查看: 1608|回復(fù): 6
想請(qǐng)教一下51單片機(jī)T1定時(shí)器控制T0定時(shí)器啟動(dòng)的參考例子有沒(méi)有?或者參考方案
ID:858009 發(fā)表于 2021-11-17 15:07 | 只看該作者 回帖獎(jiǎng)勵(lì) |正序?yàn)g覽 |閱讀模式
本帖最后由 qwettyuio 于 2021-11-22 14:25 編輯
想學(xué)習(xí)使用T1定時(shí)器控制T0定時(shí)器
通過(guò)按鍵控制定時(shí)器的,想修改,沒(méi)有按鍵控制的情況下,每次通過(guò)按鍵設(shè)時(shí)間結(jié)束等待5后啟動(dòng)倒計(jì)時(shí),
#include<reg51.h>
uchar min,sec,count,sec1,sec2,min0,min1,min2,keystopc,temp,mun;
sbit keystop=P3^0;
sbit keyh=P3^1;
sbit keym=P3^2;
sbit led1=P1^0;
sbit beep=P2^3;
sbit lcden=P3^4;
sbit lcdrw=P3^6;
sbit lcdrs=P3^5;
uchar code table[]={'0','1','2','3','4','5','6','7','8','9',':'};
void delay(uint z)                //延時(shí)程序
        uint x,y;
        for(x=z;x>0;x--)
         for(y=110;y>0;y--);
void beep_Init()
        beep=0;
        delay(500);
        beep=1;
------LCD1602顯示函數(shù)------
void write_com(uchar com)
        lcdrs=0;
        P0=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_data(uchar date)
        lcdrs=1;
        P0=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void init_1602()                                //初始化1602
        lcden=0;
        lcdrw=0;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        write_com(0x80);
void write_Char(unsigned char x,unsigned char y,unsigned char date)
         if (y == 0)
                write_com(0x80 + x);
                write_com(0xC0 + x);
        write_data(date);
void display(uchar min0,uchar min1,uchar min2,uchar sec1,uchar sec2)         //顯示程序
        write_Char(3,0,table[min0]);
        write_Char(4,0,table[min1]);
        write_Char(5,0,table[min2]);
        write_Char(6,0,table[0x0a]);
        write_Char(7,0,table[sec1]);
        write_Char(8,0,table[sec2]);
------計(jì)時(shí)器/定時(shí)器0-----
void init()                                                //定時(shí)器初始化
        count=0;
        min=0;
        sec=0;
        TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        TR0=0;
        ET0=1;
        EA=1;
void count0() interrupt 1     //工作方式
        TH0=(65536-50000)/256;    //50ms
        count++;
        if(count==20)             //20*50ms=1000ms=1s
                        count=0;
                        if(sec==0)
                                if (min!=0)
                                        sec=59;
                                        min--;
                                        beep_Init();
                                        TR0 =0;
                        else sec--;
------主函數(shù)------
        init();
        init_1602();
                if(keystop==0)                             //檢測(cè)是否停止鍵按下
                        delay(10);
                        if(keystop==0)
                                if(keystopc!=1)   keystopc++;      //按停止鍵的次數(shù)
                                else              keystopc=0;
                                while(keystop==0);                 //松手檢測(cè)
                                delay(5);
