查看: 2157|回復: 2
Build target 'Target 1' compiling DS1302.c... DS1302.c(6): error C129: missin...
ID:974311 發表于 2021-10-25 00:19 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#include <intrins.h>
typedef unsigned char u8;
u8 LED1 LED2 LED3 LED4 LED5 LED7 LED8
u8 time1 time2 time3 time4 time5 time7 time8
u8 select_function
sbit RS=P2^0;
sbit RW=P2^1;
sbit E=P1^2;
sbit T_RST=P1^3;
sbit T_CLK=P1^7;
sbit T_IO=P2^3;
sbit s7=P3^0;
sbit s6=P3^1;
sbit s5=P3^2;
sbit s4=P3^3;
unsigned char timechar[]={"TIME:"};
unsigned char datechar[]={"DATE:"};
void Timer0Init()
        TMOD=0X01;
        TH0=0XD8;
        TL0=0XF0;
        ET0=1;
        EA=1;
        TR0=1;
void time_calculate()
        time1++;
        if(time1==60)
                time1=0;
                time2++;
        if(time2==60)
                time2=0;
                time3++;
        if(time3==24)
                time1=0;
                time2=0;
                time3++;
void  WriteB(unsigned char  dat)
   unsigned char  i;
   for(i=8; i>0; i--)
        T_IO=dat&0x01;
        T_CLK = 1;
        T_CLK = 0;
        dat = dat >> 1;
unsigned char  ReadB(void)
    unsigned char i,readdat=0;
    for(i=8; i>0; i--)
        readdat=readdat>>1;
        if(T_IO)
            readdat|=0x80;
        T_CLK = 1;
        T_CLK = 0;
    return(readdat);
void  W1302(unsigned char address,unsigned char dat)
    T_RST = 0;
    T_CLK = 0;
    _nop_();
    _nop_();
    T_RST = 1;
    _nop_();
    _nop_();
    WriteB(address);
    WriteB(dat);
    T_CLK = 1;
    T_RST =0;
unsigned char  R1302(unsigned char  address)
    unsigned char dat=0;
    T_RST = 0;
    T_CLK = 0;
    T_RST = 1;
    WriteB(address);
    dat = ReadB();
    T_CLK = 1;
    T_RST =0;
    return(dat);
void delay(unsigned int n)
  unsigned i=0,j=0;
    for(i=0;i<n;i++)
      for(j=0;j<120;j++);
void writedat(unsigned char dat)
  RS=1;
    RW=0;
    E=0;
    P0=dat;
    delay(5);
    E=1;
    E=0;
void writecom(unsigned char com)
  RS=0;
    RW=0;
    E=0;
    P0=com;
    delay(5);
    E=1;
    E=0;
void Initlcd()
    writecom(0x38);
    writecom(0x0c);
    writecom(0x06);
    writecom(0x01);
//*************************°′¼ü¿ØÖÆ**************************************
void keypros()
        if(s6==0)
                delay(10);
          if(s6==0)
                   select_function++;
                   if(select_function==4)select_function=0;
                   if(select_function!=0)TRO=0;
           }while(!s6);
          if(select_function==0)TRO=1;
        if(select_function==1)
                if(s5==0)
                        time1++;
                        if(time1>=60)time1=0
                        }while(!s5);
                if(s4==0)
                        if(time1==0)time1=60;
                        time1--;
                }while(!s4);
if(select_function==2)
                if(s5==0)
                        time2++;
                        if(time2>=60)time2=0
                        }while(!s5);
                if(s4==0)
                        if(time2==0)time2=60;
                        time2--;
                }while(!s4);
        if(select_function==3)
                if(s5==0)
                        time3++;
                        if(time3>=24)time3=0
                        }while(!s5);
                if(s4==0)
                        if(time3==0)time3=24;
                        time3--;
                }while(!s4);
        LED1=time1%10;
        LED1=time1/10;
        LED2=time2%10;
        LED2=time2/10;
        LED3=time3%10;
        LED3=time3/10;
//************************ÖD¶Ï£¨Ã¿¸ô10msÖD¶Ïò»′Σ¬Ë¢DÂ걼䣩***********
void Timer0() interrupt 1
        static unsigned int k=0;
        TH0=0xD8;
        TL0=0xF0;
        k++;
        if(k==50)
                k=0;
                timer_calculate();
void display()
   lcd_pos(0x07);
         lcdwriteData(LED8+'0');
   lcd_pos(0x08);
         lcdwriteData(LED7+'0');
         lcd_pos(0x09);
         lcewriteData('-');
         lcd_pos(0x0A);
         lcdwriteData(LED5+'0');
   lcd_pos(0x0B);
         lcdwriteData(LED4+'0');
         lcd_pos(0x0C);
         lcewriteData('-');
         lcd_pos(0x0D);
         lcdwriteData(LED2+'0');
   lcd_pos(0x0E);
         lcdwriteData(LED1+'0');
         lcd_pos(0x0F);
         lcewriteData('-');
    Initlcd();
    show_string(display);
        Time0Init();
        LED1=0;
        LED2=0;
        LED3=0;
        LED4=0;
        LED5=0;
        LED6=0;
        LED7=0;
        LED8=0;
        select_function=0;
        time1=0;
        time2=0;
        time3=0;
                        keypros();
      display();
ID:123289 發表于 2021-10-25 16:16 | 只看該作者
先將本句翻譯成中文,再對照理解一下,看它說的,與你做的是不是相符,即它說的對不對?
ID:824490 發表于 2021-10-26 10:12 | 只看該作者
新手飯量大,總愛把“;”當飯吃了。。
