查看: 2209|回復: 4
求助各位大神,幫忙看一下為什么仿真時12864亂碼
ID:958228 發表于 2021-8-2 10:47 | 顯示全部樓層 |閱讀模式
程序:
#include<reg51.h>
#include<intrins.h>
sbit RST=P2^0;
sbit E=P2^1;
sbit wr=P2^2;
sbit rs=P2^3;
sbit CS2=P2^4;
sbit CS1=P2^5;
uchar code hanzi_ZM[][32]={
/*--  文字:  壯  --*/
/*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
0x10,0x04,0x10,0x04,0x10,0x04,0x12,0x04,0x14,0x04,0x14,0x04,0xD0,0x7F,0x18,0x04,
0x14,0x04,0x12,0x04,0x11,0x04,0x10,0x04,0x10,0x04,0x10,0x04,0x90,0x3F,0x10,0x00,
/*--  文字:  麗  --*/
0x00,0x00,0xFF,0x7F,0x00,0x00,0x00,0x00,0x7C,0x1F,0x44,0x11,0x44,0x11,0x44,0x11,
0x4C,0x13,0x54,0x15,0x54,0x15,0x44,0x11,0x44,0x11,0x44,0x11,0x54,0x15,0x24,0x09,
/*--  文字:  7  --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x7E,0x00,0x42,0x00,0x20,0x00,0x20,0x00,0x10,0x00,
0x10,0x00,0x08,0x00,0x08,0x00,0x08,0x00,0x08,0x00,0x08,0x00,0x00,0x00,0x00,0x00,
/*--  文字:  0  --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x00,0x24,0x00,0x42,0x00,0x42,0x00,0x42,0x00,
0x42,0x00,0x42,0x00,0x42,0x00,0x42,0x00,0x24,0x00,0x18,0x00,0x00,0x00,0x00,0x00,
/*--  文字:  年  --*/
0x08,0x00,0x08,0x00,0xF8,0x3F,0x04,0x01,0x04,0x01,0x02,0x01,0xF8,0x1F,0x08,0x01,
0x08,0x01,0x08,0x01,0xFF,0x7F,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,
/*--  文字:     --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/*--  文字:     --*/
/*--  文字:  奮  --*/
0x80,0x00,0x80,0x00,0xFE,0x3F,0x40,0x01,0x20,0x02,0x10,0x04,0x0C,0x18,0x03,0x60,
0xF8,0x0F,0x88,0x08,0x88,0x08,0xF8,0x0F,0x88,0x08,0x88,0x08,0xF8,0x0F,0x08,0x08,
/*--  文字:  斗  --*/
0x00,0x02,0x20,0x02,0x40,0x02,0x40,0x02,0x08,0x02,0x10,0x02,0x10,0x02,0x00,0x02,
0x00,0x7F,0xFE,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,
/*--  文字:  新  --*/
0x08,0x00,0x10,0x20,0xFE,0x1E,0x00,0x02,0x44,0x02,0x28,0x02,0xFF,0x7E,0x10,0x12,
0x10,0x12,0xFE,0x12,0x10,0x12,0x54,0x12,0x92,0x12,0x11,0x11,0x14,0x11,0x88,0x10,
/*--  文字:  時  --*/
0x00,0x10,0x00,0x10,0x3E,0x10,0x22,0x10,0xA2,0x7F,0x22,0x10,0x22,0x10,0x3E,0x10,
0x22,0x11,0x22,0x12,0x22,0x12,0x22,0x10,0x3E,0x10,0x22,0x10,0x00,0x14,0x00,0x08,
/*--  文字:  代  --*/
0x10,0x09,0x10,0x11,0x10,0x11,0x08,0x01,0x08,0x7D,0xEC,0x03,0x0C,0x01,0x0A,0x02,
0x09,0x02,0x08,0x02,0x08,0x04,0x08,0x44,0x08,0x48,0x08,0x50,0x08,0x60,0x08,0x40,
uchar code shuzi_ZM[][16]={
/*--  文字:  1  --*/
/*--  宋體12;  此字體下對應的點陣為:寬x高=8x16   --*/
0x00,0x00,0x00,0x10,0x1C,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x7C,0x00,0x00,
/*--  文字:  9  --*/
0x00,0x00,0x00,0x1C,0x22,0x42,0x42,0x42,0x62,0x5C,0x40,0x40,0x24,0x18,0x00,0x00,
/*--  文字:  4  --*/
0x00,0x00,0x00,0x20,0x30,0x30,0x28,0x24,0x24,0x22,0xFE,0x20,0x20,0xF8,0x00,0x00,
/*--  文字:  9  --*/
/*--  文字:  -  --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/*--  文字:  2  --*/
0x00,0x00,0x00,0x3C,0x42,0x42,0x42,0x40,0x20,0x10,0x08,0x04,0x42,0x7E,0x00,0x00,
/*--  文字:  0  --*/
