查看: 3056|回復(fù): 2
關(guān)于stm32f103C8t6與esp8266 連接失敗的問題求助
ID:955316 發(fā)表于 2021-8-14 17:01 | 顯示全部樓層 |閱讀模式
遇到的問題就是  串口調(diào)試助手 出現(xiàn)  0 AT  沒有得到esp8266的響應(yīng)。
部分代碼如下:
void ESP8266_Init(void)
        GPIO_InitTypeDef GPIO_Initure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
        //ESP8266復(fù)位引腳
        GPIO_Initure.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_Initure.GPIO_Pin = GPIO_Pin_14;                                        //GPIOC14-復(fù)位
        GPIO_Initure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOC, &GPIO_Initure);
        GPIO_WriteBit(GPIOC, GPIO_Pin_14, Bit_RESET);
        delay_ms(250);
        GPIO_WriteBit(GPIOC, GPIO_Pin_14, Bit_SET);
        delay_ms(500);
        ESP8266_Clear();
        UsartPrintf(USART_DEBUG, "0. AT\r\n");
        while(ESP8266_SendCmd("AT\r\n", "OK"))
                delay_ms(500);
        UsartPrintf(USART_DEBUG, "1. RST\r\n");
        ESP8266_SendCmd("AT+RST\r\n", "");
          delay_ms(500);
        ESP8266_SendCmd("AT+CIPCLOSE\r\n", "");
          delay_ms(500);
        UsartPrintf(USART_DEBUG, "2. CWMODE\r\n");
        while(ESP8266_SendCmd("AT+CWMODE=1\r\n", "OK"))
                delay_ms(500);
        UsartPrintf(USART_DEBUG, "3. AT+CWDHCP\r\n");
        while(ESP8266_SendCmd("AT+CWDHCP=1,1\r\n", "OK"))
                delay_ms(500);
        UsartPrintf(USART_DEBUG, "4. CWJAP\r\n");
        while(ESP8266_SendCmd(ESP8266_WIFI_INFO, "GOT IP"))
                delay_ms(500);
        UsartPrintf(USART_DEBUG, "5. CIPSTART\r\n");
        while(ESP8266_SendCmd(ESP8266_ONENET_INFO, "CONNECT"))
                delay_ms(500);
        UsartPrintf(USART_DEBUG, "6. ESP8266 Init OK\r\n");
有沒有大佬講解一下,為什么會這樣,我打算將溫濕度傳到云,再通過手機(jī)app檢測。。出師未捷身先死,第一步就失敗啦,stm32與esp8266沒有成功連接。大哭,以下是我的工程,有沒有大佬幫忙看看,不勝感激。
Template _3.7z
212.79 KB, 下載次數(shù): 6
ID:584195 發(fā)表于 2021-8-14 20:31 | 顯示全部樓層
你先用串口助手,檢查一下串口工作正常不正常,兩邊的波特率對不對,先用串口轉(zhuǎn)TTL把兩邊的東西調(diào)通,再組裝到一起來調(diào)試!
ID:878236 發(fā)表于 2021-8-14 23:36 | 顯示全部樓層
上電之后先延時等待esp8266初始化結(jié)束 然后再讓單片機(jī)發(fā)指令
比如
  1. "AT\r\n"
  1. "AT+RST\r\n"
