給你改了,對比一下就知道哪里錯了。
- #include <reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define DAdata P0
- #define lcd_ports P1
- void delay(uchar z);
- void triangle_out();
- void sine_out();
- void square_out();
- void write_com(uchar com);
- void write_date(uchar date);
- void disp_lcd(uchar addr,uchar *temp1);
- void init_lcd();
- //void timer0() interrupt 1; //中斷子函數 不須要函數申明
- //void key_int0() interrupt 0; //中斷子函數 不須要函數申明
- sbit DA_S1= P2^0;
- sbit DA_S2= P2^1;
- sbit rs=P2^2;
- sbit rw=P2^3;
- sbit lcden=P2^4;
- sbit key= P3^2;
- uchar wavecount;
- uchar THtemp,TLtemp;
- uchar judge=1;
- uchar waveform;
- uchar code freq_unit[3]={10,50,200};
- uchar idata wavefreq[3]={1,1,1};
- uchar code lcd_hang1[]={"Sine Wave" "Triangle Wave" "Square Wave" "Select Wave:" "press No.1 key!"};
- uchar idata lcd_hang2[16]={"f=Hz"};
- uchar code waveTH[]={
- 0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
- 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff};
- uchar code waveTL[]={
- 0x06,0x8a, 0x10,0x4e, 0x78,0x93, 0xa8,0xb3, 0xbe,0xc6,
- 0xac,0xde,0x48,0x7a,0x99,0xaf,0xbb,0xc8,0xd0,0xde,
- 0xff,0x8e,0x5a,0x41,0x32,0x28,0x20,0x1b,0x17,0x0e};
- uchar code triangle_tab[]={
- 0x00,0x08,0x10,0x18,0x20,0x28,0x30,0x38,0x40,0x48,0x50,0x58,0x60,0x68,0x70,0x78,
- 0x80,0x88,0x90,0x98,0xa0,0xa8,0xb0,0xb8,0xc0,0xc8,0xd0,0xd8,0xe0,0xe8,0xf0,0xf8,0xff,
- 0xf8,0xf0,0xe8,0xe0,0xd8,0xd0,0xc8,0xc0,0xb8,0xb0,0xa8,0xa0,0x98,0x90,0x88,0x80,
- 0x78,0x70,0x68,0x60,0x58,0x50,0x48,0x40,0x38,0x30,0x28,0x20,0x18,0x10,0x08,0x00};
- uchar code sine_tab[256]={
- 0x80,0x83,0x86,0x89,0x8d,0x90,0x93,0x96,0x99,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,0xae,0xb1,0xb4,0xb7,0xba,0xbc, 0xbf,0xc2,0xc5,0xc7,0xca,0xcc,0xcf,0xd1,0xd4,0xd6,0xd8,0xda,0xdd,0xdf,0xe1,0xe3,0xe5,0xe7,0xe9,0xea,0xec,
- 0xee,0xef,0xf1,0xf2,0xf4,0xf5,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,
- 0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfd,0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf4,0xf2,0xf1,0xef,
- 0xee,0xec,0xea,0xe9,0xe7,0xe5,0xe3,0xe1,0xde,0xdd,0xda,0xd8,0xd6,0xd4,0xd1,0xcf,0xcc,0xca,0xc7,0xc5,0xc2,
- 0xbf,0xbc,0xba,0xb7,0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99 ,0x96,0x93,0x90,0x8d,0x89,0x86,0x83,0x80,
- 0x80,0x7c,0x79,0x76,0x72,0x6f,0x6c,0x69,0x66,0x63,0x60,0x5d,0x5a,0x57,0x55,0x51,0x4e,0x4c,0x48,0x45,0x43,
- 0x40,0x3d,0x3a,0x38,0x35,0x33,0x30,0x2e,0x2b,0x29,0x27,0x25,0x22,0x20,0x1e,0x1c,0x1a,0x18,0x16 ,0x15,0x13,
- 0x11,0x10,0x0e,0x0d,0x0b,0x0a,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02 ,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0d,0x0e,0x10,