0x00,0x00,0x00,0x18,0x24,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x24,0x18,0x00,0x00,
/*--  文字:  1  --*/
/*--  文字:  9  --*/
/*--  文字:  c  --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x44,0x02,0x02,0x02,0x44,0x38,0x00,0x00,
/*--  文字:  o  --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x42,0x42,0x42,0x42,0x42,0x3C,0x00,0x00,
/*--  文字:  m  --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0x92,0x92,0x92,0x92,0x92,0xB7,0x00,0x00,
/*--  文字:  e  --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x42,0x42,0x7E,0x02,0x42,0x3C,0x00,0x00,
/*--  文字:     --*/
/*--  文字:  o  --*/
/*--  文字:  n  --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3B,0x46,0x42,0x42,0x42,0x42,0xE7,0x00,0x00,
void delayms(uint x)
uchar i;
while(x--)
for(i=0;i<123;i++);
void writeData(uchar x)
  rs=1;
  wr=0;
  P0=x;
  _nop_();
  E=1;
   _nop_();
  E=0;
void writeCon(uchar x)
  rs=0;
  wr=0;
  P0=x;
  _nop_();
  E=1;
   _nop_();
  E=0;
void lcd_xy(uchar x,y)
if(y<64)
  CS1=1;
  CS2=0;
  writeCon(0X40|y);
  CS1=0;
  CS2=1;
  writeCon(0X40|y-64);
  writeCon(0Xb8|x);
void clear()
   uint i,j;
   CS1=CS2=1;
   for(i=0;i<8;i++);
             writeCon(0xb8+i);
          writeCon(0X40);
          for(j=0;j<64;j++)
          writeCon(0X00);
void init12864()
  RST=0;
  delayms(15);
  RST=1;
  writeCon(0X3e);
  writeCon(0X40);
  writeCon(0Xb8);
  writeCon(0Xc0);
  writeCon(0X3f);
void writeHZ(uchar x,y,uchar code*p)
  uint t=0;
  uchar i,j;
  for(i=x;i<x+2;i++)
          for(j=y;j<y+6;j++)
         lcd_xy(i,j);
         writeData(p[t++]);
void writeAscii(uchar x,y,uchar code*p)
  uint t=0;
  uchar i,j;
  for(i=x;i<x+2;i++)
          for(j=y;j<y+6;j++)
         lcd_xy(i,j);
         writeData(p[t++]);
  init12864();
  clear();
  writeAscii(0,16,shuzi_ZM[0]);
  writeAscii(0,24,shuzi_ZM[1]);
  writeAscii(0,32,shuzi_ZM[2]);
  writeAscii(0,40,shuzi_ZM[3]);
  writeAscii(0,48,shuzi_ZM[4]);
  writeAscii(0,56,shuzi_ZM[5]);
  writeAscii(0,64,shuzi_ZM[6]);
  writeAscii(0,72,shuzi_ZM[7]);
  writeAscii(0,80,shuzi_ZM[8]);
  writeHZ(2,16,shuzi_ZM[0]);
  writeHZ(2,32,shuzi_ZM[1]);
  writeHZ(2,48,shuzi_ZM[2]);
  writeHZ(2,64,shuzi_ZM[3]);
  writeHZ(2,80,shuzi_ZM[4]);
  writeHZ(4,16,shuzi_ZM[5]);
  writeHZ(4,32,shuzi_ZM[6]);
  writeHZ(4,48,shuzi_ZM[7]);
  writeHZ(4,64,shuzi_ZM[8]);
  writeHZ(4,80,shuzi_ZM[9]);
  writeAscii(6,16,shuzi_ZM[9]);
  writeAscii(6,24,shuzi_ZM[10]);
  writeAscii(6,32,shuzi_ZM[11]);
  writeAscii(6,40,shuzi_ZM[12]);
  writeAscii(6,48,shuzi_ZM[13]);
  writeAscii(6,56,shuzi_ZM[14]);
  writeAscii(6,64,shuzi_ZM[15]);
  while(1);
仿真:
ID:584814 發表于 2021-8-2 15:04 | 顯示全部樓層
從畫面上看像是是行列顛倒了
ID:939710 發表于 2021-8-2 16:58 | 顯示全部樓層
這個屏是分左右屏的  x坐標范圍只能到0-63
ID:958228 發表于 2021-8-3 07:51 | 顯示全部樓層
lishengaha 發表于 2021-8-2 16:58
設置的左半屏小于64,,范圍就是在0-63
ID:691028 發表于 2021-8-3 13:07 | 顯示全部樓層
取模方向改一下就好了
