我把mpu6050的計算程序移植到51單片機上面,程序沒有報錯,卻計算不出角度,煩請指導(dǎo)一下,或給出正確的計算函數(shù)程序如下:
- #include <REG52.H>
- #include <math.h> //Keil library
- #include <stdio.h> //Keil library
- #include <INTRINS.H>
- typedef unsigned char uchar;
- typedef unsigned short ushort;
- typedef unsigned int uint;
- typedef unsigned char u8;
- //--聲明一些需要使用的變量--//
- uchar MPU6050_DATA[14];
- int Gyro_x,Gyro_y,Gyro_z;
- int Gyro_angle_x=0,Gyro_angle_y=0,Gyro_angle_z=0;
- int Acc_x,Acc_y,Acc_z;
- int Temp;
- int xdata g_x=0,g_y=0,g_z=0; //陀螺儀矯正參數(shù)
- float xdata a_x=0,a_y=0; //角度矯正參數(shù)
- float data AngleX=0,AngleY=0; //四元數(shù)解算出的歐拉角
- float xdata Angle_gx=0,Angle_gy=0,Angle_gz=0; //由角速度計算的角速率(角度制)
- float xdata Angle_ax=0,Angle_ay=0,Angle_az=0; //由加速度計算的加速度(弧度制)
- // 定義51單片機端口
- #define DataPort P0 //LCD1602數(shù)據(jù)端口
- sbit SCL=P1^1; //IIC時鐘引腳定義
- sbit SDA=P1^0; //IIC數(shù)據(jù)引腳定義
- sbit LCM_RS=P3^5; //LCD1602命令端口
- sbit LCM_RW=P3^6; //LCD1602命令端口
- sbit LCM_EN=P3^4; //LCD1602命令端口
- // 定義MPU6050內(nèi)部地址
- #define SMPLRT_DIV 0x19 //陀螺儀采樣率,典型值:0x07(125Hz)
- #define CONFIG 0x1A //低通濾波頻率,典型值:0x06(5Hz)
- #define GYRO_CONFIG 0x1B //陀螺儀自檢及測量范圍,典型值:0x18(不自檢,2000deg/s)
- #define ACCEL_CONFIG 0x1C //加速計自檢、測量范圍及高通濾波頻率,典型值:0x01(不自檢,2G,5Hz)
- #define ACCEL_XOUT_H 0x3B
- #define ACCEL_XOUT_L 0x3C
- #define ACCEL_YOUT_H 0x3D
- #define ACCEL_YOUT_L 0x3E
- #define ACCEL_ZOUT_H 0x3F
- #define ACCEL_ZOUT_L 0x40
- #define TEMP_OUT_H 0x41
- #define TEMP_OUT_L 0x42
- #define GYRO_XOUT_H 0x43
- #define GYRO_XOUT_L 0x44
- #define GYRO_YOUT_H 0x45
- #define GYRO_YOUT_L 0x46
- #define GYRO_ZOUT_H 0x47
- #define GYRO_ZOUT_L 0x48
- #define PWR_MGMT_1 0x6B //電源管理,典型值:0x00(正常啟用)
- #define WHO_AM_I 0x75 //IIC地址寄存器(默認數(shù)值0x68,只讀)
- #define SlaveAddress 0xD0 //IIC寫入時的地址字節(jié)數(shù)據(jù),+1為讀取
- //定義類型及變量
- uchar dis[4]; //顯示數(shù)字(-511至512)的字符數(shù)組
- int dis_data; //變量
- //int Temperature,Temp_h,Temp_l; //溫度及高低位數(shù)據(jù)
- //函數(shù)聲明
- void delay(unsigned int k); //延時
- //LCD相關(guān)函數(shù)
- void InitLcd(); //初始化lcd1602
- void lcd_printf(uchar *s,int temp_data);
- void WriteDataLCM(uchar dataW); //LCD數(shù)據(jù)
- void WriteCommandLCM(uchar CMD,uchar Attribc); //LCD指令
- void DisplayOneChar(uchar X,uchar Y,uchar DData); //顯示一個字符
- void DisplayListChar(uchar X,uchar Y,uchar *DData,L); //顯示字符串
- //MPU6050操作函數(shù)
- void InitMPU6050(); //初始化MPU6050
