查看: 3366|回復: 0
51單片機寫的曝光定時器C語言程序
ID:37685 發表于 2013-9-5 13:39 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "at89x52.h"
#include "intrins.h"                            //_nop_();延時函數用
#define  uchar unsigned char
#define  uint  unsigned int
uchar code discode[10]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
//共陽LED段碼表        "0"  "1"  "2"  "3"  "4"  "5"  "6"  "7"  "8"  "9"
uint disdata[2]={0,0};
/*********************延遲1ms**********************/
void delayms(uint ms)
// 延時子程序
    unsigned char i;
    while(ms--)
        for(i = 0; i <105; i++);
/********************顯示函數*********************/
void scan(uint time)
{     uint t,s;
if(time>=10)t=time/10 ;else t=0;
s=time-t*10;
   disdata[0]=t;
   disdata[1]=s;
P3=0xff;
P3_6=0;
P0=discode[disdata[0]];
delayms(5);
P3=0xff;
P3_7=0;
P0=discode[disdata[1]];
delayms(5);
P3=0xff;
/*******************顯示+延遲0.1秒************************/
void delay_scan(uint t,uint codes)
{    t=t*10;
  while(t--){
    scan(codes);
/*********************聲音函數**********************/
void beep(uint t,uint s)
{   if(s==0)s=360;
    else if(s==1) s=90;
    else if(s==2) s=30;
    else s=300;
    while(t--)
        P2_1=0  ;
        delayms(s);
        P2_1=1;
        delayms(s);
    delayms(s/6);
/****************主函數************************/
main()
uint time=0;
P1=0xFF;
scan(time);
if(P1_0==0){
delayms(5);
if(P1_0==0){
if(time<60) time++;else beep(1,1);
scan(time);
delay_scan(1,time);
if(P1_1==0){
delayms(5);
if(P1_1==0){
if(time>0) time--;else beep(1,1);
scan(time);
delay_scan(1,time);
if(P1_2==0)
    delayms(5);
    if(P1_2==0 && time>0)
    { P2_0=1;
      delay_scan(3,time);
      while(time--)
      { beep(1,2);
        P2_0=0;
      delay_scan(10,time);
       P2_0=1;
       beep(1,1);
       time=0;
    beep(1,0);
    time=0;
if(P1_3==0){
delay_scan(7,time);
if(P1_3==0){
beep(2,1);
P2_0=~P2_0;
