT_PULLUP);
- WebConfig();
- Blinker.begin(auth, WiFi.SSID().c_str(), WiFi.psk().c_str());
- Button1.attach(button1_callback);
- Blinker.attachData(dataRead);
- Blinker.attachHeartbeat(heartbeat);
- BlinkerMIOT.attachPowerState(miotPowerState);
- BlinkerDuerOS.attachPowerState(duerPowerState);
- BlinkerAliGenie.attachPowerState(aligeniePowerState);
- BlinkerMIOT.attachQuery(miotQuery);
- BlinkerDuerOS.attachQuery(duerQuery);
- BlinkerAliGenie.attachQuery(aligenieQuery);
- void loop() {
- Blinker.run();
- sdms();
評(píng)分
查看全部評(píng)分
