查看: 3796|回復: 11
51單片機使用mpu6050的的dmp 輸出的Yaw一直亂飄是怎么一回事?
ID:928549 發表于 2021-7-24 10:49 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<STC8A.h>
#include<intrins.h>
#include<MPU_I2C.h>
#include<math.h>
#include<DMP.h>
#include<test.h>
#define q30 1073741824.0f;
uchar dmpdatas[42];
signed long dmpdata_group[4];
float q0 = 1.0f,q1 = 0.0f,q2 = 2.0f,q3 = 0.0f;//四元數
float Yaw,Pitch,Roll,Temp;        //加載并配置DMP 數字運動處理引擎
uchar dmpInitialize(void)
        uchar hwRevision,otpValid,mpuIntStatus;
        uchar xgOffsetTC,ygOffsetTC,zgOffsetTC;
        uint fifoCount;
        I2C_writebit(PWR_MGMT_1,7,1);//復位MPU6050
        Delay10ms();
        I2C_writebit(PWR_MGMT_1,6,0);
        I2C_send(0x6D,0x70);
        I2C_send(0x6E,0x06);
        I2C_Recv_t(0x6F,&hwRevision);//讀取
        //hwRevision = I2C_Recv(0x6f);
        I2C_send(0x6D,0); //重置內存bank選擇
        readBit(0x00,0,&otpValid); //讀取otp bank 有效標志
        readBits(0x00,6,6,&xgOffsetTC); //讀取陀螺儀偏置TC值 x
        readBits(0x01,6,6,&ygOffsetTC);  //讀取陀螺儀偏置TC值 y
        readBits(0x02,6,6,&zgOffsetTC);  //讀取陀螺儀偏置TC值 z
        I2C_writebit(USER_CTRL,1,1); //I2C總線主控復位
        Delay10ms();        if ((loadfirmware()) == 0) return 0;//加載dmp代碼到內存
        //loadfirmware();
        //        uart1sendstr("TEST\r\n");
        if ((loadcfgupd()) ==0) return 0;//配置dmp
        I2C_writebits(PWR_MGMT_1,2,3,0x03); //設置脈沖源z陀螺
        I2C_send(0x38,0x12);//設置DMP和FIFO_OFLOW啟用中斷
        I2C_send(0x19,4);//設置采樣率為200 hz  (1khz / (1 + 4) = 200 Hz)
        I2C_writebits(0x1A,5,3,0x1); //設置外部幀同步TEMP_UT_L[0]
        I2C_writebits(0x1A,2,3,0x03);//設置DLPF帶寬42赫茲
        I2C_writebits(0x1B,4,2,0x03);//陀螺儀靈敏度+-2000
        I2C_send(0x70,0x03); //設置DMP配置字節
        I2C_send(0x71,0x00); //設置DMP配置字節???
        I2C_writebit(0x00,0,0);//清除otp bank 標志
  I2C_writebits(0x00,6,6,xgOffsetTC); //清除陀螺儀偏置TC值 x
        I2C_writebits(0x01,6,6,ygOffsetTC);  //清除陀螺儀偏置TC值 y
        I2C_writebits(0x02,6,6,zgOffsetTC);  //清除陀螺儀偏置TC值 z  dmp_update(0);
        dmp_update(5);
        I2C_writebit(0x6A,2,1); //復位fifo
        fifoCount = getFIFOcount(); //讀取FIFO計數
        I2C_send(0x1F,2); //運動檢測閾值設置為2
        I2C_send(0x21,156); //零運動檢測閾值為156 (是否修改)
        I2C_send(0x20,80);//設置運動檢測持續時間至80
        I2C_send(0x22,0);//設置運動檢測時間0
        I2C_writebit(0x6A,6,1); //使能fifo
        I2C_writebit(0x6A,7,1); //使能dmp
        I2C_writebit(0x6A,3,1); //復位dmp  dmp_update(12);
  dmp_update(17);
  dmp_update(28);
        while ((fifoCount = getFIFOcount()) < 3 ); //等待fifo計數大于2
        I2C_writebit(0x6A,2,1);//復位fifo
        I2C_Recv_t(0x3A,&mpuIntStatus);//讀取中斷狀態
        //mpuIntStatus = I2C_Recv(0x3A);
//        if(dmp_update(35)==0) return 0;        //最后更新6/7(函數未知)dmpUpdates數組第六行
  dmp_update(35);
//        if(dmp_update(40)==0) return 0;        //最后更新7/7(函數未知)dmpUpdates數組第七行
  dmp_update(40);
  I2C_writebit(0x6A,7,0); //禁用dmp
        return 1;
uchar getDevideID(void)    //驗證id
        uchar b = 0;
        readBits(0x75,6,6,&b);
        return b== 0x34;
