查看: 3011|回復: 6
PCF8563時鐘模塊顯示時間在oled上顯示有問題
ID:906945 發表于 2021-7-21 09:03 | 顯示全部樓層 |閱讀模式
我寫了這個代碼,但是不知道為什么日期無法正常顯示,其他全是正常的代碼如下
#define MAIN_Fosc   11059200L  //定義主時鐘
#include "STC8.H"
#include "OLED.h"
#include "PCF8563.h"
  P2M1 |= 0x30;        P2M0 |= 0x30;   //設置P2.4和P2.5為開漏輸出
        OLED_Init();          //對OLED屏初始化
  OLED_Fill(0x00);      //清屏
  delay_ms(1000);
  LCD_P8x16Str(0,0,"   2000-00-00 0 ");
        LCD_P8x16Str(0,2,"    12:00:00    ");
        delay_ms(10);//等待初始化完成
        I2C_init();           //IIC初始化
        EA = 1;                            //打開總中斷
  WriteRTC();
        delay_ms(20);
        {   ReadRTC();                                 //讀PCF8563時鐘值,即讀出時、分、秒
      OLED_ShowChar(5*8,0,year/10+'0');
                        OLED_ShowChar(6*8,0,year%10+'0');
                        OLED_ShowChar(8*8,0,month/10+'0');
                        OLED_ShowChar(9*8,0,month%10+'0');
                  OLED_ShowChar(11*8,0,date/10+'0');
                        OLED_ShowChar(12*8,0,date%10+'0');
                  OLED_ShowChar(14*8,0,week+'0');
                  OLED_ShowChar(4*8,2,hour/10+'0');
                        OLED_ShowChar(5*8,2,hour%10+'0');
                        OLED_ShowChar(7*8,2,minute/10+'0');
                        OLED_ShowChar(8*8,2,minute%10+'0');
                        OLED_ShowChar(10*8,2,second/10+'0');
                        OLED_ShowChar(11*8,2,second%10+'0');
                        delay_ms(50); //刷新
#ifndef __PCF8563_H_
#define __PCF8563_H_
#include "delay.h"
#include "i2c.h"
uchar        year,month,date,week,hour,minute,second;           //RTC變量,時,分,秒
引腳別名定義
sbit        SDA        = P1^4;        //定義SDA
sbit        SCL        = P1^5;        //定義SCL
#define DIS_DOT                0x20
#define DIS_BLACK        0x10
#define DIS_                0x11
#define SLAW         0xA2
#define SLAR         0xA3
uchar        tmp[7];
uchar timedate[7]={21,7,20,2,18,31,0};//年,月,日,星期,時,分,秒
功能描述:讀RTC函數
入口參數:無
返回值:無
void        ReadRTC(void)
        P_SW2 |= 0x80;                         //將EAXFR位置1,以訪問PWM在擴展RAM區的特殊功能寄存器
        I2C_Start();
        I2C_SendData(0xA2);
        I2C_RecvACK();
        I2C_SendData(0x02);
        I2C_RecvACK();
        I2C_Start();
        I2C_SendData(0xA3);
  I2C_RecvACK();
        tmp[6] =I2C_RecvData();
        second = ((tmp[6] >> 4) & 0x07) * 10 + (tmp[6] & 0x0f);//秒
        I2C_SendACK();
        tmp[5] =I2C_RecvData();
        minute = ((tmp[5] >> 4) & 0x07) * 10 + (tmp[5] & 0x0f);
        I2C_SendACK();
        tmp[4]   =I2C_RecvData();
        hour   = ((tmp[4] >> 4) & 0x03) * 10 + (tmp[4] & 0x0f);
        I2C_SendACK();
        tmp[3]   =I2C_RecvData();
        week   = tmp[3];