- void Delay5us();
- void I2C_Start();
- void I2C_Stop();
- void I2C_SendACK(bit ack);
- bit I2C_RecvACK();
- void I2C_SendByte(uchar dat);
- uchar I2C_RecvByte();
- void I2C_ReadPage();
- void I2C_WritePage();
- void display_ACCEL_x();
- void display_ACCEL_y();
- void display_ACCEL_z();
- uchar Single_ReadI2C(uchar REG_Address); //讀取I2C數(shù)據(jù)
- void Single_WriteI2C(uchar REG_Address,uchar REG_data);//向I2C寫入數(shù)據(jù)
- void Delay2us(void)
- u8 i;
- i = 11; // @24MHZ, 6 + 33 = 39T, 1.625us
- while (--i);
- void Read_MPU6050(u8 *buf)
- u8 i;
- I2C_Start(); //起始信號
- I2C_SendByte(SlaveAddress); //發(fā)送設(shè)備地址+寫信號
- I2C_SendByte(ACCEL_XOUT_H); //內(nèi)部寄存器地址,
- I2C_SendByte(SlaveAddress+1); //發(fā)送設(shè)備地址+讀信號
- for(i=0; i<13; i++)
- buf[i] = I2C_RecvByte(); //讀出寄存器數(shù)據(jù)
- SDA = 0; //寫應(yīng)答信號
- SCL = 1; //拉高時鐘線
- Delay2us(); //延時
- SCL = 0; //拉低時鐘線
- Delay2us(); //延時
- buf[i] = I2C_RecvByte(); //最后一個字節(jié)
- SDA = 1; //寫非應(yīng)答信號
- SCL = 1; //拉高時鐘線
- Delay2us(); //延時
- SCL = 0; //拉低時鐘線
- Delay2us(); //延時
- I2C_Stop(); //停止信號
- //整數(shù)轉(zhuǎn)字符串
- if(temp_data<0)
- temp_data=-temp_data;
- *s='-';
- else *s=' ';
- *++s =temp_data/100+0x30;
- temp_data=temp_data%100; //取余運算
- *++s =temp_data/10+0x30;
- temp_data=temp_data%10; //取余運算
- *++s =temp_data+0x30;
- //延時
- unsigned int i,j;
- for(i=0;i<k;i++)
- for(j=0;j<121;j++);
- //LCD1602初始化
- void InitLcd()
- WriteCommandLCM(0x38,1);
- WriteCommandLCM(0x08,1);
- WriteCommandLCM(0x01,1);
- WriteCommandLCM(0x06,1);
- WriteCommandLCM(0x0c,1);
- DisplayOneChar(0,0,'A');
- DisplayOneChar(0,1,'G');
- //LCD1602寫允許
- void WaitForEnable(void)
- DataPort=0xff;
- LCM_RS=0;LCM_RW=1;_nop_();
- LCM_EN=1;_nop_();_nop_();
- while(DataPort&0x80);
- LCM_EN=0;
- //LCD1602寫入命令
- if(Attribc)WaitForEnable();
- LCM_RS=0;LCM_RW=0;_nop_();
- DataPort=CMD;_nop_();
- LCM_EN=1;_nop_();_nop_();LCM_EN=0;
- //LCD1602寫入數(shù)據(jù)
- WaitForEnable();
- LCM_RS=1;LCM_RW=0;_nop_();
- DataPort=dataW;_nop_();
- //LCD1602寫入一個字符
- Y&=1;
- X&=15;
- if(Y)X|=0x40;
- X|=0x80;
- WriteCommandLCM(X,0);
- WriteDataLCM(DData);
- //LCD1602顯示字符串
- uchar ListLength=0;
- Y&=0x1;
- X&=0xF;
- while(L--)
- DisplayOneChar(X,Y,DData[ListLength]);
- ListLength++;
- X++;
- //延時5微秒(STC90C52RC@12M)
- //不同的工作環(huán)境,需要調(diào)整此函數(shù)
- //當改用1T的MCU時,請調(diào)整此延時函數(shù)
