查看: 7902|回復: 3
ccs編譯錯誤msp4305529 error #10056: symbol "main" redefined: first def
ID:931208 發表于 2021-7-30 16:48 | 顯示全部樓層 |閱讀模式
下面是復制的console內容
<Linking>
error #10056: symbol "main" redefined: first defined in "./main.obj"; redefined in "./oled project/oled.obj"
remark #10372-D: (ULP 4.1) Detected uninitialized Port A in this project. Recommend initializing all unused ports to eliminate wasted current consumption on unused pins.
error #10010: errors encountered during linking; "oled.out" not built
remark #10372-D: (ULP 4.1) Detected uninitialized Port B in this project. Recommend initializing all unused ports to eliminate wasted current consumption on unused pins.
remark #10372-D: (ULP 4.1) Detected uninitialized Port C in this project. Recommend initializing all unused ports to eliminate wasted current consumption on unused pins.
remark #10372-D: (ULP 4.1) Detected uninitialized Port D in this project. Recommend initializing all unused ports to eliminate wasted current consumption on unused pins.
>> Compilation failure
makefile:188: recipe for target 'oled.out' failed
gmake[1]: *** [oled.out] Error 1
makefile:184: recipe for target 'all' failed
gmake: *** [all] Error 2
**** Build Finished ****
圖片2,3是路徑,我都包含進去了的,然后工程里也沒有標紅,但是就是有錯誤
網上也搜過了,試了很多辦法就是不行,官網有類似的,但是也沒看出來是咋解決的。
圖3
圖3
圖2
圖2
圖1
圖1
ID:883242 發表于 2021-7-30 18:02 | 顯示全部樓層
main.c和oled.c里面都有main()
ID:585147 發表于 2021-8-2 13:54 | 顯示全部樓層
這2個文件重復定義了main,提示很明確了
ID:130230 發表于 2021-8-2 14:08 | 顯示全部樓層
第一句不是已經說了有2個main.c了么。。