- 0x11,0x13,0x15 ,0x16,0x18,0x1a,0x1c,0x1e,0x20,0x22,0x25,0x27,0x29,0x2b,0x2e,0x30,0x33,0x35,0x38,0x3a,0x3d,
- 0x40,0x43,0x45,0x48,0x4c,0x4e,0x51,0x55,0x57,0x5a,0x5d,0x60,0x63,0x66 ,0x69,0x6c,0x6f,0x72,0x76,0x79,0x7c,0x80};
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- DAdata=triangle_tab[wavecount++];
- if(wavecount>64) wavecount=0;
- DA_S1=0;
- DA_S1=1;
- void sine_out()
- DAdata=sine_tab[wavecount++];
- DA_S1=0;
- DA_S1=1;
- void square_out()
- judge=~judge;
- if(judge==1) DAdata=0xff;
- else DAdata=0x00;
- DA_S1=0; //打開位輸入寄存器
- DA_S1=1; //關閉位輸入寄存器
- /************1602液晶的相關函數*************/
- rs=0;
- lcden=0;
- lcd_ports=com;
- delay(5);
- lcden=1;
- delay(5);
- lcden=0;
- rs=1;
- lcden=0;
- lcd_ports=date;
- delay(5);
- lcden=1;
- delay(5);
- lcden=0;
- uchar num;
- write_com(addr);
- delay(1);
- for(num=0;num<16;num++)
- write_date(temp1[num]);
- delay(1);
- void init_lcd()
- lcden=0;
- rw=0; //初始化一定要設置為零,表示寫數據
- write_com(0x38);
- write_com(0x0c);
- write_com(0x06);
- write_com(0x01);
- write_com(0x80);
- disp_lcd(0x80,&lcd_hang1[3*16]); //在第一行顯示
- disp_lcd(0xc0,&lcd_hang1[4*16]); //在第二行顯示
- /********************1602液晶函數聲明結束*********************/
- void main()
- uchar i=0;
- DA_S2=0;
- DAdata=0;
- DA_S1=1;
- init_lcd();
- waveform=0;
- TMOD=0x01; //設置定時器為位工作方式
- IT0=1;
- ET0=1;
- EX0=1;
- EA=1;
- while(1) //主循環
- void timer0() interrupt 1
- TH0=THtemp;
- TL0=TLtemp;
- if(waveform==0) sine_out();
- else if(waveform==1) triangle_out();
- else if(waveform==2) square_out();
- void key_int0() interrupt 0
- uchar keytemp;
- uint total_freq; //總頻率
- EA=0; TR0=0; //關總中斷與定時器
- delay(5);
- if(key==0) //確實有按鍵按下而引發中斷
- keytemp=P3&0xf0; //獲取P3口高四位的值
- switch(keytemp)
- case 0xe0: //選擇波形
- waveform++;
- if(waveform>2) waveform=0;
- break;
- case 0xd0: //頻率按規定單位依次增加
- wavefreq[waveform]++; // <---------???
- if(wavefreq[waveform]>10) wavefreq[waveform]=1;
- break;
- case 0xb0: //頻率按規定單位依次衰減
- wavefreq[waveform]--; // <---------????
- if(wavefreq[waveform]<1) wavefreq[waveform]=10;
- break;
- case 0x70:
- DA_S2=1; //使DAC寄存器關閉
- break;
- THtemp=waveTH[waveform*10+(wavefreq[waveform]-1)]; //方括號中選取第幾個數后,并把該值賦給T_temp
- TLtemp=waveTL[waveform*10+(wavefreq[waveform]-1)];
- total_freq= wavefreq[waveform] * freq_unit[waveform]; //求輸出頻率(個數*單位)
- lcd_hang2[5]=total_freq%10+0x30; //在液晶中顯示個位,(0x30 在液晶顯示中表示數字)
- total_freq/=10; lcd_hang2[4]=total_freq%10+0x30; //在液晶中顯示時十位
- total_freq/=10; lcd_hang2[3]=total_freq%10+0x30; //在液晶中顯示時百位
- total_freq/=10; lcd_hang2[2]=total_freq%10+0x30; //在液晶中顯示時千位
- disp_lcd(0x80,&lcd_hang1[waveform*16]); //在第一行顯示
- disp_lcd(0xc0,lcd_hang2); //在第二行顯示
- EA=1; TR0=1; //開啟總中斷與定時器
復制代碼 |
