查看: 2907|回復: 13
單片機程序怎么修改設置好對應時間,等待10s左右自動倒計時,不用按鍵觸發倒計時
ID:858009 發表于 2021-10-28 11:56 | 顯示全部樓層 |閱讀模式
  1. #include<reg51.h>
  3. #define uint unsigned int
  4. uchar min,sec,count,sec1,sec2,min0,min1,min2,keystopc,temp;
  5. sbit keystop=P3^0;
  6. sbit keyh=P3^1;
  7. sbit keym=P3^2;
  8. sbit keys=P3^3;
  9. sbit lcden=P3^4;
  10. sbit lcdrw=P3^6;
  11. sbit lcdrs=P3^5;
  12. uchar code table[]={'0','1','2','3','4','5','6','7','8','9',':'};
  13. void init()                                                //定時器初始化
  14. {
  15.         count=0;
  16.         min=0;
  17.         sec=59;
  18.         TMOD=0x01;
  19.         TH0=(65536-50000)/256;
  20.         TL0=(65536-50000)%256;
  21.         TR0=0;
  22.         ET0=1;
  23.         EA=1;
  24. }
  25. void delay(uint z)                //延時程序
  26. {
  27.         uint x,y;
  28.         for(x=z;x>0;x--)
  29.          for(y=110;y>0;y--);
  30. }
  31. /**************************************************************
  32. ------LCD1602顯示函數------
  33. *************************************************************/
  34. void write_com(uchar com)
  35. {
  36.         lcdrs=0;
  37.         P0=com;
  38.         delay(5);
  39.         lcden=1;
  40.         delay(5);
  41.         lcden=0;
  42. }
  43. void write_data(uchar date)
  44. {
  45.         lcdrs=1;
  46.         P0=date;
  47.         delay(5);
  48.         lcden=1;
  49.         delay(5);
  50.         lcden=0;
  51. }
  52. void init_1602()                                //初始化1602
  53. {
  54.         lcden=0;
  55.         lcdrw=0;
  56.         write_com(0x38);
  57.         write_com(0x0c);
  58.         write_com(0x06);
  59.         write_com(0x01);
  60.         write_com(0x80);
  61. }
  62. void write_Char(unsigned char x,unsigned char y,unsigned char date)
  63. {
  64.          if (y == 0)
  65.          {
  66.                 write_com(0x80 + x);
  67.          }
  68.         else
  69.          {
  70.                 write_com(0xC0 + x);
  71.          }
  72.         write_data(date);
  73. }
  74. void display(uchar min0,uchar min1,uchar min2,uchar sec1,uchar sec2)         //顯示程序
  75. {
  76.         write_Char(3,0,table[min0]);
  77.         write_Char(4,0,table[min1]);
  78.         write_Char(5,0,table[min2]);
  79.         write_Char(6,0,table[0x0a]);
  80.         write_Char(7,0,table[sec1]);
  81.         write_Char(8,0,table[sec2]);
  82. }
  83. /************************************************************
  84. ------計時器/定時器0-----
  85. *************************************************************/
  86. void count0() interrupt 1
  87. {
  88.         TH0=(65536-50000)/256;
  89.         TL0=(65536-50000)%256;
  90.         count++;
  91.         if(count==20)
  92.                 {
  93.                         count=0;
  94.                         if(sec==0)
  95.                         {
  96.                                 if (min!=0)
  97.                                 {
  98.                                         sec=59;
  99.                                         min--;
  100.                                 }
  101.                         }
  102.                         else sec--;
  103.                 }
  104. }
  105. /************************************************************
  106. ------主函數------
  107. *************************************************************/
  108. void main()
  109. {
  110.         init();
  111.         init_1602();
  112.         while(1)
  113.         {
  114.                 if(keystop==0)                             //檢測是否停止鍵按下
  115.                 {
  116.                         delay(10);
  117.                         if(keystop==0)
  118.                         {
  119.                                 if(keystopc!=1)   keystopc++;      //按停止鍵的次數
  120.                                 else              keystopc=0;
  121.                                 while(keystop==0);                 //松手檢測
  122.                                 delay(5);
  123.                                 while(keystop==0);
  124.                         }
  125.                         switch(keystopc)
  126.                         {
  127.                                 case 1:TR0=0;break;                // 按鍵一次就停止計數
  128.                                 case 0:TR0=1;break;
  129.                                 default:break;
  130.                         }
  131.                 }
  132.                 if(keyh==0)                 //實現小時加一
  133.                 {
  134.                         delay(50);
  135.                         if(keyh==0)
  136.                         {
  137.                                 if(min!=110)
  138.                                 {
  139.                                         min++;
  140.                                 }