void init_MPU6050(void)
        I2C_writebits(PWR_MGMT_1,2,3,0x01); //電源管理
        I2C_send(GYRO_CONFIG, 0x00);
        I2C_send(ACCEL_CONFIG, 0x01);
        I2C_writebit(PWR_MGMT_1,6,1);    //睡眠狀態
        if (getDevideID())
        {                if(!(dmpInitialize()))
                        while(1);
        }        I2C_writebit(0x6A,2,1); //復位fifo
void read_FIFO(void)
        uchar zd;
        uint i;
        i = getFIFOcount();//讀取fifo計數
        I2C_Recv_t(0x3A,&zd);//讀取中斷狀態        //uart1sendstr("ddd\r\n");
        if ((zd & 0x10)||i>=840) //判斷fifo是否溢出
                uart1sendstr("yichu\r\n");
        else if (zd &0x02)
                uart1sendstr("eee\r\n");
                while (i<42) i=getFIFOcount();
                if (readdmp(dmpdatas)) //讀取fifo數據
                        dmpdata_group[0] = ((long)dmpdatas[0] << 24) | ((long)dmpdatas[1] << 16) | ((long)dmpdatas[2] << 8) | dmpdatas[3];
                  dmpdata_group[1] = ((long)dmpdatas[4] << 24) | ((long)dmpdatas[5] << 16) | ((long)dmpdatas[6] << 8) | dmpdatas[7];
      dmpdata_group[2] = ((long)dmpdatas[8] << 24) | ((long)dmpdatas[9] << 16) | ((long)dmpdatas[10] << 8) | dmpdatas[11];
      dmpdata_group[3] = ((long)dmpdatas[12] << 24) | ((long)dmpdatas[13] << 16) | ((long)dmpdatas[14] << 8) | dmpdatas[15];
                  q0 = (float)dmpdata_group[0] / q30;                 //取四元數
                        //q0 = 131.1f;
            q1 = (float)dmpdata_group[1] / q30;
            q2 = (float)dmpdata_group[2] / q30;
            q3 = (float)dmpdata_group[3] / q30;
                        //                Roll = Atan2(2 *(Y * Z + W * X) , W * W -X * X -Y * Y + Z * Z)
                  Roll = atan2(2 * q2 * q3 + 2 * q0 * q1, -2 * q1 * q1 - 2 * q2* q2 + 1)* 42.975;
                        //                Pitch = asin(-2 * (X * Z - W * Y))
                  Pitch = asin(-2 * q1 * q3 + 2 * q0* q2)* 42.975;
                        //                Yaw   = atan2(2 * (X * Y + W * Z) ,W * W + X * X - Y * Y - Z * Z)
                  Yaw = atan2(2*(q1*q2 + q0*q3),q0*q0+q1*q1-q2*q2-q3*q3) * 42.975;                                        }
ID:928549 發表于 2021-7-24 10:50 | 只看該作者
void Delay10ms()                //@24.000MHz
        unsigned char i;
        uint j;
for (j=0;j<1000;j++)
        _nop_();
        _nop_();
        i = 57;
        while (--i);
uchar loadfirmware(void)
        uint datanum = 0; //dmp固件寫入標志
        uchar ye,i,j;
        uchar bank = 0;
        uchar addr = 0;
        for (;bank<8;bank++)
                if(bank ==7)
                        i=8;
                        i=16;
                for (ye=0;ye<i;ye++)
                        I2C_send(0x6d,bank);
                        I2C_send(0x6e,addr);
                        MPU_I2C_start();
                        MPU_I2C_SendData(SlaveAddress);
            MPU_I2C_RecvACK();
                        MPU_I2C_SendData(0x6f);
                        MPU_I2C_RecvACK();