                                while(keystop==0);
                        switch(keystopc)
                                case 0:TR0=0;break;                // 按鍵一次就停止計(jì)數(shù)
                                case 1:TR0=1;break;
                                default:break;
                if(keyh==0)                 //實(shí)現(xiàn)分鐘加一
                        delay(100);
                        if(keyh==0)
                                if(min!=110)
                                        min++;
                        while(!keym);                  //松手檢測(cè)
                        delay(5);
                        while(!keym);
                if(keym==0)              //實(shí)現(xiàn)分鐘減一
                        delay(100);
                        if(keym==0)
                                if(min!=0)
                                        min--;
                        while(!keyh);                //松手檢測(cè)
                        delay(5);
                        while(!keyh);
                min0=min/100;
                min1=min%100/10;
                min2=min%10;
                sec1=sec/10;
                sec2=sec%10;
           display(min0,min1,min2,sec1,sec2);  //一直顯示時(shí)鐘
ID:858009 發(fā)表于 2021-11-22 14:22 | 只看該作者
188610329 發(fā)表于 2021-11-19 17:18
T1 控制 T0 不難,
T1 定時(shí) 5分鐘也不難,
難的是,你要搞明白單片機(jī)運(yùn)行的原理,
就是不通過(guò)按鍵控制啟動(dòng),在設(shè)置時(shí)間結(jié)束后,等待5s后啟動(dòng)倒計(jì)時(shí)
ID:858009 發(fā)表于 2021-11-22 09:17 | 只看該作者
本帖最后由 qwettyuio 于 2021-11-22 14:33 編輯
T1 控制 T0 不難,
T1 定時(shí) 5分鐘也不難,
整體設(shè)計(jì)是做一個(gè)定時(shí)器,就只有兩個(gè)按鍵,一個(gè)按鍵按一次加·一分鐘,長(zhǎng)按50ms連續(xù)加,另一個(gè)是減,在不添加其他按鍵情況下,想通過(guò)自動(dòng)啟動(dòng)倒計(jì)時(shí),每次設(shè)置好時(shí)間等待5s左右就啟動(dòng)倒計(jì)時(shí),所以想問(wèn)一下,怎么通過(guò)一個(gè)定時(shí)器控制另一個(gè)定時(shí)器啟動(dòng);
代碼如下,這是添加了一個(gè)啟動(dòng)按鍵的,能否把這個(gè)去掉,
ID:624769 發(fā)表于 2021-11-19 17:18 | 只看該作者
qwettyuio 發(fā)表于 2021-11-19 16:28
按鍵啟動(dòng)定時(shí)器會(huì)用,但是不用按鍵啟動(dòng)定時(shí)器,就不太會(huì),做一個(gè)5分鐘倒計(jì)時(shí),設(shè)置好時(shí)間,等待3s沒(méi)有再 ...
T1 控制 T0 不難,
T1 定時(shí) 5分鐘也不難,
就算我現(xiàn)在把 T1 定時(shí)5分鐘 后 TR0 =1 整個(gè)中斷寫出來(lái)給你, 和本來(lái)在T0里面計(jì)時(shí)也是沒(méi)有差別的,你想時(shí)間到了蜂鳴器響的話,還是要把這個(gè)模塊寫出來(lái),不是加個(gè)T1去定時(shí), 蜂鳴器就能響了。
并且,T1 定時(shí)5分鐘后啟動(dòng) T0, 那么 T1 靠什么啟動(dòng)呢? 這些原理你要搞清楚了,你壓根不會(huì)考慮去用T1 啟動(dòng)T0, 而是 在 T0 里面把活全干了。
ID:858009 發(fā)表于 2021-11-19 16:28 | 只看該作者
yzwzfyz 發(fā)表于 2021-11-18 13:48
讀通定時(shí)器的原理就能達(dá)成你的目的。
按鍵啟動(dòng)定時(shí)器會(huì)用,但是不用按鍵啟動(dòng)定時(shí)器,就不太會(huì),做一個(gè)5分鐘倒計(jì)時(shí),設(shè)置好時(shí)間,等待3s沒(méi)有再設(shè)置時(shí),啟動(dòng)倒計(jì)時(shí),想著用51單片機(jī)T1控制T0,不太會(huì),想請(qǐng)教一下
ID:123289 發(fā)表于 2021-11-18 13:48 | 只看該作者
ID:948088 發(fā)表于 2021-11-17 19:21 來(lái)自觸屏版 | 只看該作者
可以把定時(shí)器0的寄存器的相關(guān)控制代碼寫在定時(shí)器1的中斷函數(shù)里
ID:624769 發(fā)表于 2021-11-17 19:03 來(lái)自觸屏版 | 只看該作者
把控制t0定時(shí)器的代碼寫到t1定時(shí)器里。
推薦
ID:908826 發(fā)表于 2021-11-17 18:44 | 只看該作者
沒(méi)看明白你的意思。