        I2C_SendACK();
        tmp[2]   =I2C_RecvData();
        date   = ((tmp[2] >> 4) & 0x03) * 10 + (tmp[2] & 0x0f);
        I2C_SendACK();
        tmp[1]   =I2C_RecvData();
        month   = ((tmp[1] >> 4) & 0x03) * 10 + (tmp[1] & 0x0f);
        I2C_SendACK();
        tmp[0]   =I2C_RecvData();
        year   = ((tmp[0] >> 4) & 0x03) * 10 + (tmp[0] & 0x0f);
        I2C_SendNAK();
        I2C_Stop();
        P_SW2 &= 0x7F;                             //將EAXSFR位置0,恢復訪問XRAM
功能描述:寫RTC函數
入口參數:無
返回值:無
void        WriteRTC(void)
        tmp[0] = ((timedate[0] / 10) << 4) + (timedate[0] % 10);//年
        tmp[1] = ((timedate[1] / 10) << 4) + (timedate[1] % 10);//月
        tmp[2] = ((timedate[2] / 10) << 4) + (timedate[2] % 10);//日
        tmp[3] = timedate[3];                                   //星期
        tmp[4] = ((timedate[4] / 10) << 4) + (timedate[4] % 10);//小時
        tmp[5] = ((timedate[5] / 10) << 4) + (timedate[5] % 10);//分鐘
        tmp[6] = ((timedate[6] / 10) << 4) + (timedate[6] % 10);//秒
        I2C_Start();
        I2C_SendData(SLAW);          //發送設備地址+寫命令
        I2C_RecvACK();
        I2C_SendData(0x02);          //發送存儲地址
        I2C_RecvACK();
        I2C_SendData(tmp[6]);          //設置秒值
  I2C_RecvACK();
        I2C_SendData(tmp[5]);          //設置分鐘值
        I2C_RecvACK();
        I2C_SendData(tmp[4]);          //設置小時值
        I2C_RecvACK();
        I2C_SendData(tmp[3]);          //設置星期值
  I2C_RecvACK();
        I2C_SendData(tmp[2]);          //設置日期值
        I2C_RecvACK();
        I2C_SendData(tmp[1]);          //設置月值
        I2C_RecvACK();
        I2C_SendData(tmp[0]);          //設置年值
        I2C_RecvACK();
        I2C_Stop();
#endif
#ifndef OLED_H
#define OLED_H
#include "OLEDFONT.h"
#include "delay.h"
#define  uchar    unsigned char
#define  uint   unsigned int
#define OLED_WR_CMD     0
#define OLED_WR_DAT     1
#define SIZE 16
引腳別名定義
sbit RES=P5^5;
sbit DC=P4^0;
sbit CS=P3^5;
#define  LCD_DC     DC     //OLED命令/數據選擇 H=命令 L=數據
#define  LCD_CS     CS     //OLED片選
#define XLevelL        0x00
#define XLevelH        0x10
#define XLevel         ((XLevelH&0x0F)*16+XLevelL)
#define Max_Column     128
#define Max_Row        64
#define Brightness     0xCF
#define X_WIDTH        128
#define Y_WIDTH        64
#define SPIF 0x80 //SPSTAT.7
#define WCOL 0x40 //SPSTAT.6
#define SSIG 0x80 //SPCTL.7
#define SPEN 0x40 //SPCTL.6
#define DORD 0x20 //SPCTL.5
#define MSTR 0x10 //SPCTL.4
#define CPOL 0x08 //SPCTL.3
#define CPHA 0x04 //SPCTL.2
#define SPDHH 0x00 //CPU_CLK/4
#define SPDH 0x01 //CPU_CLK/8
#define SPDL 0x02 //CPU_CLK/16
#define SPDLL 0x03 //CPU_CLK/32
* 描  述 : 硬件SPI初始化
* 入  參 : 無
* 返回值 : 無
void Init_SPI()
