查看: 2086|回復: 2
51單片機1602液晶屏如何改下面程序,使其滾動顯示
ID:972842 發表于 2021-10-19 17:39 | 顯示全部樓層 |閱讀模式
16黑幣
#include <reg51.h>
#include <intrins.h>
#define uint unsigned char
#define out p0
sbit RS=P2^0;
sbit RW=P2^1;
sbit E=P2^2;
void lcd_initial(void);
void check_busy(void);
void write_command(uchar com);
void write_data(uchar dat);
void string(uchar ad ,uchar *s);
void delay(uint);
void main(void)
lcd _initial ();
string(0x85,"welcome");
string(0xc2,"Harbin CHINA");
delay(100);
write_command(0x01);
delay(100);
void delay(uint j)
uchar i=250;
for(;j>0;j--)
while(--i);
i=249;
while(--i);
i=250;
uchar dt;
do
dt=0xff;
E=0;
RS=0;
RW=1;
E=1;
dt=out;
}while(dt&0x80);
E=0;
check_busy();
E=0;
RS=0;
RW=0;
out=com;
E=1;
_nop_();
E=0;
delay(1);
check_busy();
E=0;
RS=1;
RW=0;
out=dat;
E=1;
_nop_();
E=0;
delay(1);
void lcd_initial (void)
write_command(0x38);
write_command(0x0C);
write_command(0x05);
delay(1);
void string(uchar ad,uchar *s)
write_command(ad);
while(*s>0)
write_data(*s++);
delay(100);
ID:734856 發表于 2021-10-19 23:11 | 顯示全部樓層
上下?左右?
ID:972842 發表于 2021-10-20 07:19 | 顯示全部樓層
左右滾動
