查看: 1727|回復: 3
STM32 IED DHT11溫濕度傳感器程序問題
ID:938707 發表于 2021-7-31 21:03 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
uint8_t Rh_byte1,Rh_byte2;
uint8_t Temp_byte1,Temp_byte2;
uint16_t sum;
uint8_t check=0;
GPIO_InitTypeDef GPIO_InitStruct;
void set_gpio_output(void)
        GPIO_InitStruct.Pin = GPIO_PIN_0;
        GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
        GPIO_InitStruct.Speed=GPIO_SPEED_FREQ_LOW;
        HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
void set_gpio_input(void)
        GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
        GPIO_InitStruct.Pull = GPIO_NOPULL;
void DHT11_start(void)
        set_gpio_output();
        HAL_GPIO_WritePin(GPIOC, GPIO_PIN_0, 0);
        HAL_Delay(24);
        set_gpio_input();
void check_response(void)
        delay_us(40);
        if(HAL_GPIO_ReadPin(GPIOC, GPIO_PIN_0) == 0)
                delay_us(80);
                if(HAL_GPIO_ReadPin(GPIOC, GPIO_PIN_0) == 1)
                        check=1;
        while(HAL_GPIO_ReadPin(GPIOC, GPIO_PIN_0)==1);
uint8_t read_data(void)
        uint8_t i=0,j;
        for(j=0;j<8;j++)
                while(!(HAL_GPIO_ReadPin(GPIOC, GPIO_PIN_0)));
                delay_us(40);
                if((HAL_GPIO_ReadPin(GPIOC, GPIO_PIN_0))==0)
                        i&= ~(1<<(7-j));
                        i|=(1<<(7-j));
                while((HAL_GPIO_ReadPin(GPIOC, GPIO_PIN_0)));
        return i;
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
          DHT11_start();
          check_response();
          Rh_byte1=read_data();
          Rh_byte2=read_data();
          Temp_byte1=read_data();
          Temp_byte2=read_data();
          sum=read_data();
          while(sum==(Rh_byte1+Rh_byte2+Temp_byte1+Temp_byte2))
                  printf("溫度是:%d.%d C ",Temp_byte1,Temp_byte2);
                  HAL_Delay(2);
                  printf("濕度是:%d.%d H\r\n",Rh_byte1,Rh_byte2);
                  HAL_GPIO_TogglePin(D1_GPIO_Port, D1_Pin);
                  HAL_Delay(1000);
ID:938707 發表于 2021-7-31 21:05 | 只看該作者
我的問題是單片機復位一次測一次溫濕度,不能連續測,只有最開始的那次測了,后面的但是重復最開始測的那個值
ID:938707 發表于 2021-7-31 21:15 | 只看該作者
file:///C:/Users/Administrator/Desktop/QQ%E6%88%AA%E5%9B%BE20210731211426.png
這是沒復位的現象
ID:938707 發表于 2021-7-31 21:18 | 只看該作者
file:///C:/Users/Administrator/Desktop/QQ%E6%88%AA%E5%9B%BE20210731211705.png
這是按了復位的現象
