查看: 2704|回復: 3
為什么仿真液晶無顯示
ID:678280 發表于 2021-10-15 12:00 | 顯示全部樓層 |閱讀模式
請教了,不知錯在哪里,仿真時液晶就是啥都沒有。謝謝。
ID:678280 發表于 2021-10-15 12:01 | 顯示全部樓層
上圖的代碼
#include<reg52.h>
#include<string.h>
void Initialize_LCD();
void DelayMS(uint ms);
void ShowString(uchar,uchar,uchar *);
sbit K1=P3^0;
sbit K2=P3^1;
sbit K3=P3^2;
uchar code Prompt[]="Press K1 - K3 To Start Demo Prog";
//待滾動顯示的信息段落,每行不超過80個字符,共6行
uchar const Line_Count=6;
uchar code Msg[][80]=
        "Many CAD users dismiss schematic capture as a necessary evil in the ",
        "process of creating PCB layout but we have always disputed this point ",
        "of view. With PCB layout now offering automation of both component ",
        "can often be the most time consuming element of the exercise.",
        "And if you use circuit simulation to develop your ideas, ",
        "you are going to spend even more time working on the schematic."
//顯示緩沖(2行)
uchar Disp_Buffer[32];
void V_Scroll_Display() //垂直滾動顯示
        uchar i,j,k=0;
        uchar *p=Msg[0];
        uchar *q=Msg[Line_Count]+strlen(Msg[Line_Count]);
        //以下僅使用顯示緩沖的前16字節空間
        while(p<q)
                for(i=0;i<16&&p<q;i++)
                {        //消除顯示緩沖中待顯示行首尾可能出現的空格
                        if((i==0||i==15)&&*p==' ') p++;
                        if(*p!='\0')
                                Disp_Buffer[i]=*p++;
                                if(++k>Line_Count) break;
                                p=Msg[k];                                        //p指向下一串的首地址
                //不足16個字符時空格補充
                for(j=i;j<16;j++) Disp_Buffer[j]=' ';
                //垂直滾動顯示
                while(F0) DelayMS(5);
                ShowString(0,0,"                 ");
                DelayMS(150);
                ShowString(0,1,Disp_Buffer);
                DelayMS(150);
                ShowString(0,0,Disp_Buffer);
                ShowString(0,1,"                 ");
                DelayMS(150);
        //最后清屏
void H_Scroll_Display()//水平滾動顯示
        uchar i,j,k=0,L=0;
        uchar *p=Msg[0];
        //將32個字符的顯示緩沖前16個字符設為空格
        for(i=0;i<16;i++) Disp_Buffer[i]=' ';
        while(p<q)
                //忽略緩沖中首尾可能出現的空格
                if((i==16||i==31)&&*p==' ') p++;
                for(i=16;i<32&&p<q;i++)
                        if(*p!='\0')
                //不足32個字符時空格補充
                for(j=i;j<32;j++) Disp_Buffer[j]=' ';
                //水平滾動顯示
                for(i=0;i<=16;i++)
                        ShowString(0,L,Disp_Buffer+i);
                        DelayMS(20);
                L=(L==0)?1:0;                //行號在0,1間交替
                DelayMS(300);
        //如果顯示結束時停留在第0行,則清除第1行的內容
        if(L==1) ShowString(0,1,"                 ");
void EX_INT0() interrupt 0//外部中斷0,由K3控制暫停與繼續顯示
  F0=!F0;                //暫停與繼續顯示控制標志位
        uint Count=0;
        IE=0x81;                //允許外部中斷0
        IT0=1;                        //下降沿觸發
        F0=0;                        //暫停與繼續顯示控制標志位
        Initialize_LCD();
        ShowString(0,0,Prompt);
        ShowString(0,1,Prompt+16);
                if(K1==0)
                        V_Scroll_Display();
                        DelayMS(300);
                if(K2==0)
                        H_Scroll_Display();
                        DelayMS(300);
ID:752974 發表于 2021-10-16 11:29 | 顯示全部樓層
仿真中用到的器件要有相應的仿真數學模型,有的器件缺這個模型,就不能仿真,可以換一個試試。
ID:856329 發表于 2021-10-16 12:11 | 顯示全部樓層
樓主,仿真圖中排阻網絡標號錯位,lcd不確定是否有錯。
另外,程序中沒有看到lcd控制引腳的定義。
以下是我仿真的lcd1602和排阻接法,可以參考。
Screenshot_2021-10-16-12-03-08-328_com.miui.gallery.png Screenshot_2021-10-16-12-02-58-359_com.miui.gallery.png
自用的lcd1602驅動奉上,僅供參考
Lcd1602驅動.zip (1.67 KB, 下載次數: 2)
