查看: 2246|回復(fù): 3
關(guān)于NTC溫度二分查表法的單片機(jī)程序問題
ID:602776 發(fā)表于 2021-6-25 10:41 | 顯示全部樓層 |閱讀模式
想問下(AD_temp_data[head]-AD_temp_data[mid])中mid不是賦值給到head,AD_temp_data[head]應(yīng)該等于AD_temp_data[mid]才對啊,想請教一下大神們
*        函 數(shù) 名: AD_Value_To_Temperature
*        功能說明: 折半法查表將AD值轉(zhuǎn)換為溫度值,精確到小數(shù)點(diǎn)后一位
*        形    參:AD采樣值
*        返 回 值: 溫度
const INT16U AD_temp_data[182]=   //-20℃~70℃  0.5一格
    2792, 2784, 2776, 2768, 2761, 2752, 2744, 2736, 2727, 2718,
    2710, 2700, 2691, 2682, 2672, 2663, 2653, 2643, 2632, 2622,
    2612, 2601, 2590, 2579, 2568, 2556, 2545, 2533, 2521, 2509,
    2497, 2484, 2472, 2459, 2446, 2433, 2420, 2407, 2393, 2379,
    2364, 2350, 2336, 2322, 2307, 2293, 2278, 2263, 2248, 2233,
    2218, 2202, 2187, 2171, 2156, 2140, 2124, 2108, 2092, 2076,
    2061, 2044, 2027, 2010, 1993, 1977, 1960, 1943, 1926, 1909,
    1893, 1876, 1859, 1842, 1825, 1807, 1790, 1773, 1756, 1739,
    1722, 1705, 1687, 1670, 1653, 1636, 1619, 1602, 1585, 1568,
    1551, 1534, 1517, 1500, 1484, 1467, 1450, 1434, 1417, 1401,
    1385, 1368, 1352, 1336, 1320, 1304, 1288, 1273, 1257, 1241,
    1226, 1211, 1195, 1180, 1165, 1150, 1135, 1121, 1106, 1092,
    1078, 1064, 1049, 1036, 1022, 1008, 994        , 981 , 968        , 955 ,
    942        , 929 , 916 , 904 , 891        , 879 , 866        , 854 , 842        , 829 ,
    816        , 806 , 796        , 785 , 774        , 763 , 752        , 741 , 731        , 720 ,
    710        , 700 , 689        , 680 , 670        , 660 , 650        , 641 , 632        , 622 ,
    613        , 604 , 596        , 587 , 578        , 570 , 562        , 553 , 545        , 537 ,
    529        , 522 , 514        , 506 , 499        , 492 , 484        , 477 , 470        , 463 ,
    456        , 450
INT16U AD_Value_To_Temperature(INT16U AD_Value)
    INT16U head, mid, tail;
    INT32U Temp=0;
    if((AD_Value<=2364)&&(AD_Value>450))  //正值  0-70
    {//在檢測范圍內(nèi)
        head=40;
        tail=181;
        while(head<tail)
            if((tail-head)!=1)
            {//尚未在兩個(gè)相鄰范圍內(nèi)
                mid=(head+tail)/2;
                if(AD_Value==AD_temp_data[mid])
                {//AD剛好在邊界點(diǎn)上
                    Temp = (mid-40)*10/2;
                    break;
                else if(AD_Value<AD_temp_data[mid])
                    head=mid;
                else if(AD_Value>AD_temp_data[mid])
                    tail=mid;
                if(AD_Value<AD_temp_data[mid])   //倍率為10
                    Temp = (head-40)*10/2;
                    Temp += ((AD_temp_data[head] -AD_Value)*5)/(AD_temp_data[head]-AD_temp_data[mid]);    //????
                    Temp += ((AD_temp_data[mid] -AD_Value)*5)/(AD_temp_data[mid]-AD_temp_data[tail]);
                break;
    else if((AD_Value<=2989)&&(AD_Value>2364))  //負(fù)值
        head=0;
        tail=39;
        while(head<tail)
            if((tail-head)!=1)
                mid=(head+tail)/2;
                {//AD剛好在邊界點(diǎn)上
                    Temp = 200-(5*mid);
                    break;
                else if(AD_Value > AD_temp_data[mid])
                    tail=mid;
                else if(AD_Value < AD_temp_data[mid])
                    head=mid;
                if(AD_Value < AD_temp_data[mid])   //倍率為10   1度的偏移
                    Temp = 200-(5*mid);
                    Temp -= ((AD_temp_data[mid] - AD_Value)*5)/(AD_temp_data[mid] - AD_temp_data[tail]);
                    Temp += 10;
                    Temp = 200-(5*head);
                    Temp -= ((AD_temp_data[head] -AD_Value)*5)/(AD_temp_data[head]-AD_temp_data[mid]);
                    Temp +=10;
                //取補(bǔ)碼加1
                Temp =(~Temp);
                Temp +=1;
                break;
    return (Temp&0xFFFF);
無效樓層,該帖已經(jīng)被刪除
ID:808485 發(fā)表于 2021-6-25 17:50 | 顯示全部樓層
我覺得你說的對
ID:718725 發(fā)表于 2021-6-27 14:33 | 顯示全部樓層
做溫度檢測不錯(cuò)的
ID:602776 發(fā)表于 2021-6-28 15:41 | 顯示全部樓層
這個(gè)程序還是有問題,剛才本人調(diào)試了一下,會(huì)出現(xiàn)AD_temp_data[head]等于AD_temp_data[mid]情況,但是程序沒有跑死
無效樓層,該帖已經(jīng)被刪除
