- #include<reg52.h>
- unsigned int i=0;
- sbit P36=P3^6;
- unsigned char j;
- unsigned int kop;
- unsigned char a[10]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
- unsigned char b[8]={0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff};
- void delaym(unsigned int t)
- { unsigned char p;
- while(t--)
- for(p=0; p<125; p++);
- void main()
- EA = 1;
- TH0=0x00;
- TL0=0x00;
- ET0=1;
- ET1=1;
- TMOD = 0x15;// 打開(kāi)定時(shí)器和計(jì)數(shù)器T0,因此矩形脈沖輸入端接P3.4
- TH1=0x3C; //50ms
- TL1=0xB0;
- TR0 = 1;
- TR1 = 1;
- while(1)
- for(j=0;j<3;j++) //顯示個(gè)數(shù)
- P0=b[j];
- P2=j;
- delaym(2);
- timer3() interrupt 3 //定時(shí)器中斷時(shí)間到,就讀取計(jì)數(shù)器值
- { TH1=0X3C;
- TL1=0XB0;
- i++;
- if(i==20) //1s才進(jìn)行技術(shù)脈沖值顯示,即每秒更新一次速度
- kop=TH0;//計(jì)數(shù)器計(jì)入脈沖,每來(lái)一個(gè)矩形脈沖計(jì)數(shù)值加1
- kop=kop<<8;
- kop=kop+TL0;
- b[2]=a[kop/100]; //顯示計(jì)數(shù)器的值即實(shí)際測(cè)得速度
- b[1]=a[kop%100/10];
- b[0]=a[kop%100%10];
- i=0;
- TH0=0;//計(jì)數(shù)器速度獲取后清零,進(jìn)行下次獲取
- TL0=0;
