- #include<reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- extern int KeyDown();
- extern void LcdInit();
- extern void Lcd1602_Delay1ms(uint c);
- extern void LcdWriteCom(uchar com);
- extern void LCD_Write_String(uchar x,uchar y,uchar *s);
- extern void LCD_Write_Char(uchar x,uchar y,uchar Data);
- uchar code password[]={1,2,3,4,1,1};
- sbit led=P3^0;
- main()
- uchar num,i,j;
- uchar passwordtemp[6];
- uchar passwordlength,PLEN;
- bit flag;
- PLEN=sizeof(password)/sizeof(password[0]);
- PLEN=6;
- LcdInit() ;
- Lcd1602_Delay1ms(100);
- LcdWriteCom(0x01);
- LCD_Write_String(0,0," Welcome! ");
- LCD_Write_String(0,1,"Input password!");
- while(1)
- num=KeyDown();
- if(num!=0xff)
- if(i==0)
- LCD_Write_String(0,0," ");
- if(i<9)
- passwordtemp[i]=num;
- LCD_Write_Char(i,1,i);
- i++;
- if(i==6)
- passwordlength=i-1;
- i=0;
- if(passwordlength==PLEN)
- flag=1;
- for(j=0;j<PLEN;j++)
- flag=flag&&(passwordtemp[j]==password[j]);
- if(flag)
- LCD_Write_String(0,1," ");
- LCD_Write_String(0,1,"Right Open!>>>>");
- flag=0;
- else
- LCD_Write_String(0,1,"Wrong! Retry!");
- while(1);
- #include"reg52.h"
- #define LCD1602_DATAPINS P0
- uchar x;
- sbit LCD1602_RW=P2^5;
- sbit LCD1602_RS=P2^6;
- sbit LCD1602_E=P2^7;
- void Lcd1602_Delay1ms(uint c);
- void LcdWriteCom(uchar com);
- void LcdWriteData(uchar dat) ;
- void LcdInit();
- void LCD_Write_String(uchar x,uchar y,uchar *s);
- void LCD_Write_Char(uchar x,uchar y,uchar Data);
- uchar a,b;
- for (; c>0; c--)
- for (b=199;b>0;b--)
- for(a=1;a>0;a--);
- LCD1602_E = 0;
- LCD1602_RS = 0;
- LCD1602_RW = 0;
- LCD1602_DATAPINS = com;
- Lcd1602_Delay1ms(1);
- LCD1602_E = 1;
- Lcd1602_Delay1ms(5);
- LCD1602_E = 0;
- LCD1602_E = 0;
- LCD1602_RS = 1;
- LCD1602_RW = 0;
- LCD1602_DATAPINS = dat;
- LCD1602_E = 1;
- LCD1602_E = 0;
- void LcdInit()
- LcdWriteCom(0x38);
- LcdWriteCom(0x0c);
- LcdWriteCom(0x06);
- while (*s)
- LCD_Write_Char(x,y,*s);
- s ++; x++;
- if (y == 0)
- LcdWriteCom(0x80 + x);
- else
- LcdWriteCom(0xC0 + x);
- LcdWriteData( Data);
- #include<reg52.h>
- typedef unsigned int uint;
- typedef unsigned char uchar;
- #define GPIO_KEY P1
- uchar KeyValue;
- uchar KeyState;
- uchar Disp[]="0,1,2,3,4,5,6,7,8,9,[,]";
- void Delay10ms();
- int KeyDown();
- int KeyDown()
- char a;
- GPIO_KEY=0x0f;
- if(GPIO_KEY!=0x0f)
- Delay10ms();
- KeyState=1;
- GPIO_KEY=0X0F;
- Delay10ms();
- switch(GPIO_KEY)
- case(0x07):KeyValue=0;break;
- case(0X0b):KeyValue=1;break;
- case(0X0d):KeyValue=2;break;
- case(0X0e):KeyValue=3;break;
- GPIO_KEY=0XF0;
- Delay10ms();
- switch(GPIO_KEY)
- case(0X70): KeyValue=KeyValue;break;
- case(0Xb0): KeyValue=KeyValue+4;break;
- case(0Xd0): KeyValue=KeyValue+8;break;
- case(0Xe0): KeyValue=KeyValue+12;break;
- while((a<50)&&(GPIO_KEY!=0xf0))
- Delay10ms();
- a++;
- KeyValue= Disp[KeyValue];
- return KeyValue;
- void Delay10ms(void)
- uchar a,b,c;
- for(c=1;c>0;c--)
- for(b=38;b>0;b--)
- for(a=130;a>0;a--);
復(fù)制代碼 |
