本功能中用51單片機(jī)做控制核心,實(shí)現(xiàn)的功能是鍵盤輸入數(shù)值,用一塊液晶顯示屏同時(shí)顯示一些提示字符,比如“welcome go home”、“the num is right”等,這個(gè)密碼鎖設(shè)計(jì)目前已經(jīng)處于淘汰的邊緣,但是對(duì)于初學(xué)者來說算是一次比較復(fù)雜的設(shè)計(jì)嘗試,該設(shè)計(jì)中使用了矩陣鍵盤,液晶屏,繼電器等模塊,初始設(shè)計(jì)的密碼位數(shù)是3位,若想增加位數(shù)只需對(duì)程序中的初始密碼進(jìn)行修改,同時(shí)更改主函數(shù)中的判定位數(shù)即可。最高支持16位密碼。密碼輸入正確繼電器動(dòng)作,同時(shí)LED燈會(huì)閃爍3次。主要裝配的電路圖如下所示:LED和繼電器未標(biāo)出,應(yīng)連接P0.3和P0.4
仿真(版本8.11)
實(shí)物搭建
程序代碼:
#include <reg52.h> //方便觀看,1602未使用庫(kù)函數(shù)調(diào)用
#include <stdio.h>
#include <intrins.h>
#define KeyPort P1
#define DataPort P0
sbit RS = P2^2;
sbit RW = P2^1;
sbit EN = P2^0;
sbit BEEP = P0^4;
sbit CON = P0^3;
uchar code password[]={3,3,3};初始密碼,若位數(shù)更改,主函數(shù)中對(duì)應(yīng)位數(shù)也要修改
void DelayUs2x(uchar t)
while(--t);
延時(shí)函數(shù),若精確延時(shí)請(qǐng)使用匯編修改
void DelayMs(uchar t)
while(t--)
DelayUs2x(245);
DelayUs2x(245);
LCD1602寫指令
void write_com(uchar com)
RS=0;
RW=0;
DataPort = com;
EN=1;
DelayMs(1);
EN=0;
LCD1602寫數(shù)據(jù)
void write_data(uchar dat)
RS=1;
RW=0;
DataPort = dat;
EN=1;
DelayMs(1);
EN=0;
清屏
void clear(void)
write_com(0x01);
DelayMs(5);
LCD1602寫字符
void write_char(uchar x,uchar y,uchar Data)
if (y == 0)
write_com(0x80 + x);
write_com(0xC0 + x);
write_data(Data);
LCD1602寫字符串
void write_string(uchar x,uchar y,uchar *s)
while (*s)
write_char(x,y,*s);
s++;
x++;
LCD1602初始化
void LCD_Init(void)
write_com(0x38);
write_com(0x08);
write_com(0x01);
write_com(0x06);
write_com(0x0C);
行掃描法,返回對(duì)應(yīng)鍵值
uchar KeyScan(void)
uchar cord_h,cord_l;
KeyPort=0x0f;
cord_h=KeyPort&0x0f;
if(cord_h!=0x0f)
DelayMs(10);
if((KeyPort&0x0f)!=0x0f)
KeyPort=cord_h|0xf0;
cord_l=KeyPort&0xf0;
while((KeyPort&0xf0)!=0xf0);
return(cord_h+cord_l);
return(0xff);
按鍵處理函數(shù),返回對(duì)應(yīng)數(shù)值
uchar KeyPro(void)
switch(KeyScan())
case 0x7e:return 0;break; //0 7E //此處對(duì)應(yīng)矩陣鍵盤相對(duì)值
case 0xbe:return 1;break; //1 7D
case 0xde:return 2;break; //2 7B
case 0xee:return 3;break; //3 77
case 0x7d:return 4;break; //4 BE
case 0xbd:return 5;break; //5 BD
case 0xdd:return 6;break; //6 BB
case 0xed:return 7;break; //7 B7
case 0x7b:return 8;break; //8 DE
case 0xbb:return 9;break; //9 DD
case 0xdb:return 10;break; //a DB
case 0xeb:return 11;break; //b D7
case 0x77:return 12;break; //c EE
case 0xb7:return 13;break; //d ED
case 0xd7:return 14;break; //e EB
case 0xe7:return 15;break; //f E7
default:return 0xff;break;
uchar num,i,j;
uchar passwordtemp[3];
uchar inputtimes;
uchar passwordlength,PLEN;
bit Flag;
PLEN=sizeof(password)/sizeof(password[0]);
LCD_Init();
//DelayMs(10);
clear();
BEEP=0;
CON=0;
write_string(0,0," Welcome! ");
write_string(0,1,"Input password:");
num=KeyPro();
if(num!=0xff)
if(i==0)
write_string(0,1," ");
if(i<3)//若初始密碼位數(shù)更改,此處對(duì)應(yīng)的判定位數(shù)也要修改,要和前面的定義一致
passwordtemp[ i]=num;
write_string(0,0," Your nm is: ");
write_char(i,1,'*');
i++;
if(15==num) //鍵盤上的15號(hào)按鍵對(duì)應(yīng)確定按鈕
passwordlength=i-1;
i=0;
if(passwordlength==PLEN)
Flag=1;
for(j=0;j<PLEN;j++)
Flag=Flag&&(passwordtemp[j]==password[j]);
if(Flag)
CON = 1;
BEEP=1;
write_string(0,0," ");
write_string(0,0," Welcome home! ");
write_string(0,1,"Right Open!>>>>");
BEEP=1;DelayMs(2000);
BEEP=0;DelayMs(2000);
inputtimes=0;
Flag=0;
BEEP=0;
CON = 0;
write_string(0,1,"Password Error! ");
inputtimes++;
if(inputtimes==3)
write_string(0,0,"Wrong 3 times!");
write_string(0,1,"Door is Locked.")
while(1);
全部資料51hei下載地址:
密碼鎖0409.rar
(121.4 KB, 下載次數(shù): 29)
2021-7-17 14:23 上傳
點(diǎn)擊文件名下載附件
評(píng)分
查看全部評(píng)分
