查看: 1775|回復: 2
學習UART串口通信的例程,單片機好像沒有接受到電腦發送的命令
大致就是根據電腦發送的不同命令執行相關操作,并且每次把接收到的命令原封不動發回給電腦,作為接收到命令的標志,但串口調試助手接收不到發回的命令,單片機也沒執行相關操作,目前我想解決串口調試助手接收不到發回的命令的這一問題,請大佬幫忙看看,程序中有部分函數是關于LCD1602的,他們的原形在另一個.c文件中,由于無關且就沒貼出來
/******UART.c的程序******/
#include "reg52.h"
bit flagFrame = 0;//用于判斷命令是否接收完成的標志
bit flagTxd = 0;//字節發送完成的標志
unsigned char cntRxd = 0;//計數接收到多少字節
unsigned char bufRxd[32];//接收緩沖區
extern void UartAction(unsigned char *buf,unsigned char len);
/**波特率配置函數**/
void ConfigUART(unsigned char baud)
        SCON =  0x50;
        TMOD &= 0x0f;
        TMOD |= 0x20;
        TH1 = 256 - (11059200/12/32)/baud;;
        TL1 = TH1;
        ET1 = 0;
        ES = 1;
        TR1 = 1;
/**UART讀取函數,在判斷完命令接收完成后使用,將讀取到的數據從bufRxd中取出**/
unsigned char UartRead(unsigned char *buf,unsigned char len)
        unsigned char i;
        if(len > cntRxd)
                 len = cntRxd;
        for(i = 0;i < len;i++)
                *buf++ = bufRxd[ i];
        cntRxd = 0;
        return len;
/**命令監測函數,用于監測命令是否接收完成,在中斷中使用**/
void UartRxMonitor(unsigned char ms)
        static unsigned char cntbkp;//數據接收字節備份值,30ms接收字節與備份值不變,即認為命令接收完成
        static unsigned char idletmr;
        if(cntRxd > 0)
                if(cntbkp != cntRxd)
                        cntbkp = cntRxd;
                        idletmr = 0;
                        if(idletmr < 30)
                        idletmr+=ms;
                        if(idletmr >= 30)
                        flagFrame = 1;
                cntbkp = 0;
/**將接收到的原原本本發送回去,作為接收到了的標志**/
void UartWrite(unsigned char *buf,unsigned char len)
        while(len--)
                flagTxd = 0;
                SBUF = *buf++;
                while(!flagTxd);
void UartDriver()
        unsigned char len;
        unsigned char buf[40];
        if(flagFrame)
                flagFrame = 0;
                len = UartRead(buf,sizeof(buf));
                UartAction(buf,len);
/**UART中斷函數**/
void InterruptUART() interrupt 4
        if(RI)
                RI = 0;
                if(cntRxd < sizeof(bufRxd))
                bufRxd[cntRxd++] = SBUF;
        if(TI)
                TI = 0;
                flagTxd = 1;
/******main.c的程序******/
#include "reg52.h"
sbit BUZZ = P2^5;
bit flagBuzzOn = 0;
unsigned char T0RH = 0;
unsigned char T0RL = 0;
void ConfigTimer0(unsigned int ms);
extern void ConfigUART(unsigned char baud);
extern unsigned char UartRead(unsigned char *buf,unsigned char len);
extern void UartRxMonitor(unsigned char ms);
extern void UartWrite(unsigned char *buf,unsigned char len);
extern void UartDriver();
extern void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);
extern void LcdAreaClear(unsigned char x, unsigned char y, unsigned char len);
extern void InitLcd1602();
        EA = 1;
        ConfigTimer0(1);
        ConfigUART(9600);
        InitLcd1602();
        LcdShowStr(0, 0, "Welcome to 51");
                UartDriver();
/**命令比較函數,將接收的命令與現有的命令進行比較**/
bit CmpMemory(unsigned char *ptr1,unsigned char *ptr2,unsigned char len)
        while(len--)
                if(*ptr1++ != *ptr2++)
                        return 0;
        return 1;
/**根據接收到的命令執行不同的操作**/
        unsigned char i;
        unsigned char code cmd0[] = "buzz on";
        unsigned char code cmd1[] = "buzz off";
        unsigned char code cmd2[] = "showstr ";
        unsigned char code cmdlen[] = {
         sizeof(cmd0)-1,sizeof(cmd1)-1,sizeof(cmd2)-1
        unsigned char *cmdPtr[] = {&cmd0[0],&cmd1[0],&cmd2[0]};
        for(i = 0;i < 3;i++)
                if(len >= cmdlen[ i])
                        if(CmpMemory(buf,cmdPtr[ i],cmdlen[ i]))
                                break;
        switch(i)
        case(0):
                flagBuzzOn = 1;
                break;
        case(1):
                flagBuzzOn = 0;
                break;
        case(2):
                buf[len] = '\0';
                LcdShowStr(0,0,buf+cmdlen[2]);
                i = len-cmdlen[2];
                if(i < 16)
                        LcdAreaClear(i,0,16-i);
                break;
        default:
                UartWrite("erro.\r\n",sizeof("erro.\r\n")-1);
                return;
        buf[len++] = '\r';
        buf[len++] = '\n';
        UartWrite(buf,len);
unsigned long tmp; //臨時變量
tmp = 11059200 / 12; //定時器計數頻率
tmp = (tmp * ms) / 1000; //計算所需的計數值
tmp = 65536 - tmp; //計算定時器重載值
tmp = tmp + 33; //補償中斷響應延時造成的誤差
T0RH = (unsigned char)(tmp>>8); //定時器重載值拆分為高低字節
T0RL = (unsigned char)tmp;
TMOD &= 0xF0; //清零 T0 的控制位
TMOD |= 0x01; //配置 T0 為模式 1
TH0 = T0RH; //加載 T0 重載值
TL0 = T0RL;
ET0 = 1; //使能 T0 中斷
TR0 = 1; //啟動 T0
/**在中斷中調用UartRxMonitor(ms)函數,來記錄沒有接收到新命令的時間,超過30ms就認為命令已經接收完整**/
void InterruptTimer0() interrupt 1
TH0 = T0RH; //重新加載重載值
TL0 = T0RL;
if (flagBuzzOn) //執行蜂鳴器鳴叫或關閉
BUZZ = ~BUZZ;
BUZZ = 1;
UartRxMonitor(1); //串口接收監控
屏幕截圖 2021-10-30 165052.png (62.99 KB, 下載次數: 41)
ID:624769 發表于 2021-10-30 19:06 | 只看該作者
你先做最基本的
單片機每隔 0.5秒 給單片機發送 一個 ‘A'       這個過程叫 “調通”, 當你可以收到了。做下一步。
只要單片機收到  電腦發來數據, 就給 電腦 發一個 ‘B' , 這個過程叫 '聯動'。
做完上面這兩步,你再捉摸上面你發出來的程序。
ID:401564 發表于 2021-10-30 23:29 | 只看該作者
STC的下載器有現成的串口代碼,可以直接復制使用
先寫一個簡單的串口發送函數,只給電腦發送一個數據就行了
通過之后才寫別的代碼
而不是像現在這樣,一下把整個程序都寫完了才開始調試,出了問題都不知道在哪里找
