- #include "delay.h"
- #include "sys.h"
- #include "usart.h"
- #include "led.h"
- #include "key.h"
- //超聲波硬件接口定義
- #define HCSR04_PORT GPIOB
- #define HCSR04_CLK RCC_APB2Periph_GPIOB
- #define HCSR04_TRIG GPIO_Pin_11
- #define HCSR04_ECHO GPIO_Pin_10
- //超聲波計(jì)數(shù)
- u16 msHcCount = 0;
- //定時(shí)器4設(shè)置
- void hcsr04_NVIC()
- NVIC_InitTypeDef NVIC_InitStructure;
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
- NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
- NVIC_Init(&NVIC_InitStructure);
- //IO口初始化 及其他初始化
- void Hcsr04Init()
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(HCSR04_CLK, ENABLE);
- GPIO_InitStructure.GPIO_Pin =HCSR04_TRIG;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(HCSR04_PORT, &GPIO_InitStructure);
- GPIO_ResetBits(HCSR04_PORT,HCSR04_TRIG);
- GPIO_InitStructure.GPIO_Pin = HCSR04_ECHO;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
- GPIO_ResetBits(HCSR04_PORT,HCSR04_ECHO);
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
- TIM_DeInit(TIM4);
- TIM_TimeBaseStructure.TIM_Period = (999);
- TIM_TimeBaseStructure.TIM_Prescaler =(71);
- TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
- TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
- TIM_ClearFlag(TIM4, TIM_FLAG_Update);
- TIM_ITConfig(TIM4,TIM_IT_Update,ENABLE);
- TIM_Cmd(TIM4,DISABLE);
- //打開(kāi)定時(shí)器4
- static void OpenTimerForHc()
- TIM_SetCounter(TIM4,0);
- msHcCount = 0;
- TIM_Cmd(TIM4, ENABLE);
- //關(guān)閉定時(shí)器4
- static void CloseTimerForHc()
- TIM_Cmd(TIM4, DISABLE);
- //定時(shí)器4終中斷
- void TIM4_IRQHandler(void)
- if (TIM_GetITStatus(TIM4, TIM_IT_Update) != RESET)
- msHcCount++;
- TIM_ClearITPendingBit(TIM4, TIM_IT_Update );
- //獲取定時(shí)器4計(jì)數(shù)器值
- u32 GetEchoTimer(void)
- u32 t = 0;
- t = msHcCount*1000;
- t += TIM_GetCounter(TIM4);
- TIM4->CNT = 0;
- delay_ms(50);
- return t;
- //通過(guò)定時(shí)器4計(jì)數(shù)器值推算距離
- float Hcsr04GetLength(void )
- u32 t = 0;
- int i = 0;
- float lengthTemp = 0;
- float sum = 0;
- while(i!=5)
- TRIG_Send = 1;
- delay_us(20);
- TRIG_Send = 0;
- while(ECHO_Reci == 0);
- OpenTimerForHc();
- i = i + 1;
- while(ECHO_Reci == 1);
- CloseTimerForHc();
- t = GetEchoTimer();
- lengthTemp = ((float)t*0.034/2);//cm
- sum = lengthTemp + sum ;
- lengthTemp = sum/5.0;
- return lengthTemp;
- //測(cè)試主函數(shù)
- int main(void)
- float length;
- delay_init(); //延時(shí)函數(shù)初始化
- //NVIC_Configuration(); //設(shè)置NVIC中斷分組2:2位搶占優(yōu)先級(jí),2位響應(yīng)優(yōu)先級(jí)
- hcsr04_NVIC();
- uart_init(9600); //串口初始化為9600
- Hcsr04Init();
- LED_Init();
- // Hcsr04Init();
- while(1)
- length = Hcsr04GetLength();
- printf("距離為:%.3fcm\n",length);
- if(length>100)
- GPIO_ResetBits(GPIOB,GPIO_Pin_0);
- else
- GPIO_SetBits(GPIOB,GPIO_Pin_0);
- delay_ms(50);
代碼:
超聲波(用).7z
(219.91 KB, 下載次數(shù): 36)
2021-6-27 21:15 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
評(píng)分
查看全部評(píng)分
