查看: 2793|回復(fù): 3
stc89c52單片機(jī)驅(qū)動(dòng)無刷電調(diào),電機(jī)一直沒反應(yīng)
ID:976316 發(fā)表于 2021-11-14 16:06 | 顯示全部樓層 |閱讀模式
stc89c52驅(qū)動(dòng)無刷電調(diào),電機(jī)一直沒反應(yīng),以前是用32驅(qū)動(dòng)能正常驅(qū)動(dòng),但是最近32燒了,繼續(xù)用51頂一下暫用,但是這段代碼一直無法正常驅(qū)動(dòng)單片機(jī),求大神幫幫忙,下面部分是單片機(jī)程序
#include <REGX52.H
sbit Motor1=P1^0;
sbit Motor2=P1^1;
unsigned char RecieveByte;
unsigned char Counter,CompareL,CompareR;        //計(jì)數(shù)值和比較值,用于輸出PWM
  * @brief  定時(shí)器0初始化,2us@12.000MHz
  * @param  無
  * @retval 無
void Timer0_Init(void)                //2微秒@11.0592MHz
        TMOD &= 0xF0;                //設(shè)置定時(shí)器模式
        TL0 = 0xEA;                //設(shè)置定時(shí)初始值
        TH0 = 0xFF;                //設(shè)置定時(shí)初始值
        TF0 = 0;                //清除TF0標(biāo)志
        TR0 = 1;                //定時(shí)器0開始計(jì)時(shí)
        ET0=1;
        EA=1;
        PT0=0;
void UART_Init(void)                //9600bps@11.0592MHz
        PCON &= 0x7F;                //波特率不倍速
        SCON = 0x50;                //8位數(shù)據(jù),可變波特率
        TMOD &= 0x0F;                //清除定時(shí)器1模式位
        TMOD |= 0x20;                //設(shè)定定時(shí)器1為8位自動(dòng)重裝方式
        TL1 = 0xFD;                //設(shè)定定時(shí)初值
        TH1 = 0xFD;                //設(shè)定定時(shí)器重裝值
        ET1 = 0;                //禁止定時(shí)器1中斷
        TR1 = 1;                //啟動(dòng)定時(shí)器1
        EA=1;
        ES=1;
        PS=1;
void Delay(unsigned int xms)
        unsigned char i, j;
        while(xms--)
                i = 2;
                j = 239;
                do
                        while (--j);
                } while (--i);
void forwardquickly()
        CompareL=50;
        CompareR=50;
void forward()
        unsigned char i=30;
        for(i=0;i<40;i++)
                CompareL=i;
                CompareR=i;
                Delay(50);
void left()
        CompareL=20;
        CompareR=10;
void right()
        CompareL=10;
        CompareR=20;
void stop()
        CompareL=0;
        CompareR=0;
        Timer0_Init();
        UART_Init();
void Timer0_Routine() interrupt 1
        Counter++;
        Counter%=100;        //計(jì)數(shù)值變化范圍限制在0~99
        if(Counter<CompareL)        //計(jì)數(shù)值小于比較值  左邊螺旋槳電機(jī)
                Motor1=1;                //輸出1
        else                                //計(jì)數(shù)值大于比較值
                Motor1=0;                //輸出0
        if(Counter<CompareR) //計(jì)數(shù)值小于比較值   右邊螺旋槳電機(jī)
                Motor2=1; //輸出1
                Motor2=0;  //輸出0
void UART_Routine()  interrupt 4
        if(RI==1)
                RecieveByte=SBUF;//將接受到的數(shù)據(jù)賦值給RecieveByte
                switch(RecieveByte)//進(jìn)行數(shù)據(jù)處理,執(zhí)行相對(duì)應(yīng)的操作
                        case '1':forwardquickly();P2_0=0;break;
                        case '2':forward();P2_1=0;break;
                        case '3':stop();P2_2=0;break;
                        case '4':left();P2_3=0;break;
                        case '5':right();P2_4=0;break;
                RI=0;
ID:420836 發(fā)表于 2021-11-15 01:46 | 顯示全部樓層
檢查所有硬件特定變量是否已正確映射到 51 單片機(jī)。
ID:976316 發(fā)表于 2021-11-15 13:40 | 顯示全部樓層
TTQ001 發(fā)表于 2021-11-15 01:46
硬件映射應(yīng)該沒有問題吧,我用直流減速電機(jī)去測(cè)試這段代碼直流減速電機(jī)可以動(dòng),但是拿這個(gè)用電調(diào)去驅(qū)動(dòng)無刷電機(jī)一點(diǎn)反應(yīng)都沒有
ID:94031 發(fā)表于 2021-11-15 14:46 | 顯示全部樓層
應(yīng)該把電機(jī),電調(diào)情況介紹給大家。