            //uart1sendstr("TEST\r\n");
                        for (j=0;j<16;j++)
                                MPU_I2C_SendData(dmpmemorydata[datanum++]);
                                MPU_I2C_RecvACK();
                        addr +=16;
                        MPU_STOP();
        I2C_send(0x6d,7);
        MPU_I2C_start();
        MPU_I2C_RecvACK();
        MPU_I2C_RecvACK();
        for (i=0;i<9;i++)
                MPU_I2C_RecvACK();
        MPU_STOP();
        return 1;
uchar loadcfgupd(void)  //DMP設置
        uchar line; //一共寫入30行數據
        uchar bank; //頁
        uchar datacounts = 0;//DMP設置數據標志位
        uchar bytes2write; //數據長度
        uchar offset; //偏移地址
        uchar writingcounts; //數據寫入標志byte2write一同使用
        uchar special;
        for (line=0;line<30;line++)
                bank = dmpcfgupddata[datacounts++];
                offset = dmpcfgupddata[datacounts++];
                bytes2write = dmpcfgupddata[datacounts++];
                I2C_send(0x6e,offset);
          MPU_I2C_start();
          MPU_I2C_RecvACK();
                MPU_I2C_RecvACK();
                for (writingcounts=0;writingcounts<bytes2write;writingcounts++)
                        MPU_I2C_SendData(dmpcfgupddata[datacounts++]);
                        MPU_I2C_RecvACK();
                if(0 == bytes2write) //?????
                        special = dmpcfgupddata[datacounts++];
                        if (0x01 == special)
                                I2C_send(0x38,0x32);
                                return 0;
        MPU_STOP();
        return 1;
/*最后更新*/
uchar dmp_update(uchar datacounts)
        uchar writingcounts,bank,offset,bytes2write;
        bank = dmpUpdates[datacounts++];
        offset = dmpUpdates[datacounts++];
        MPU_I2C_start();
        MPU_I2C_RecvACK();
        MPU_I2C_RecvACK();
                MPU_I2C_SendData(dmpcfgupddata[datacounts++]);//寫入DMP配置數據
                MPU_I2C_RecvACK();
        MPU_STOP();
        return 1;
/*讀取FIFO計數*/
uint getFIFOcount()
                uchar i[2];
                I2C_Recvs(0x72,2,i);
                return ((i[0]<<8)+i[1]);
uchar readdmp(uchar *Data)
                return I2C_Recvs(0x74,42,Data);
ID:928549 發表于 2021-7-24 11:29 | 只看該作者
1093562897 發表于 2021-7-24 10:50
        unsigned char i;
ID:928549 發表于 2021-7-24 14:43 | 只看該作者
圖發不出來,我描述一下,就是輸出的數據基本是錯誤的一會+50,一會-20,一會+110,又一會+20這樣的,也不像是零飄的樣子,感覺就是單純的數據錯誤
ID:928549 發表于 2021-7-24 17:34 | 只看該作者
換了一塊陀螺儀還是同樣的問題,感覺是程序的問題,但不知道哪里錯了,掙扎了好久
ID:928549 發表于 2021-7-30 15:10 | 只看該作者
求求了,有沒有大佬指導下,按照手冊重寫了代碼,(雖然發現了不少問題)但最后發現還是上次的問題還是沒有解決,嗚嗚嗚
ID:928549 發表于 2021-7-30 17:17 | 只看該作者
會不會是陀螺儀收到電磁干擾嚴重才會這樣?,但看著輸出的數據又不太像,由于電路是我的一個師兄設計的,當時也是初學者,也不排除有這個可能
ID:928549 發表于 2021-8-13 11:25 | 只看該作者
大家好,我找到問題所在了,是stc8a8k系列芯片硬件I2c有點問題,換成軟件模擬I2C就沒問題了
ID:928549 發表于 2021-8-13 11:28 | 只看該作者
這是我的測試代碼,寫的有點亂
測試部分.rar
104.75 KB, 下載次數: 47
ID:587208 發表于 2021-12-23 11:33 | 只看該作者
成長了。
ID:994053 發表于 2021-12-24 14:18 | 只看該作者
ID:493177 發表于 2021-12-27 15:52 | 只看該作者
可以加個好友探討一下6050的問題嗎