   P_SW1 |=0X0C;                                       //將 SPI 調整到 P3.2 P3.3 P3.4  P3.5
   SPDAT = 0;                     //初始化將SPI數據寄存器清空
   SPSTAT = SPIF | WCOL;          //清除SPI狀態位
   SPCTL = SPEN | MSTR | SSIG;    //主機模式
* 描  述 : 硬件SPI寫入一個字節,并返回一個值
* 入  參 : uchar date  uchar mode
* 返回值 : 無
uchar OLED_WrByte(uchar dat,uchar mode)
        if(mode == OLED_WR_CMD)LCD_DC = 0;
  else LCD_DC = 1;
  SPDAT = dat;                   //觸發SPI發送數據
  while (!(SPSTAT & SPIF));      //等待發送完成
  return SPDAT;                  //返回SPI數據
* 描  述 : 設置坐標
* 入  參 : x:x坐標;y:y坐標
* 返回值 : 無
void OLED_Set_Pos(uchar x, uchar y)
    OLED_WrByte((0xb0+y),OLED_WR_CMD);
    OLED_WrByte(((x&0xf0)>>4)|0x10,OLED_WR_CMD);
    OLED_WrByte((x&0x0f)|0x01,OLED_WR_CMD);
* 描  述 : LCD初始化
* 入  參 : 無
* 返回值 : 無
void OLED_Fill(uchar dat)
    uchar y,x;
    for(y=0;y<8;y++)
        OLED_WrByte(0xb0+y,OLED_WR_CMD);    //設置頁地址(0~7)
        OLED_WrByte(0x02,OLED_WR_CMD);      //設置顯示位置—列低地址
        OLED_WrByte(0x10,OLED_WR_CMD);      //設置顯示位置—列高地址
        for(x=0; x<X_WIDTH; x++)
            OLED_WrByte(dat,OLED_WR_DAT);
* 描  述 : 指定位置顯示一個字符
* 入  參 : x:列0~127;y:頁地址0~7;
* 返回值 : 無
void OLED_ShowChar(uchar x,uchar y,uchar chr)
  uchar c=0,i=0;
  c = chr-' ';                  //得到偏移后的值
  if(x > Max_Column-1)
    x = 0;
    y = y+2;
  OLED_Set_Pos(x,y);
  for(i=0; i<8; i++)OLED_WrByte(F8X16[c*16+i],OLED_WR_DAT);
  OLED_Set_Pos(x,y+1);
  for(i=0;i<8;i++)OLED_WrByte(F8X16[c*16+i+8],OLED_WR_DAT);
* 描  述 : 顯示8*16一組標準ASCII字符串
* 返回值 : 無
void LCD_P8x16Str(uchar x, uchar y,uchar ch[])
  uchar c=0,i=0,j=0;
  while (ch[j] != '\0')
    c = ch[j]-32;
    if(x>120){x=0;y++;}
    OLED_Set_Pos(x,y);
    for(i=0;i<8;i++) OLED_WrByte(F8X16[c*16+i+8],OLED_WR_DAT);
    x += 8;
    j++;
* 描  述 : 顯示漢字
* 返回值 : 無
void LCD_P16x16Ch(uchar x, uchar y, uchar N)
    uchar wm=0;
    unsigned int adder=32*N;
    OLED_Set_Pos(x , y);
    for(wm = 0;wm < 16;wm++)
        OLED_WrByte(F16x16[adder],OLED_WR_DAT);
        adder += 1;
    OLED_Set_Pos(x,y + 1);
        adder += 1;
* 描  述 : LCD初始化
* 入  參 : 無
* 返回值 : 無
void OLED_Init(void)
          Init_SPI();                 //SPI初始化
    delay_ms(10);
          LCD_CS=1;
          delay_ms(10);
    LCD_CS=0;
    delay_ms(200);
    OLED_WrByte(0xae,OLED_WR_CMD);//--turn off oled panel
    OLED_WrByte(0x00,OLED_WR_CMD);//---set low column address
    OLED_WrByte(0x10,OLED_WR_CMD);//---set high column address
    OLED_WrByte(0x40,OLED_WR_CMD);//--set start line address  Set Mapping RAM Display Start Line (0x00~0x3F)
    OLED_WrByte(0x81,OLED_WR_CMD);//--set contrast control register
    OLED_WrByte(0xcf,OLED_WR_CMD); // Set SEG Output Current Brightness
    OLED_WrByte(0xa1,OLED_WR_CMD);//--Set SEG/Column Mapping     0xa0左右反置 0xa1正常
