查看: 2627|回復: 9
在嘗試制作avr16單片機帶鬧鈴功能的時鐘遇到一些問題,請求指教
ID:962686 發表于 2021-9-2 18:36 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
我打算設置鬧鐘響10s(count2==1000),但是鬧鐘會響11s.請問是什么原因。新手單片機入門,結果處處碰壁。單片機好難
//時鐘頻率8M
#include<iom16v.h>
#include"lcd1602.h"
#define key_state0 0
#define key_state1 1
#define key_state2 2
#define key_off 0
#define key1 1
#define key2 2
#define key3 3
#define time_display 0
#define clock_set 1
#define alarm_set 2
#define set_h 0
#define set_m 1
#define set_s 2
void main(void);
void io_init(void);
void time_init(void);
void cpu_init(void);
void time_10ms(void);
char key_scan(void);
void Pattern(void);//模式
void Alarm(void);//鬧鐘響
void Set(void);//設置狀態
void time(void);
const char num[] = {"0123456789"};
char cs = 0,cm = 0,ch = 0;//實時時鐘
char as = 5,am = 0,ah = 0;//鬧鐘
char ss,sm,sh;
char time_10ms_ok;//10ms按鍵掃描標志
char time_10s_ok;//10s鬧鈴標志
char key_sign;//存儲按鍵狀態
char set = set_h;
uint count1 = 0, count2 = 0;
void io_init(void)
         DDRA |= 1<<7;
        PORTA |= 1<<7;
         DDRB = 0X00;
        PORTB = 0XFF;
        DDRC = 0XFF;
        PORTC = 0XFF;
        DDRD |= (1<<7)|(1<<6)|(1<<5);
        PORTD |= (1<<7)|(1<<6)|(1<<5);
         TCCR1A = 0X00;
         TCCR1B = (1<<WGM12)|(3<<CS10);//CTC,64分頻
        OCR1AH = 1250>>8;
        OCR1AL = 1250;
        TCNT1 = 0;
         TIMSK = 1<<OCIE1A;
         SREG = 1<<7;
void cpu_init(void)
         io_init();
        time_init();
        lcd_init();
#pragma interrupt_handler time_10ms:7
        count1++;
        count2++;
        time_10ms_ok = 1;//10ms按鍵掃描標志
char key_scan(void)
         static char key_press, key_state = 0;
        char key_return = key_off;
        key_press = PINB;
        switch(key_state)
                 case key_state0:
                         if(key_press != 0XFF)//若有按鍵按下,則進入確認狀態
                                 key_state = key_state1;
                        break;
                case key_state1:
                         if(key_press != 0XFF)//確認有按鍵按下,開始識別按鍵按下位置
                                 if(!(key_press & (1<<PB0))) key_return = key1;//按鍵1
                                else if(!(key_press & (1<<PB1))) key_return = key2;//按鍵2
                                else if(!(key_press & (1<<PB2))) key_return = key3;//按鍵3
                                 key_state = key_state2;
                        else key_state = key_state0;//若按鍵抬起則回到初始狀態
                        break;
                case key_state2:
                         if(key_press == 0XFF)//若按鍵抬起則回到初始狀態
                        break;
                default: key_state = key_state0; break;
        return key_return;
void Pattern(void)//模式函數
         static char pattern = time_display;
         switch(pattern)
                 case time_display://模式1,實時時鐘顯示
                         if(time_10ms_ok)
                                 time_10ms_ok = 0;
                                key_sign = key_scan();
                                if(key_sign == key1)
                                         pattern = clock_set;//時鐘設置
                                        set = set_h;//回到小時位調整
                                        ss = cs;
                                        sm = cm;
                                        sh = ch;
                                else time();
                        break;
                case clock_set://模式2,時鐘設置
                         if(time_10ms_ok)
                                 time_10ms_ok = 0;
                                         pattern = alarm_set;//鬧鐘設置
                                        cs = ss;
                                        cm = sm;
                                        ch = sh;
                                        ss = as;
                                        sm = am;
                                        sh = ah;
