查看: 3265|回復: 6
這個NTC測溫的單片機程序有什么問題嗎?
ID:709761 發表于 2021-8-12 08:03 | 顯示全部樓層 |閱讀模式
#include "STC15.h"
#include "intrins.h"
#include <stdio.h>
#define uchar   unsigned  char
#define uint    unsigned int
#define ADC_POWER   0x80            //ADC電源控制位
#define ADC_FLAG    0x10            //ADC完成標志
#define ADC_START   0x08            //ADC起始控制位
#define ADC_SPEEDLL 0x00            //540個時鐘
#define ADC_SPEEDL  0x20            //360個時鐘
#define ADC_SPEEDH  0x40            //180個時鐘
#define ADC_SPEEDHH 0x60            //90個時鐘
uchar code adwd[101] = {
        0xBD,0xBB,0xB9,0xB6,0xB4,0xB2,0xAF,0xAD,0xAA,0xA8,
        0xA5,0xA3,0xA0,0x9D,0x9B,0x98,0x96,0x93,0x91,0x8E,
        0x8B,0x89,0x86,0x84,0x81,0x7F,0x7C,0x7A,0x77,0x75,
        0x72,0x70,0x6E,0x6B,0x69,0x67,0x65,0x62,0x60,0x5E,
        0x5C,0x5A,0x58,0x56,0x54,0x52,0x50,0x4E,0x4C,0x4B,
        0x49,0x47,0x46,0x44,0x42,0x41,0x3F,0x3E,0x3C,0x3B,
        0x39,0x38,0x37,0x35,0x34,0x33,0x32,0x30,0x2F,0x2E,
        0x2D,0x2C,0x2B,0x2A,0x29,0x28,0x27,0x26,0x25,0x24,
        0x23,0x22,0x22,0x21,0x20,0x1F,0x1F,0x1E,0x1D,0x1D,
        0x1C,0x1B,0x1B,0x1A,0x19,0x19,0x18,0x18,0x17,0x17,
        0x16
};//采樣AD 從大到小
uchar code wd[101] = {
        0,1,2,3,4,5,6,7,8,9,
        10,11,12,13,14,15,16,17,18,19,
        20,21,22,23,24,25,26,27,28,29,
        30,31,32,33,34,35,36,37,38,39,
        40,41,42,43,44,45,46,47,48,49,
        50,51,52,53,54,55,56,57,58,59,
        60,61,62,63,64,65,66,67,68,69,
        70,71,72,73,74,75,76,77,78,79,
        80,81,82,83,84,85,86,87,88,89,
        90,91,92,93,94,95,96,97,98,99,
        100
};//AD對應的溫度值 從低到高
void UartInit(void)                //115200bps@12.000MHz
        SCON = 0x50;                //8位數據,可變波特率
        AUXR |= 0x40;                //定時器時鐘1T模式
        AUXR &= 0xFE;                //串口1選擇定時器1為波特率發生器
        TMOD &= 0x0F;                //設置定時器模式
        TL1 = 0xE6;                //設置定時初始值
        TH1 = 0xFF;                //設置定時初始值
        ET1 = 0;                //禁止定時器%d中斷
        TR1 = 1;                //定時器1開始計時
軟件延時
void Delay(uint n)
    uint x;
    while (n--)
        x = 5000;
        while (x--);
/*發送一個字節*/
void SendData(uchar ch)
    SBUF = ch;                 //寫數據到UART數據寄存器
                while(TI == 0);
                TI = 0;
/*發送字符串*/
void SendString(uchar *s)
    while (*s)                  //檢測字符串結束標志
        SendData(*s++);         //發送當前字符
初始化ADC
void InitADC()
        P1ASF = 0x01;           //設置P1.0口為AD口
        ADC_RES = 0;              //清除結果寄存器高8位
        ADC_CONTR = ADC_POWER ;  //ADC上電
        Delay(2);
uchar  adc()
        uchar ad;
        ADC_CONTR = 0x88;     //ADC上電并啟動(轉換完成自動關閉ADC,每次轉換都要先啟動ADC)
        Delay(2);
        while (!(ADC_CONTR & ADC_FLAG));//等待ADC轉換完成
        ADC_CONTR &= ~ADC_FLAG;         //清零ADC標志位
        ad=ADC_RES;       //得到高8位
  return  ad;
uint htd(uint a)//十六進制轉十進制
    uint b,c;
b=a%10;
c=b;
a=a/10;
b=a%10;
c=c+(b<<4);
a=a/10;
b=a%10;
c=c+(b<<8);
a=a/10;
b=a%10;
c=c+(b<<12);
return c;
uchar y,j;
    UartInit();                     //初始化串口
    InitADC();                      //初始化ADC
    while (1)
                        y=adc();
            for(j=0; j<100; j++)        //查溫度表
             if(y>=adwd[j]) //AD數組從大到小逐次比較
                                                 break;
                        SendData(htd(wd[j]));//溫度值轉十進制發送
            Delay(400);
ID:94031 發表于 2021-8-12 09:13 | 顯示全部樓層
硬件圖也不告訴大家,不好分析。
ID:277550 發表于 2021-8-12 10:15 | 顯示全部樓層
樓主應該先說自己遇到的情況,不然要人家制作、測試
ID:161164 發表于 2021-8-12 12:46 | 顯示全部樓層
不明白如何"溫度值轉十進制發送"
如一數值:0xF0F0(61680)
htd(0xF0F0) => 0x1680(5760)
完全不是同一樣東西
十進制和十六進制只是給人看的
單片機看到的只是二進制
SendData()是發送字符串用的
htd的反回類型是uint即兩個uchar
如SendData(0x1680),電腦收到的會是下面兩個字符
建議寫法如下
  1. void main()
  2. {
  3.         uchar y,j;
  4.         uchar Show[10];//<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
  5.         UartInit();                     //初始化串口
  6.         InitADC();                      //初始化ADC
  7.         while (1)
  8.         {
  9.                 y=adc();
  10.                 for(j=0; j<100; j++)        //查溫度表
  11.                 {
  12.                         if(y>=adwd[j]) //AD數組從大到小逐次比較
  13.                                 break;
  14.                 }
  15.                 sprintf(Show,"%u",wd[j]);//<<<<<<<<<<
  16.                 SendData(Show);
  17.                 Delay(400);
  18.         }
  19. }
ID:401564 發表于 2021-8-13 00:02 | 顯示全部樓層
什么情況也不說,什么電路也沒有,NTC在串聯電阻的什么位置也不知道
代碼往這一放,就問"這代碼有沒有問題?"
我想幫你,我還自己焊個電路,說不定NTC位置不對,我還得換一下,完了我還得建立一個工程,燒錄驗證一下......
兄弟,上論壇叫別人幫忙好歹有個態度吧
比如說,我這代碼編譯不成功或者NTC溫度和實際溫度有誤差,要么是無法燒錄什么的
你不能像那某個網友一樣來消遣我們的熱情呀
ID:128516 發表于 2021-8-13 11:24 | 顯示全部樓層
這個要查表
ID:94657 發表于 2021-8-13 15:02 | 顯示全部樓層
ntc測溫,嚴謹一點是需要知道B值的,再通過B值、AD值去推算真實溫度
