查看: 1914|回復: 0
利用單片進行0~20的計數程序
ID:981666 發表于 2021-11-16 22:21 | 顯示全部樓層 |閱讀模式
可以實現0~20計數功能顯示
#include<reg51.h>
#define LED_SEGMENT P0
sbit led1 = P2^0;
sbit led0 = P2^1;
#define ON 1
#define OFF 0
unsigned char code display_code[10]={0XC0,0XF9,0XA4,0XB0,0X99,0X92,0X82,0XF8,0X80,0X90};
unsigned char code display_position[4]={0X01,0X02,0X04,0X08};
unsigned char display_buff[4];
unsigned int counter;
void delay_ms(unsigned int ms)
unsigned char k;
while(ms--)
           for(k=0;k<123;k++);
void display_process()
display_buff[0]=counter/10;
display_buff[1]=counter%10;
void LED_display()
    LED_SEGMENT=display_code[display_buff[0]];
    led1 = 1;
    delay_ms(2);
    led1 = 0;
    LED_SEGMENT=display_code[display_buff[1]];
    led0 = 1;
    delay_ms(2);
    led0 = 0;
void int0_counter()interrupt 0 using 1
          counter++;
          if(counter==21)
          counter=0;
          P3=0XFF;
          counter=0;
          EX0=1;
          IT0=1;
          EA=1;
           display_process();
           LED_display();
參與人數 1黑幣 +10 收起 理由
admin + 10 共享資料的黑幣獎勵!