                                        TCNT1 = 0;//計數器清零
                                else Set();
                        break;
                case alarm_set://模式3,鬧鐘設置
                         if(time_10ms_ok)
                                 time_10ms_ok = 0;
                                        as = ss;
                                        am = sm;
                                        ah = sh;
                                else Set();
                        break;
                default: pattern = time_display; break;
void Set(void)
        lcd_write_char(4,0,num[sh/10]);
        lcd_write_char(5,0,num[sh%10]);
        lcd_write_char(7,0,num[sm/10]);
        lcd_write_char(8,0,num[sm%10]);
        lcd_write_char(10,0,num[ss/10]);
        lcd_write_char(11,0,num[ss%10]);
         switch(set)
                 case set_h://調整小時位
                        if(key_sign == key2)
                                sh = (++sh)%24;
                        else if(key_sign == key3) set = set_m;
                        break;
                case set_m://調整分鐘位
                                sm = (++sm)%60;
                        else if(key_sign == key3) set = set_s;
                        break;
                case set_s://調整秒位
                                ss = (++ss)%60;
                        else if(key_sign == key3) set = set_h;
                        break;
                 default: set = set_h; break;
void time(void)
        lcd_write_char(4,0,num[ch/10]);
        lcd_write_char(5,0,num[ch%10]);
        lcd_write_char(7,0,num[cm/10]);
        lcd_write_char(8,0,num[cm%10]);
        lcd_write_char(10,0,num[cs/10]);
        lcd_write_char(11,0,num[cs%10]);
void Alarm(void)
         if(count2 == 1000) time_10s_ok = 1;
         if((ch == ah) && (cm == am) && (cs == as))
                PORTA &= ~(1<<PA7);
                count2 =0;
                time_10s_ok = 0;
        else if(time_10s_ok) PORTA |= (1<<PA7);
void time_send(void)
         if((cs == 0)&&(cm == 0)) ;
void main(void)//主函數
         cpu_init();
        time_display_init();
                 if(count1 == 100)//實時時間計時
                          cs++;
                        count1 = 0;
                        if(cs == 60)
                                 cm++;
                                cs = 0;
                                if(cm == 60)
                                          ch++;
                                         cm = 0;
                                        if(ch == 24) ch = 0;
                 Pattern();
                Alarm();
ID:962686 發表于 2021-9-2 19:45 | 只看該作者
我測試了一下,發現我的定時器不精準,但是我用8M的外部時鐘頻率,按道理我用64預分頻那么通過計算:8000000/64=125000—>那么我用ctc比較匹配的話。把計數上限OCR1A設置為1250不就是10ms了嗎???但是實時為什么會慢那么多
ID:624769 發表于 2021-9-2 20:26 | 只看該作者
AVR沒用過不清楚,但是,預分頻能影響到定時器么?很多單片機,定時器有專門的寄存器來選擇到底用主頻預分頻,還是主頻,還是定時器的專用分頻器,你最好先確認一下這個。
ID:962686 發表于 2021-9-2 20:35 | 只看該作者
188610329 發表于 2021-9-2 20:26
AVR沒用過不清楚,但是,預分頻能影響到定時器么?很多單片機,定時器有專門的寄存器來選擇到底用主頻預分 ...
我定1s誤差很小,但是到10ms就很大了。我不知道是什么原因,小白菜一個請求大佬指教一下
ID:962686 發表于 2021-9-2 21:09 | 只看該作者
wzl570 發表于 2021-9-2 19:45
我測試了一下,發現我的定時器不精準,但是我用8M的外部時鐘頻率,按道理我用64預分頻那么通過計算:800000 ...
我設置1s(count1 == 100)誤差不大,但是10s(count2==1000)就是11秒了
ID:419968 發表于 2021-9-2 22:30 | 只看該作者
設置成8分頻 8000000/64=1000000 OCR1A=9999
如64分頻 OCR1a=1249 誤差大
ID:624769 發表于 2021-9-3 00:34 | 只看該作者
wzl570 發表于 2021-9-2 21:09
做兩個嘗試,
1,不預分頻,看看誤差大不大。
2,既然你都測試10秒了,索性干脆點, 測試1分鐘(6000),5分鐘(30000),看看誤差到底是等比,還是等差。等比,就是定時器或者說時鐘有問題,等差,就是你程序或者中斷本身有問題。到時候再分析。
ID:962686 發表于 2021-9-3 11:09 | 只看該作者
adject 發表于 2021-9-2 22:30
請問一下誤差是硬件問題嗎
ID:962686 發表于 2021-9-3 11:11 | 只看該作者
188610329 發表于 2021-9-3 00:34
做兩個嘗試,
1,不預分頻,看看誤差大不大。
2,既然你都測試10秒了,索性干脆點, 測試1分鐘(6000) ...
我只知道他有一點誤差,但是具體多少我不知道怎么測試。請問我該如何得到精準一點的誤差
ID:962686 發表于 2021-9-4 13:29 | 只看該作者
求大佬指點啊
