查看: 3968|回復: 4
STM32串口配置(串口三的配置=初始化+中斷配置+中斷接收函數)
ID:110875 發表于 2021-11-7 17:47 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
繼前貼http://m.raoushi.com/bbs/dpj-213781-1.html,今天發布STM32的串口3配置程序,話不多說。
  1 /*===============================================================================
  2 Copyright:
  3 Version:
  4 Author:
  5 Date: 2017/11/3
  6 Description:
  7     函數功能是將接收固定長度的字符串,并將接收后的字符串通過串口發送出去
  8     通過滴答定時器方式獲取數據
  9 revise Description:
10 ===============================================================================*/
11 #include "stm32f10x_usart.h"
12 #include "stm32f10x.h"
13
14 #define USART3_TIMEOUT_Setting 800  //(ms)
15
16 u8 USART3_RX_BUF[250];
17 u16 USART3_RX_CNT=0;
18 u16 USART3_RX_TIMEOUT=0;       //接收狀態標記
19
20 void Timer1CountInitial(void);
21
22 void USART3_Init(u32 baud)
23 {
24     USART_InitTypeDef USART_InitStructure;
25     NVIC_InitTypeDef NVIC_InitStructure;
26     GPIO_InitTypeDef GPIO_InitStructure;    //聲明一個結構體變量,用來初始化GPIO
27     //使能串口的RCC時鐘
28     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB , ENABLE); //使能UART3所在GPIOB的時鐘
29     RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);
30
31     //串口使用的GPIO口配置
32     // Configure USART3 Rx (PB.11) as input floating
33     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
34     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
35     GPIO_Init(GPIOB, &GPIO_InitStructure);
36
37     // Configure USART3 Tx (PB.10) as alternate function push-pull
38     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
39     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
40     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
41     GPIO_Init(GPIOB, &GPIO_InitStructure);
42
43     //配置串口
44     USART_InitStructure.USART_BaudRate = baud;
45     USART_InitStructure.USART_WordLength = USART_WordLength_8b;
46     USART_InitStructure.USART_StopBits = USART_StopBits_1;
47     USART_InitStructure.USART_Parity = USART_Parity_No;
48     USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
49     USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
50
51
52     // Configure USART3
53     USART_Init(USART3, &USART_InitStructure);//配置串口3
54     // Enable USART3 Receive interrupts 使能串口接收中斷
55     USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);
56     // Enable the USART3
57     USART_Cmd(USART3, ENABLE);//使能串口3
58
59     //串口中斷配置
60     //Configure the NVIC Preemption Priority Bits
61     NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
62
63     // Enable the USART3 Interrupt
64     NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn;
65     NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;//搶占優先級3
66     NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;        //子優先級3
67     NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
68     NVIC_Init(&NVIC_InitStructure);
69
70 }
71
72 void USART3_Sned_Char(u8 temp)
73 {
74     USART_SendData(USART3,(u8)temp);
75     while(USART_GetFlagStatus(USART3,USART_FLAG_TXE)==RESET);
76
77 }
78
79 void USART3_Sned_Char_Buff(u8 buf[],u32 len)
80 {
81     u32 i;
82     for(i=0;i<len;i++)
83     USART3_Sned_Char(buf[ i]);
84
85 }
86
87 void main(void)
88 {
89     Timer1CountInitial();
90     Usart3_Init(9600);//串口1波特率設置為9600
91     while(1)
92     {
93         if(USART3_RX_TIMEOUT==USART3_TIMEOUT_Setting)
94         {
95             USART3_RX_TIMEOUT=0;
96             USART3_Sned_Char_Buff(USART3_RX_BUF,USART3_RX_CNT);//將接收到的數據發送出去
97             USART3_RX_CNT=0;
98         }
99
100     }
101 }
102 void USART3_IRQHandler(void)                    //串口3中斷服務程序
103 {
104     u8 Res;
105     if(USART_GetITStatus(USART3, USART_IT_RXNE) != RESET)
106     {
107         USART3_RX_TIMEOUT=0;
108         USART3_RX_BUF[USART3_RX_CNT++] = USART_ReceiveData(USART3);    //讀取接收到的數據
109     }
110     //溢出-如果發生溢出需要先讀SR,再讀DR寄存器則可清除不斷入中斷的問題
111     if(USART_GetFlagStatus(USART3,USART_FLAG_ORE) == SET)
112     {
113         USART_ReceiveData(USART3);
114         USART_ClearFlag(USART3,USART_FLAG_ORE);
115     }
116     USART_ClearITPendingBit(USART3, USART_IT_RXNE);
117
118 }
119
120 //放到主函數的初始化中初始化
121 void Timer1CountInitial(void)
122 {
123     //定時=36000/72000x2=0.001s=1ms;
124         TIM_TimeBaseInitTypeDef    TIM_TimeBaseStructure;
125         ///////////////////////////////////////////////////////////////
126         RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
127
128         TIM_TimeBaseStructure.TIM_Period = 100-1;//自動重裝值(此時改為10ms)
129         TIM_TimeBaseStructure.TIM_Prescaler = 7200-1;//時鐘預分頻
130         TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//向上計數
131         TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;        //時鐘分頻1
132         TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
133         TIM_TimeBaseInit(TIM1,&TIM_TimeBaseStructure);
134
135         TIM_ClearFlag(TIM1,TIM_FLAG_Update);
136         TIM_ITConfig(TIM1,TIM_IT_Update,ENABLE);
137         TIM_Cmd(TIM1, ENABLE);
138 }
139 void TIM1_UP_IRQHandler(void)
140 {
141     //TIM_TimeBaseStructure.TIM_Period = 100-1;//自動重裝值(此時改為10ms)
142     if (TIM_GetITStatus(TIM1, TIM_IT_Update) != RESET)
143     {
144         if(USART3_RX_TIMEOUT<USART3_TIMEOUT_Setting)
145                 USART3_RX_TIMEOUT++;
146     }
147     TIM_ClearITPendingBit(TIM1,TIM_IT_Update);
148 }
參與人數 1黑幣 +30 收起 理由
admin + 30 共享資料的黑幣獎勵!
收藏收藏2 分享淘帖 頂 踩
ID:630913 發表于 2021-11-8 14:18 | 只看該作者
樓主能發一個同時開啟二個串口,都支持串口發送和中斷接收的程序嗎?
ID:630913 發表于 2021-11-8 14:22 | 只看該作者
可以發一個二個串口同時工作,都能發送和中斷接收的程序嗎,我現在測試的串口程序是二個串口單獨都能正常工作,只要二個口串口都開啟中斷時,就有一個串口工作不正常!
ID:813640 發表于 2021-11-8 20:32 | 只看該作者
pjh2003 發表于 2021-11-8 14:22
可以發一個二個串口同時工作,都能發送和中斷接收的程序嗎,我現在測試的串口程序是二個串口單獨都能正常工 ...
同求  需要同時開啟兩個串口
ID:884711 發表于 2024-5-20 09:19 | 只看該作者
串口中斷函數處理部分
void USART1_IRQHandler(void)
        USART_ClearFlag(USART1,USART_FLAG_TC);
        if(USART_GetITStatus(USART1,USART_IT_RXNE)!=Bit_RESET)
        u8        k=USART_ReceiveData(USART1);
        serial1_sned_char(k+1);
void USART2_IRQHandler(void)
        USART_ClearFlag(USART2,USART_FLAG_TC);
        if(USART_GetITStatus(USART2,USART_IT_RXNE)!=Bit_RESET)
        u8        k=USART_ReceiveData(USART2);