    OLED_WrByte(0xc8,OLED_WR_CMD);//Set COM/Row Scan Direction   0xc0上下反置 0xc8正常
    OLED_WrByte(0xa6,OLED_WR_CMD);//--set normal display
    OLED_WrByte(0xa8,OLED_WR_CMD);//--set multiplex ratio(1 to 64)
    OLED_WrByte(0x3f,OLED_WR_CMD);//--1/64 duty
    OLED_WrByte(0xd3,OLED_WR_CMD);//-set display offset    Shift Mapping RAM Counter (0x00~0x3F)
    OLED_WrByte(0x00,OLED_WR_CMD);//-not offset
    OLED_WrByte(0xd5,OLED_WR_CMD);//--set display clock divide ratio/oscillator frequency
    OLED_WrByte(0x80,OLED_WR_CMD);//--set divide ratio, Set Clock as 100 Frames/Sec
    OLED_WrByte(0xd9,OLED_WR_CMD);//--set pre-charge period
    OLED_WrByte(0xf1,OLED_WR_CMD);//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock
                //OLED_WrByte(0x22,OLED_WR_CMD);
    OLED_WrByte(0xda,OLED_WR_CMD);//--set com pins hardware configuration
    OLED_WrByte(0x12,OLED_WR_CMD);
    OLED_WrByte(0xdb,OLED_WR_CMD);//--set vcomh
    OLED_WrByte(0x40,OLED_WR_CMD);//Set VCOM Deselect Level
    OLED_WrByte(0x20,OLED_WR_CMD);//-Set Page Addressing Mode (0x00/0x01/0x02)
    OLED_WrByte(0x02,OLED_WR_CMD);//
    OLED_WrByte(0x8d,OLED_WR_CMD);//--set Charge Pump enable/disable
    OLED_WrByte(0x14,OLED_WR_CMD);//--set(0x10) disable
    OLED_WrByte(0xa4,OLED_WR_CMD);// Disable Entire Display On (0xa4/0xa5)
    OLED_WrByte(0xa6,OLED_WR_CMD);// Disable Inverse Display On (0xa6/a7)
    OLED_WrByte(0xaf,OLED_WR_CMD);//--turn on oled panel
    OLED_Fill(0xff);  //初始清屏
    OLED_Set_Pos(0,0);
#endif
#ifndef __I2C_H
#define __I2C_H
#include "delay.h"
引腳別名定義
//sbit        SDA        = P2^4;           //定義SDA
//sbit        SCL        = P2^5;           //定義SCL
void        I2C_Wait(void)
        while(!(I2CMSST&0x40));    //等待IIC主機狀態寄存器的中斷標志位為1
        I2CMSST&=0xBF;                         //MSIF=0,軟件清零IIC主機狀態寄存器的中斷標志位
void I2C_Start(void)
        I2CMSCR=0x01;
        I2C_Wait();
void I2C_SendData(uchar dat)
        I2CTXD=dat;                           //寫數據到數據緩沖區
        I2CMSCR=0x02;                          //發送SEND命令
        I2C_Wait();
void I2C_RecvACK(void)
        I2CMSCR=0x03;                    //發送讀ACK命令
        I2C_Wait();
uchar I2C_RecvData(void)
        I2CMSCR=0x04;                     //發送RECV命令
        I2C_Wait();
        return  I2CRXD;
void I2C_SendACK(void)
        I2CMSST=0x00;                          //設置ACK信號
        I2CMSCR=0x05;                     //發送ACK命令
        I2C_Wait();
void I2C_SendNAK(void)
        I2CMSST=0x01;                            //設置NAK信號
        I2C_Wait();
void I2C_Stop(void)
        I2CMSCR=0x06;                      //發送STOP命令
        I2C_Wait();
void I2C_init(void)
        P_SW2 &= 0xCF;                         //將I2C_S[1:0]置01,以選擇I2C硬件功能腳為P2.4  P2.5
