本程序擁有暫停,復(fù)位和自己設(shè)置時(shí)間的功能- #include "reg52.h"
- typedef unsigned int u16;
- typedef unsigned char u8;
- sbit LSA=P2^2;
- sbit LSB=P2^3;
- sbit LSC=P2^4;
- sbit k1=P3^0;
- sbit k2=P3^1;
- sbit k3=P3^2;
- sbit k4=P3^3;
- sbit k5=P3^4;
- sbit k6=P3^5;
- sbit k7=P3^6;
- sbit k8=P3^7;
- u8 code smgduan[17]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
- 0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
- u8 ssec,sec,min,hour;
- u8 DisplayData[8];
- void delay(u16 i)
- while(i--);
- void Timer0Init()
- TMOD=0X01;
- TH0=0Xd8;
- TL0=0Xf0;
- TR0=1;
- void DigDisplay()
- u8 i;
- for(i=0;i<8;i++)
- switch(i)
- case(0):
- LSA=1;LSB=1;LSC=1; break;
- case(1):
- LSA=0;LSB=1;LSC=1; break;
- case(2):
- LSA=1;LSB=0;LSC=1; break;
- case(3):
- LSA=0;LSB=0;LSC=1; break;
- case(4):
- LSA=1;LSB=1;LSC=0; break;
- case(5):
- LSA=0;LSB=1;LSC=0; break;
- case(6):
- LSA=1;LSB=0;LSC=0; break;
- case(7):
- LSA=0;LSB=0;LSC=0; break;
- P1=DisplayData[i];
- delay(100);
- P1=0x00;
- void datapros()
- DisplayData[0]=smgduan[hour/10];
- DisplayData[1]=smgduan[hour%10];
- DisplayData[2]=0x40;
- DisplayData[3]=smgduan[min/10];
- DisplayData[4]=smgduan[min%10];
- DisplayData[5]=0x40;
- DisplayData[6]=smgduan[sec/10];
- DisplayData[7]=smgduan[sec%10];
- void keypros1()
- if(k1==0)
- delay(1000);
- if(k1==0)
- TR0=~TR0;
- while(!k1);
- void keypros2()
- if(k2==0)
- delay(1000);
- if(k2==0)
- ssec=0;sec=0;min=0;hour=0;
- while(!k2);
- void keypros3()
- if(k3==0)
- delay(1000);
- if(k3==0)
- sec=sec+1;
- while(!k3);
- void keypros4()
- if(k4==0)
- delay(1000);
- if(k4==0)
- sec=sec-1;;
- while(!k4);
- void keypros5()
- if(k5==0)
- delay(1000);
- if(k5==0)
- min=min+1;;
- while(!k5);
- void keypros6()
- if(k6==0)
- delay(1000);
- if(k6==0)
- min=min-1;;
- while(!k6);
- void keypros7()
- if(k7==0)
- delay(1000);
- if(k7==0)
- hour=hour+1;;
- while(!k7);
- void keypros8()
- if(k8==0)
- delay(1000);
- if(k8==0)
- hour=hour-1;;
- while(!k8);
- void main()
- Timer0Init();
- while(1)
- keypros1();
- keypros2();
- keypros3();
- keypros4();
- keypros5();
- keypros6();
- keypros7();
- keypros8();
- if(TF0==1)
- TF0=0;
- TH0=0Xd8;
- TL0=0Xf0;
- ssec++;
- if(ssec>=100)
- ssec=0;
- sec++;
- if(sec>=60)
- sec=0;
- min++;
- if(min>=60)
- min=0;
- hour++;
- if(hour>=24)
- {hour=0;}
- datapros();
- DigDisplay();