- void Delay5us()
- _nop_();_nop_();_nop_();_nop_();
- //I2C起始信號
- void I2C_Start()
- Delay2us(); //延時
- Delay2us(); //延時
- SDA = 1; //拉高數(shù)據(jù)線
- SCL = 1; //拉高時鐘線
- Delay2us(); //延時
- Delay2us(); //延時
- SDA = 0; //產(chǎn)生下降沿
- Delay2us(); //延時
- SCL = 0; //拉低時鐘線
- Delay2us(); //延時
- //I2C停止信號
- void I2C_Stop()
- Delay2us(); //延時
- SDA = 0; //拉低數(shù)據(jù)線
- SCL = 1; //拉高時鐘線
- Delay2us(); //延時
- SDA = 1; //產(chǎn)生上升沿
- Delay2us(); //延時
- //I2C發(fā)送應(yīng)答信號
- //入口參數(shù):ack (0:ACK 1:NAK)
- SDA = ack; //寫應(yīng)答信號
- SCL = 1; //拉高時鐘線
- Delay5us(); //延時
- SCL = 0; //拉低時鐘線
- Delay5us(); //延時
- //I2C接收應(yīng)答信號
- bit I2C_RecvACK(void)
- SDA = 1;
- Delay2us(); //延時
- SCL = 1; //拉高時鐘線
- Delay2us(); //延時
- CY = SDA; //讀應(yīng)答信號
- SCL = 0; //拉低時鐘線
- Delay2us(); //延時
- return CY;
- //向I2C總線發(fā)送一個字節(jié)數(shù)據(jù)
- void I2C_SendByte(u8 dat)
- u8 i;
- for (i=0; i<8; i++) //8位計數(shù)器
- dat <<= 1; //移出數(shù)據(jù)的最高位
- SDA = CY; //送數(shù)據(jù)口
- SCL = 1; //拉高時鐘線
- Delay2us(); //延時
- SCL = 0; //拉低時鐘線
- Delay2us(); //延時
- I2C_RecvACK();
- //從I2C總線接收一個字節(jié)數(shù)據(jù)
- u8 i;
- u8 dat = 0;
- SDA = 1; //使能內(nèi)部上拉,準備讀取數(shù)據(jù),
- dat <<= 1;
- SCL = 1; //拉高時鐘線
- Delay2us(); //延時
- dat |= SDA; //讀數(shù)據(jù)
- SCL = 0; //拉低時鐘線
- Delay2us(); //延時
- return dat;
- //向I2C設(shè)備寫入一個字節(jié)數(shù)據(jù)
- void Single_WriteI2C(u8 REG_Address,u8 REG_data)
- I2C_SendByte(REG_Address); //內(nèi)部寄存器地址,
- I2C_SendByte(REG_data); //內(nèi)部寄存器數(shù)據(jù),
- I2C_Stop(); //發(fā)送停止信號
- //從I2C設(shè)備讀取一個字節(jié)數(shù)據(jù)
- u8 Single_ReadI2C(u8 REG_Address)
- u8 REG_data;
- I2C_SendByte(REG_Address); //發(fā)送存儲單元地址,從0開始
- REG_data=I2C_RecvByte(); //讀出寄存器數(shù)據(jù)
- SDA = 1; //寫應(yīng)答信號
- SCL = 1; //拉高時鐘線
- Delay2us(); //延時
- SCL = 0; //拉低時鐘線
- Delay2us(); //延時
- return REG_data;
- //初始化MPU6050
- Single_WriteI2C(PWR_MGMT_1, 0x00); //解除休眠狀態(tài)
- Single_WriteI2C(SMPLRT_DIV, 0x07);
- Single_WriteI2C(CONFIG, 0x04);
- Single_WriteI2C(GYRO_CONFIG, 0x08);
- Single_WriteI2C(ACCEL_CONFIG, 0x08);
- //合成數(shù)據(jù)
- int GetData(uchar REG_Address)
- char H,L;
- H=Single_ReadI2C(REG_Address);
- L=Single_ReadI2C(REG_Address+1);
- return (H<<8)+L; //合成數(shù)據(jù)
- //在1602上顯示10位數(shù)據(jù)
- void Display10BitData(int value,uchar x,uchar y)
- value/=64; //轉(zhuǎn)換為10位數(shù)據(jù)
- lcd_printf(dis, value); //轉(zhuǎn)換數(shù)據(jù)顯示