        P_SW2 |= 0x10;                         //將I2C_S[1:0]置01,以選擇I2C硬件功能腳為P2.4  P2.5
        I2CCFG=0xFF;               //使能I2C主機模式
        I2CMSST=0x00;
#endif
#ifndef OLEDFONT_H
#define OLEDFONT_H
unsigned char code F8X16[]=
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 0
  0x00,0x00,0x00,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x33,0x30,0x00,0x00,0x00,//! 1
  0x00,0x10,0x0C,0x06,0x10,0x0C,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//" 2
  0x40,0xC0,0x78,0x40,0xC0,0x78,0x40,0x00,0x04,0x3F,0x04,0x04,0x3F,0x04,0x04,0x00,//# 3
  0x00,0x70,0x88,0xFC,0x08,0x30,0x00,0x00,0x00,0x18,0x20,0xFF,0x21,0x1E,0x00,0x00,//$ 4
  0xF0,0x08,0xF0,0x00,0xE0,0x18,0x00,0x00,0x00,0x21,0x1C,0x03,0x1E,0x21,0x1E,0x00,//% 5
  0x00,0xF0,0x08,0x88,0x70,0x00,0x00,0x00,0x1E,0x21,0x23,0x24,0x19,0x27,0x21,0x10,//& 6
  0x10,0x16,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//' 7
  0x00,0x00,0x00,0xE0,0x18,0x04,0x02,0x00,0x00,0x00,0x00,0x07,0x18,0x20,0x40,0x00,//( 8
  0x00,0x02,0x04,0x18,0xE0,0x00,0x00,0x00,0x00,0x40,0x20,0x18,0x07,0x00,0x00,0x00,//) 9
  0x40,0x40,0x80,0xF0,0x80,0x40,0x40,0x00,0x02,0x02,0x01,0x0F,0x01,0x02,0x02,0x00,//* 10
  0x00,0x00,0x00,0xF0,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x1F,0x01,0x01,0x01,0x00,//+ 11
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xB0,0x70,0x00,0x00,0x00,0x00,0x00,//, 12
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,//- 13
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00,//. 14
  0x00,0x00,0x00,0x00,0x80,0x60,0x18,0x04,0x00,0x60,0x18,0x06,0x01,0x00,0x00,0x00,/// 15
  0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,//0 16
  0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//1 17
  0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,//2 18
  0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,//3 19
  0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,//4 20
  0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,//5 21
  0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00,//6 22
  0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,//7 23
  0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,//8 24
  0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00,//9 25
  0x00,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,//: 26
  0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x60,0x00,0x00,0x00,0x00,//; 27
  0x00,0x00,0x80,0x40,0x20,0x10,0x08,0x00,0x00,0x01,0x02,0x04,0x08,0x10,0x20,0x00,//< 28
  0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x00,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x00,//= 29
  0x00,0x08,0x10,0x20,0x40,0x80,0x00,0x00,0x00,0x20,0x10,0x08,0x04,0x02,0x01,0x00,//> 30
