查看: 1515|回復: 0
stm32f103r6+Proteus仿真 AD轉換+捕獲周期程序相關問題
ID:893765 發表于 2021-11-15 21:11 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
仿真顯示錯誤數值且數值不隨著調整而改變
附工程文件&代碼&仿真 麻煩各位大佬了
警告:
../Core/Src/main.c:124:4: warning: implicit declaration of function 'Show_Led' [-Wimplicit-function-declaration]
../Core/Src/main.c:134:12: warning: implicit declaration of function 'KEY_Scan' [-Wimplicit-function-declaration]
../Core/Src/main.c:139:7: warning: assignment to 'uint16_t' {aka 'short unsigned int'} from 'uint16_t (*)(void)' {aka 'short unsigned int (*)(void)'} makes integer from pointer without a cast [-Wint-conversion]
../Core/Src/main.c:160:7: warning: assignment to 'uint16_t' {aka 'short unsigned int'} from 'uint16_t (*)(void)' {aka 'short unsigned int (*)(void)'} makes integer from pointer without a cast [-Wint-conversion]
../Core/Src/bsp.c:107:1: warning: control reaches end of non-void function [-Wreturn-type]
2mode.7z
518.24 KB, 下載次數: 11
