查看: 3300|回復: 0
單片機步進電機正反轉控制
#include<reg51.h>
sbit S1=P1^4;
sbit S2=P1^5;
sbit S3=P1^7;
unsigned char keyval;
unsigned char ID;
void delay(void)
unsigned char i,j;
for(i=0;i<150;i++)
for(j=0;j<150;j++)
void motor_delay(void)
unsigned int i;
for(i=0;i<2000;i++)
void forward()
P2=0xef;
motor_delay();
P2=0xcf;
motor_delay();
P2=0xdf;
motor_delay();
P2=0x9f;
motor_delay();
P2=0xbf;
motor_delay();
P2=0x3f;
motor_delay();
P2=0x7f;
motor_delay();
P2=0x6f;
motor_delay();
void backward()
P2=0x6f;
motor_delay();
P2=0x7f;
motor_delay();
P2=0x3f;
motor_delay();
P2=0xbf;
motor_delay();
P2=0x9f;
motor_delay();
P2=0xdf;
motor_delay();
P2=0xcf;
motor_delay();
P2=0xef;
motor_delay();
void stop(void)
P2=0xff;
void main(void)
TMOD = 0x01;
EA=1;
ET0=1;
TR0=1;
TH0=(65536-500)/256;
TL0=(65536-500)%256;
keyval=0;
ID=0;
switch(keyval)
case 1:forward();
break;
case 2:backward();
break;
case 3:stop();
break;
void Time0_serve(void) interrupt 1 using 1
TR0=0;
if((P3&0xf0)!=0xf0)
delay();
if((P3&0xf0)!=0xf0)
if(S1==0)
keyval=1;
if(S2==0)
keyval=2;
if(S3==0)
keyval=3;
TH0=(65536-200)/256;
TL0=(65536-200)%256;
TR0=1;
參與人數 1黑幣 +20 收起 理由
admin + 20 共享資料的黑幣獎勵!
收藏收藏1 分享淘帖 頂1 踩