  0x00,0x70,0x48,0x08,0x08,0x08,0xF0,0x00,0x00,0x00,0x00,0x30,0x36,0x01,0x00,0x00,//? 31
  0xC0,0x30,0xC8,0x28,0xE8,0x10,0xE0,0x00,0x07,0x18,0x27,0x24,0x23,0x14,0x0B,0x00,//@ 32
  0x00,0x00,0xC0,0x38,0xE0,0x00,0x00,0x00,0x20,0x3C,0x23,0x02,0x02,0x27,0x38,0x20,//A 33
  0x08,0xF8,0x88,0x88,0x88,0x70,0x00,0x00,0x20,0x3F,0x20,0x20,0x20,0x11,0x0E,0x00,//B 34
  0xC0,0x30,0x08,0x08,0x08,0x08,0x38,0x00,0x07,0x18,0x20,0x20,0x20,0x10,0x08,0x00,//C 35
  0x08,0xF8,0x08,0x08,0x08,0x10,0xE0,0x00,0x20,0x3F,0x20,0x20,0x20,0x10,0x0F,0x00,//D 36
  0x08,0xF8,0x88,0x88,0xE8,0x08,0x10,0x00,0x20,0x3F,0x20,0x20,0x23,0x20,0x18,0x00,//E 37
  0x08,0xF8,0x88,0x88,0xE8,0x08,0x10,0x00,0x20,0x3F,0x20,0x00,0x03,0x00,0x00,0x00,//F 38
  0xC0,0x30,0x08,0x08,0x08,0x38,0x00,0x00,0x07,0x18,0x20,0x20,0x22,0x1E,0x02,0x00,//G 39
  0x08,0xF8,0x08,0x00,0x00,0x08,0xF8,0x08,0x20,0x3F,0x21,0x01,0x01,0x21,0x3F,0x20,//H 40
  0x00,0x08,0x08,0xF8,0x08,0x08,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//I 41
  0x00,0x00,0x08,0x08,0xF8,0x08,0x08,0x00,0xC0,0x80,0x80,0x80,0x7F,0x00,0x00,0x00,//J 42
  0x08,0xF8,0x88,0xC0,0x28,0x18,0x08,0x00,0x20,0x3F,0x20,0x01,0x26,0x38,0x20,0x00,//K 43
  0x08,0xF8,0x08,0x00,0x00,0x00,0x00,0x00,0x20,0x3F,0x20,0x20,0x20,0x20,0x30,0x00,//L 44
  0x08,0xF8,0xF8,0x00,0xF8,0xF8,0x08,0x00,0x20,0x3F,0x00,0x3F,0x00,0x3F,0x20,0x00,//M 45
  0x08,0xF8,0x30,0xC0,0x00,0x08,0xF8,0x08,0x20,0x3F,0x20,0x00,0x07,0x18,0x3F,0x00,//N 46
  0xE0,0x10,0x08,0x08,0x08,0x10,0xE0,0x00,0x0F,0x10,0x20,0x20,0x20,0x10,0x0F,0x00,//O 47
  0x08,0xF8,0x08,0x08,0x08,0x08,0xF0,0x00,0x20,0x3F,0x21,0x01,0x01,0x01,0x00,0x00,//P 48
  0xE0,0x10,0x08,0x08,0x08,0x10,0xE0,0x00,0x0F,0x18,0x24,0x24,0x38,0x50,0x4F,0x00,//Q 49
  0x08,0xF8,0x88,0x88,0x88,0x88,0x70,0x00,0x20,0x3F,0x20,0x00,0x03,0x0C,0x30,0x20,//R 50
  0x00,0x70,0x88,0x08,0x08,0x08,0x38,0x00,0x00,0x38,0x20,0x21,0x21,0x22,0x1C,0x00,//S 51
  0x18,0x08,0x08,0xF8,0x08,0x08,0x18,0x00,0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00,//T 52
  0x08,0xF8,0x08,0x00,0x00,0x08,0xF8,0x08,0x00,0x1F,0x20,0x20,0x20,0x20,0x1F,0x00,//U 53
  0x08,0x78,0x88,0x00,0x00,0xC8,0x38,0x08,0x00,0x00,0x07,0x38,0x0E,0x01,0x00,0x00,//V 54
  0xF8,0x08,0x00,0xF8,0x00,0x08,0xF8,0x00,0x03,0x3C,0x07,0x00,0x07,0x3C,0x03,0x00,//W 55
  0x08,0x18,0x68,0x80,0x80,0x68,0x18,0x08,0x20,0x30,0x2C,0x03,0x03,0x2C,0x30,0x20,//X 56
  0x08,0x38,0xC8,0x00,0xC8,0x38,0x08,0x00,0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00,//Y 57
  0x10,0x08,0x08,0x08,0xC8,0x38,0x08,0x00,0x20,0x38,0x26,0x21,0x20,0x20,0x18,0x00,//Z 58
  0x00,0x00,0x00,0xFE,0x02,0x02,0x02,0x00,0x00,0x00,0x00,0x7F,0x40,0x40,0x40,0x00,//[ 59
  0x00,0x0C,0x30,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x06,0x38,0xC0,0x00,//\ 60