- DisplayListChar(x,y,dis,4); //啟始列,行,顯示數(shù)組,顯示長度
- //****************角度計算*********************************************
- #define pi 3.14159265f
- #define Kp 0.8f
- #define Ki 0.001f
- #define halfT 0.004f
- float idata q0=1,q1=0,q2=0,q3=0;
- float idata exInt=0,eyInt=0,ezInt=0;
- void IMUupdate(float gx, float gy, float gz, float ax, float ay, float az)
- float data norm;
- float idata vx, vy, vz;
- float idata ex, ey, ez;
- norm = sqrt(ax*ax + ay*ay + az*az);
- ax = ax / norm;
- ay = ay / norm;
- az = az / norm;
- vx = 2*(q1*q3 - q0*q2);
- vy = 2*(q0*q1 + q2*q3);
- vz = q0*q0 - q1*q1 - q2*q2 + q3*q3 ;
- ex = (ay*vz - az*vy) ;
- ey = (az*vx - ax*vz) ;
- ez = (ax*vy - ay*vx) ;
- exInt = exInt + ex * Ki;
- eyInt = eyInt + ey * Ki;
- ezInt = ezInt + ez * Ki;
- gx = gx + Kp*ex + exInt;
- gy = gy + Kp*ey + eyInt;
- gz = gz + Kp*ez + ezInt;
- q0 = q0 + (-q1*gx - q2*gy - q3*gz) * halfT;
- q1 = q1 + ( q0*gx + q2*gz - q3*gy) * halfT;
- q2 = q2 + ( q0*gy - q1*gz + q3*gx) * halfT;
- q3 = q3 + ( q0*gz + q1*gy - q2*gx) * halfT;
- norm = sqrt(q0*q0 + q1*q1 + q2*q2 + q3*q3);
- q0 = q0 / norm;
- q1 = q1 / norm;
- q2 = q2 / norm;
- q3 = q3 / norm;
- AngleX = asin(2*(q0*q2 - q1*q3 )) * 57.2957795f;
- AngleY = asin(2*(q0*q1 + q2*q3 )) * 57.2957795f;
- //主程序
- void main()
- delay(500); //上電延時
- InitLcd(); //液晶初始化
- InitMPU6050(); //初始化MPU6050
- delay(150);
- while(1)
- { Read_MPU6050(MPU6050_DATA);
- Acc_x = MPU6050_DATA[0]<<8|MPU6050_DATA[1];
- Acc_y = MPU6050_DATA[2]<<8|MPU6050_DATA[3];
- Acc_z = MPU6050_DATA[4]<<8|MPU6050_DATA[5];
- Temp = MPU6050_DATA[6]<<8|MPU6050_DATA[7];
- Gyro_x = MPU6050_DATA[8]<<8|MPU6050_DATA[9];
- Gyro_y = MPU6050_DATA[10]<<8|MPU6050_DATA[11];
- Gyro_z = MPU6050_DATA[12]<<8|MPU6050_DATA[13];
- Angle_ax = Acc_x/8192.0;
- Angle_ay = Acc_y/8192.0;
- Angle_az = Acc_z/8192.0;
- Angle_gx = Gyro_x/65.5;
- Angle_gy = Gyro_y/65.5;
- Angle_gz = Gyro_z/65.5;
- IMUupdate(Angle_gx*0.0174533f,Angle_gy*0.0174533f,Angle_gz*0.0174533f,Angle_ax,Angle_ay,Angle_az);
- Display10BitData(GetData(ACCEL_XOUT_H),2,0); //顯示X軸加速度
- Display10BitData(GetData(ACCEL_YOUT_H),7,0); //顯示Y軸加速度
- Display10BitData(GetData(ACCEL_ZOUT_H),12,0); //顯示Z軸加速度
- Display10BitData(AngleX,2,1); //顯示俯仰角
- Display10BitData(AngleY,7,1); //顯示橫滾角
- Display10BitData(GetData(GYRO_ZOUT_H),12,1); //未改,顯示Z軸角速度
- delay(500);
