基于arduino的計時器(包涵倒計時、暫停、重置),在proteus8中仿真通過。用了兩組1673的時鐘芯片。
Arduino代碼如下:
- #include <SevenSegmentTM1637.h>
- #include <SevenSegmentExtended.h>
- volatile int minute;
- volatile int second;
- volatile int order;
- volatile int full;
- volatile int empty;
- volatile int setvalue;
- volatile int topvalue;
- boolean timerState=LOW;
- SevenSegmentExtended display(8,9);
- void setup(){
- pinMode(2, INPUT);
- minute = 0;
- second = 0;
- order = 0;
- full = 0;
- empty = 0;
- setvalue = 5;
- topvalue = 0;
- display.begin();
- order = 0;
- // 倒計時時sencond與minute從full開始計時,順計時從empty開始計時
- if (order == 0) {
- empty = 0;
- full = 59;
- minute = setvalue;
- second = 0;
- topvalue = 0;
- } else {
- empty = 59;
- full = 0;
- minute = 0;
- // 設置為x分鐘,加上秒鐘走59,實際多走了一分鐘,所以減一
- topvalue = setvalue - 1;
- attachInterrupt(digitalPinToInterrupt(2),interruptFun,LOW);
- void loop(){
- // 決定順計時倒計時0為倒計時,1為順計時
- // 設置計時的最大數值
- // 倒計時時topvalue=0時minute重置為setvalue
- // 順計時topvalue=setvalue值時被重置
- // minute=0
- if(timerState)
- display.printTime(minute,second,true);
- delayMicroseconds(1);
- if (second == empty && minute == topvalue) {
- if (order == 0) {
- // 當minute達到設定的值則
- second = empty;
- } else {
- // 當minute達到設定的值則
- minute = full;
- second = full;
- } else if (second == empty) {
- if (order == 0) {
- second = 59;
- minute = minute - 1;
- } else {
- second = 0;
- minute = minute + 1;
- } else {
- if (order == 0) {
- second = second - 1;
- } else {
- second = second + 1;
- void interruptFun()
- timerState=!timerState;
- digitalWrite(5,timerState);
- // Inside the attached function, delay() won't work and the value returned by millis() will not increment.
- // delay(5000);
Proteus8.8版本的仿真圖下載:
countDowntimer.zip
(31.11 KB, 下載次數: 53)
2021-10-25 11:03 上傳