  0x00,0x02,0x02,0x02,0xFE,0x00,0x00,0x00,0x00,0x40,0x40,0x40,0x7F,0x00,0x00,0x00,//] 61
  0x00,0x00,0x04,0x02,0x02,0x02,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//^ 62
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,//_ 63
  0x00,0x02,0x02,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//` 64
  0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x19,0x24,0x22,0x22,0x22,0x3F,0x20,//a 65
  0x08,0xF8,0x00,0x80,0x80,0x00,0x00,0x00,0x00,0x3F,0x11,0x20,0x20,0x11,0x0E,0x00,//b 66
  0x00,0x00,0x00,0x80,0x80,0x80,0x00,0x00,0x00,0x0E,0x11,0x20,0x20,0x20,0x11,0x00,//c 67
  0x00,0x00,0x00,0x80,0x80,0x88,0xF8,0x00,0x00,0x0E,0x11,0x20,0x20,0x10,0x3F,0x20,//d 68
  0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x1F,0x22,0x22,0x22,0x22,0x13,0x00,//e 69
  0x00,0x80,0x80,0xF0,0x88,0x88,0x88,0x18,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//f 70
  0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x6B,0x94,0x94,0x94,0x93,0x60,0x00,//g 71
  0x08,0xF8,0x00,0x80,0x80,0x80,0x00,0x00,0x20,0x3F,0x21,0x00,0x00,0x20,0x3F,0x20,//h 72
  0x00,0x80,0x98,0x98,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//i 73
  0x00,0x00,0x00,0x80,0x98,0x98,0x00,0x00,0x00,0xC0,0x80,0x80,0x80,0x7F,0x00,0x00,//j 74
  0x08,0xF8,0x00,0x00,0x80,0x80,0x80,0x00,0x20,0x3F,0x24,0x02,0x2D,0x30,0x20,0x00,//k 75
  0x00,0x08,0x08,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//l 76
  0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x20,0x3F,0x20,0x00,0x3F,0x20,0x00,0x3F,//m 77
  0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x00,0x20,0x3F,0x21,0x00,0x00,0x20,0x3F,0x20,//n 78
  0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x1F,0x20,0x20,0x20,0x20,0x1F,0x00,//o 79
  0x80,0x80,0x00,0x80,0x80,0x00,0x00,0x00,0x80,0xFF,0xA1,0x20,0x20,0x11,0x0E,0x00,//p 80
  0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x0E,0x11,0x20,0x20,0xA0,0xFF,0x80,//q 81
  0x80,0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x20,0x20,0x3F,0x21,0x20,0x00,0x01,0x00,//r 82
  0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x33,0x24,0x24,0x24,0x24,0x19,0x00,//s 83
  0x00,0x80,0x80,0xE0,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x1F,0x20,0x20,0x00,0x00,//t 84
  0x80,0x80,0x00,0x00,0x00,0x80,0x80,0x00,0x00,0x1F,0x20,0x20,0x20,0x10,0x3F,0x20,//u 85
  0x80,0x80,0x80,0x00,0x00,0x80,0x80,0x80,0x00,0x01,0x0E,0x30,0x08,0x06,0x01,0x00,//v 86
  0x80,0x80,0x00,0x80,0x00,0x80,0x80,0x80,0x0F,0x30,0x0C,0x03,0x0C,0x30,0x0F,0x00,//w 87
  0x00,0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x00,0x20,0x31,0x2E,0x0E,0x31,0x20,0x00,//x 88
  0x80,0x80,0x80,0x00,0x00,0x80,0x80,0x80,0x80,0x81,0x8E,0x70,0x18,0x06,0x01,0x00,//y 89
