主要內(nèi)容顯示如下:
模塊化LCD1602.c和LCD1602.h如下文件
#include <REGX52.H>
sbit LCD_RW=P2^5;
sbit LCD_RS=P2^6;//1為數(shù)據(jù),0為指令
sbit LCD_E=P2^7;
#define LCD_DataPort P0
void Delay(unsigned char xms)
unsigned char i=2,j=199;
while(xms--)
do
while(--j);
}while(--i);
void LCD_WriteCommand(unsigned char Command)
LCD_RS=0;
LCD_RW=0;
LCD_DataPort=Command;
LCD_E=1;
Delay(1);
LCD_E=0;
Delay(1);
void LCD_WriteData(unsigned char Data)
LCD_RS=1;
LCD_RW=0;
LCD_DataPort=Data;
LCD_E=1;
Delay(1);
LCD_E=0;
Delay(1);
void LCD_Init(void)
LCD_WriteCommand(0x38);
LCD_WriteCommand(0x0C);
LCD_WriteCommand(0x06);
LCD_WriteCommand(0x01);
void LCD_SetAC(unsigned char Line,unsigned char Column)
LCD_WriteCommand(0x80);
if(Line==1)
LCD_WriteCommand(0x80|(Column-1));
else if(Line==2)
LCD_WriteCommand(0x80|(Column-1)+0x40);
void LCD_ShowChar(unsigned char Line,unsigned char Column,unsigned char Char)
LCD_SetAC(Line,Column);
LCD_WriteData(Char);
void LCD_ShowString(unsigned char Line,unsigned char Column,unsigned char *String)
if(*String!='\0'){LCD_WriteData(*String);}
else{break;}
String++;
int Power(unsigned char X,unsigned char Y)
unsigned char i;
int result=1;
for(i=0;i<Y;i++)
result*=X;
return result;
void LCD_ShowNum(unsigned char Line,unsigned char Column,int Number,unsigned char Length)
unsigned char i;
for(i=Length;i>0;i--)
LCD_WriteData('0'+Number/Power(10,i-1)%10);
void LCD_ShowsignedNum(unsigned char Line,unsigned char Column,int Num1,unsigned char Length)
int Number1;
unsigned char i;
if(Num1>0)
LCD_WriteData('+');
Number1=Num1;
else if(Num1<0)
LCD_WriteData('-');
Number1=-Num1;
LCD_WriteData('0'+Number1/Power(10,i-1)%10);
LCD_Init();
LCD_ShowChar(1,1,'A');
LCD_ShowString(1,3,"Hello");
LCD_ShowNum(1,9,66,2);
LCD_ShowsignedNum(1,12,-88,2);
LCD.rar
2021-7-12 09:38 上傳
下載積分: 黑幣 -5
25.4 KB, 下載次數(shù): 74, 下載積分: 黑幣 -5
LCD1602模塊化