  141.                         }
  142.                         while(!keym);                  //松手檢測
  143.                         delay(5);
  144.                         while(!keym);
  145.                 }
  146.                 if(keym==0)              //實現分鐘加一
  147.                 {
  148.                         delay(100);
  149.                         if(keym==0)
  150.                         {
  151.                                 if(min!=0)
  152.                                 {
  153.                                         min--;
  154.                                 }
  155.                         }
  156.                         while(!keyh);                //松手檢測
  157.                         delay(5);
  158.                         while(!keyh);
  159.                 }
  160.                 min0=min/100;
  161.                 min1=min%100/10;
  162.                 min2=min%10;
  163.                 sec1=sec/10;
  164.                 sec2=sec%10;
  165.                display(min0,min1,min2,sec1,sec2);  //一直顯示時鐘
  166.         }
  167. }
ID:480510 發表于 2021-10-28 14:00 | 顯示全部樓層
再用一個定時器來控制10秒
ID:624769 發表于 2021-10-28 14:25 | 顯示全部樓層
bit  T_run;             <==== 增加全局變量
------計時器/定時器0-----
        count++;
        if(T_run)               <==== 增加
        if(count>=20)
                        count=0;
                        if(sec==0)
                                if (min!=0)
                                        sec=59;
                                        min--;
                        else sec--;
          else                      <==== 增加
                 if(count >= 200)           <==== 增加
                           T_run = 1;                  <==== 增加
                           count = 0;                 <==== 增加
------主函數------
        init();
        init_1602();
        TR0 = 1         <==== 增加
                        delay(10);
                        if(keystop==0)
                                else              keystopc=0;
                                delay(5);
                                while(keystop==0);
                        switch(keystopc)
//                                case 1:TR0=0;break;                // 按鍵一次就停止計數
//                                case 0:TR0=1;break;
                                case 1:T_run=0;break;           <==== 修改
                                case 0:T_run=1;break;           <==== 修改
                               default:break;
                        delay(50);
                        if(keyh==0)
                                if(min!=110)
                                        min++;
                                count = 0;             <==== 增加
                        delay(5);
                        while(!keym);
                        delay(100);
                        if(keym==0)
                                if(min!=0)
                                        min--;
                                count = 0;                  <==== 增加
                        delay(5);
                        while(!keyh);
                min0=min/100;
                min1=min%100/10;
                min2=min%10;
                sec1=sec/10;
                sec2=sec%10;
慘不忍睹,只能改成這樣了
ID:123289 發表于 2021-10-28 14:33 | 顯示全部樓層
既然是計時就一定有開始和結束。
結束:可以由計時器計時10s后觸發。
開始:誰觸發呢?不用按鍵觸發,也需要你設置一個觸發的方式呀。哪怕你決定打個噴嚏也行啊。
ID:858009 發表于 2021-10-28 14:41 | 顯示全部樓層
yzwzfyz 發表于 2021-10-28 14:33
既然是計時就一定有開始和結束。
結束:可以由計時器計時10s后觸發。
開始:誰觸發呢?不用按鍵觸發,也 ...
這個是做一個倒計時的,只有兩個按鍵,一個控制分鐘加,一個控制分鐘減
看能不能自動觸發開始倒計時,設置倒計的時間后等待十秒,按鍵加和按鍵減沒有被按下,測開始倒計時,啟動定時器1
ID:311846 發表于 2021-10-28 15:10 | 顯示全部樓層
qwettyuio 發表于 2021-10-28 14:41
看能不能自動觸發開始倒計時,設 ...
那你再定時10秒啊!
ID:123289 發表于 2021-10-29 09:46 | 顯示全部樓層
本帖最后由 yzwzfyz 于 2021-10-30 11:27 編輯
很簡單的事!抓住要點:如何起,如何停。再想想,不要想程序如何寫,想想邏輯上是否說得通。
ID:858009 發表于 2021-11-10 14:53 | 顯示全部樓層
我想把那個暫停/啟動按鍵去掉,例如設置10分鐘倒計時,設置結束后等待10s啟動倒計時
ID:858009 發表于 2021-11-10 14:57 | 顯示全部樓層
yzwzfyz 發表于 2021-10-29 09:46
原本使用一個按鍵控制啟動和暫停
現在想使用設置好對應時間,等待10s左右,開啟定時器進入倒計時,倒計時結束后定時器停止,蜂鳴器響3s停3s循環
ID:624769 發表于 2021-11-10 15:15 | 顯示全部樓層
qwettyuio 發表于 2021-11-10 14:53
不是幫你改好了么?
你不要那個暫停/啟動 直接刪掉不就行了? 你程序試過沒有? 是不是那個鍵按不按都沒所謂?是的話,直接刪了不就沒有了?
ID:858009 發表于 2021-11-10 15:58 | 顯示全部樓層
188610329 發表于 2021-11-10 15:15
不是幫你改好了么?
你不要那個暫停/啟動 直接刪掉不就行了? 你程序試過沒有? 是不是那個鍵按不按都 ...
這個不能等待按鍵設置對應時間后等待10s再啟動定時器進入倒計時,倒計時結束后,定時器一直在啟動,沒有中斷停止
ID:858009 發表于 2021-11-10 16:00 | 顯示全部樓層
不是幫你改好了么?
有兩個加減按鍵設置時間的,倒計時結束后有蜂鳴器提示的,既要啟動,也要停止
ID:624769 發表于 2021-11-10 16:21 | 顯示全部樓層
qwettyuio 發表于 2021-11-10 15:58
這個不能等待按鍵設置對應時間后等待10s再啟動定時器進入倒計時,倒計時結束后,定時器一直在啟動,沒有 ...
這么改就是設好時間后,等10秒啟動啊,你不是要等10秒啟動么? 定時器關了,怎么判斷10秒?
至于停止,你原來怎么停的?你原來停的地方, 只要T_run = 0, 就停了啊,我只看到你按鍵的地方,所以那里我幫你寫了 T_run = 0;
但是,其他地方,我沒看到,你有其他停的地方,你手動把 T_run = 0, 反正, TR0 是不能 =0 的 不然,沒辦法10秒自己啟動。
ID:624769 發表于 2021-11-10 16:23 | 顯示全部樓層
qwettyuio 發表于 2021-11-10 16:00
你原程序里哪里有到時間蜂鳴器響的判斷? 你原程序里沒有,我幫你憑空加出來?