  0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x21,0x30,0x2C,0x22,0x21,0x30,0x00,//z 90
  0x00,0x00,0x00,0x00,0x80,0x7C,0x02,0x02,0x00,0x00,0x00,0x00,0x00,0x3F,0x40,0x40,//{ 91
  0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,//| 92
  0x00,0x02,0x02,0x7C,0x80,0x00,0x00,0x00,0x00,0x40,0x40,0x3F,0x00,0x00,0x00,0x00,//} 93
  0x00,0x06,0x01,0x01,0x02,0x02,0x04,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//~ 94
unsigned char code F16x16[] =
/*--  ??12;  ??????????:?x?=16x16   --*/
0x10,0x10,0xD0,0xFF,0x90,0x10,0x00,0x10,0x10,0xD0,0xFF,0xD0,0x10,0x10,0x10,0x00,
0x04,0x03,0x00,0xFF,0x00,0x11,0x08,0x04,0x03,0x00,0xFF,0x00,0x03,0x04,0x08,0x00,
0x10,0x10,0x92,0x92,0x92,0xFE,0x92,0x92,0x92,0x92,0x92,0x92,0xFE,0x10,0x10,0x00,
0x40,0x20,0x10,0x0C,0xFF,0x44,0x44,0x44,0x44,0x44,0x44,0x44,0xFC,0x00,0x00,0x00,
#endif
#ifndef DELAY_H
#define DELAY_H
#include  "intrins.h"
* 描  述 : 延時函數
* 入  參 : 1ms的整數倍
* 返回值 : 無
void delay_ms(uint x)
        uint j,i;
        for(j=0;j<x;j++)
                for(i=0;i<1580;i++);
#endif
希望大佬不吝賜教求求啦,顯示出的效果如下
ID:88256 發表于 2021-7-21 11:56 | 顯示全部樓層
你的意思是日期無法正常顯示?
ID:906945 發表于 2021-7-21 11:59 | 顯示全部樓層
hhdsdy 發表于 2021-7-21 11:56
你的意思是日期無法正常顯示?
對,年月,時間都可以,就是日一直顯示00
ID:88256 發表于 2021-7-21 13:25 | 顯示全部樓層
笨學單片機 發表于 2021-7-21 11:59
年月等寫入和讀出都正常,問題只能是出在日地址錯誤或者數據被篡改了,8563我還沒用過,看了一下程序,地址是自增量的,處于中間的日不應該會出錯,查看程序涉及日處理的地方,都沒見出錯的地方,最后回歸到地址上,年月日星期時分秒,按慣性思維看似沒錯,打開 8563的手冊,才發現經驗害死人,你自己估計都沒認真看手冊吧?
參與人數 1黑幣 +30 收起 理由
admin + 30 回帖助人的獎勵!
ID:155507 發表于 2021-7-21 16:13 | 顯示全部樓層
你的放進去及取回順序錯了
功能描述:讀RTC函數
入口參數:無
返回值:無
void        ReadRTC(void)
        I2C_Start();
        I2C_SendData(0xA2);
        I2C_RecvACK();
        I2C_SendData(0x02);
        I2C_RecvACK();
        I2C_Start();
        I2C_SendData(0xA3);
        I2C_RecvACK();
        I2C_SendACK();
        I2C_SendACK();
        I2C_SendACK();
        week   = tmp[3];    <-------- 日期值
        I2C_SendACK();
        date   = ((tmp[2] >> 4) & 0x03) * 10 + (tmp[2] & 0x0f);      <--------星期值
        I2C_SendACK();
        I2C_SendACK();
        I2C_SendNAK();
        I2C_Stop();
功能描述:寫RTC函數
入口參數:無
返回值:無
void        WriteRTC(void)
        I2C_Start();
        I2C_RecvACK();
        I2C_RecvACK();
        I2C_RecvACK();
        I2C_RecvACK();
        I2C_RecvACK();
        I2C_SendData(tmp[3]);          //設置星期值   <-------- 日期值
        I2C_RecvACK();
        I2C_SendData(tmp[2]);          //設置日期值   <--------星期值
        I2C_RecvACK();
        I2C_RecvACK();
        I2C_RecvACK();
        I2C_Stop();
ID:906945 發表于 2021-7-30 19:31 | 顯示全部樓層
angmall 發表于 2021-7-21 16:13
你的放進去及取回順序錯了
謝謝謝謝我懂啦
hhdsdy 發表于 2021-7-21 13:25
年月等寫入和讀出都正常,問題只能是出在日地址錯誤或者數據被篡改了,8563我還沒用過,看了一下程序,地 ...
謝謝謝謝我知道啦
