查看: 4006|回復: 0
單片機計時器程序0~9999
ID:954156 發表于 2021-7-17 17:35 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
unsigned char code LedChar[] = {  //數碼管顯示字符轉換表
    0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,
    0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E
unsigned char LedBuff[6] = {  //數碼管顯示緩沖區,初值0xFF確保啟動時都不亮
    0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
unsigned char i = 0;   //動態掃描的索引
unsigned int cnt = 0;  //記錄T0中斷次數
unsigned char flag1s = 0;  //1秒定時標志
    char j;  //循環變量
    unsigned long sec = 0;  //記錄經過的秒數
    unsigned char buf[6];   //中間轉換緩沖區
    EA = 1;       //使能總中斷
    ENLED = 0;    //使能U3
    ADDR3 = 1;    //因為需要動態改變ADDR0-2的值,所以不需要再初始化了
    TMOD = 0x01;  //設置T0為模式1
    TH0  = 0xFC;  //為T0賦初值0xFC67,定時1ms
    TL0  = 0x67;
    ET0  = 1;     //使能T0中斷
    TR0  = 1;     //啟動T0
    while (1)
        if (flag1s == 1)  //判斷1秒定時標志
            flag1s = 0;   //1秒定時標志清零
            sec++;        //秒計數自加1
            //將sec按十進制位從低到高依次提取到buf數組中
            buf[0] = sec%10;
            buf[1] = sec/10%10;
            buf[2] = sec/100%10;
            buf[3] = sec/1000%10;
            buf[4] = sec/10000%10;
            buf[5] = sec/100000%10;
            //從最高為開始,遇到0不顯示,遇到非0退出循環
            for (j=5; j>=1; j--)
                if (buf[j] == 0)
                    LedBuff[j] = 0xFF;
                    break;
            //將剩余的有效數字位如實轉換
            for ( ; j>=0; j--)  //for()起始未對j操作,j即保持上個循環結束時的值
                LedBuff[j] = LedChar[buf[j]];
/* 定時器0中斷服務函數 */
void InterruptTimer0() interrupt 1
    TH0 = 0xFC;  //重新加載初值
    TL0 = 0x67;
    cnt++;       //中斷次數計數值加1
    if (cnt >= 1000)  //中斷1000次即1秒
        cnt = 0;      //清零計數值以重新開始下1秒計時
        flag1s = 1;   //設置1秒定時標志為1
    //以下代碼完成數碼管動態掃描刷新
    P0 = 0xFF;   //顯示消隱
    switch (i)
        case 0: ADDR2=0; ADDR1=0; ADDR0=0; i++; P0=LedBuff[0]; break;
        case 1: ADDR2=0; ADDR1=0; ADDR0=1; i++; P0=LedBuff[1]; break;
        case 2: ADDR2=0; ADDR1=1; ADDR0=0; i++; P0=LedBuff[2]; break;
        case 3: ADDR2=0; ADDR1=1; ADDR0=1; i++; P0=LedBuff[3]; break;
        case 4: ADDR2=1; ADDR1=0; ADDR0=0; i++; P0=LedBuff[4]; break;
        case 5: ADDR2=1; ADDR1=0; ADDR0=1; i=0; P0=LedBuff[5]; break;
        default: break;
原理圖:http://m.raoushi.com/bbs/dpj-210214-1.html
