查看: 1459|回復: 3
單片機intrins.h文件如何修改?可以循環移動4個字節的數據
ID:980872 發表于 2021-11-16 09:50 | 顯示全部樓層 |閱讀模式
intrins.h 這個文件,_crol_ 只能操作unsigned char 的數據,我想循環移動4個字節的數據,請問一下這個intrins.h 文件怎么改呢?還要改別的文件嗎?
INTRINS.H
Intrinsic functions for C51.
Copyright (c) 1988-2010 Keil Elektronik GmbH and ARM Germany GmbH
All rights reserved.
#ifndef __INTRINS_H__
#define __INTRINS_H__
#pragma SAVE
#if defined (__CX2__)
#pragma FUNCTIONS(STATIC)
/* intrinsic functions are reentrant, but need static attribute */
#endif
extern void          _nop_     (void);
extern bit           _testbit_ (bit);
extern unsigned char _cror_    (unsigned char, unsigned char);
extern unsigned int  _iror_    (unsigned int,  unsigned char);
extern unsigned long _lror_    (unsigned long, unsigned char);
extern unsigned char _crol_    (unsigned char, unsigned char);
extern unsigned int  _irol_    (unsigned int,  unsigned char);
extern unsigned long _lrol_    (unsigned long, unsigned char);
extern unsigned char _chkfloat_(float);
extern int           abs       (int);
extern void          _illop_   (void);
#endif
#if !defined (__CX2__)
extern void          _push_    (unsigned char _sfr);
extern void          _pop_     (unsigned char _sfr);
#endif
#pragma RESTORE
#endif
ID:824490 發表于 2021-11-16 11:03 | 顯示全部樓層
不用改, _irol_    (unsigned int,  unsigned char);這個就行了
ID:980872 發表于 2021-11-16 11:28 | 顯示全部樓層
名字不是重點 發表于 2021-11-16 11:03
_irol_    (unsigned int,  unsigned char); 用的是keil C51,版本5,單片機是C8051F330,你看他的參數,我是unsigned int,我單步調試的話,循環移動的是后面16位
ID:980872 發表于 2021-11-16 11:37 | 顯示全部樓層
用這個_lrol_,就可以對long進行操作了,謝謝
