查看: 2129|回復: 6
'Keydown': missing function-prototype
ID:888357 發表于 2021-6-21 22:16 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
extern        unsigned char KeyDown();
extern void Lcd1602_Delay1ms(uint c);
extern void LcdInit();
extern void LcdWriteCom(uchar com);
extern void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s);
extern void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data);
uchar code password[]={1,2,3,4,1,1};
sbit led=P3^0;
main()
  uchar num,i=0,j;
        uchar passwordtemp[6];
        uchar passwordlength,PLEN;
  bit flag;
  PLEN=sizeof(password)/sizeof(password[0]);
  PLEN=9;
        LcdInit()        ;
        Lcd1602_Delay1ms(10);
        LcdWriteCom(0x01);
        LCD_Write_String(0,0,"  Welcome! ");
  LCD_Write_String(0,1,"Input password!");
                        num=Keydown();
                        if(num!=0xff)
                                if(i==0)
                                LCD_Write_String(0,0,"                ");
                                if(i<16)
                                        passwordtemp[ i]=num;
                                        LCD_Write_Char(i,1,'*');
                                i++;
                                if(i==8)
                                                passwordlength=i-1;
                                                i=0;
                                        if(passwordlength==PLEN)
                                                flag=1;
                                                for(j=0;j<PLEN;j++)
                                                flag=flag&&(passwordtemp[j]==password[j]);
                                        if(flag)
                                                LCD_Write_String(0,1,"                       ");
                                                LCD_Write_String(0,1,"Right Open!>>>>");
                                                led=0;
                                                Lcd1602_Delay1ms(30000);
                                                led=1;
                                                flag=0;
                                                LCD_Write_String(0,1,"Wrong! Retry!");
#include<reg52.h>
typedef unsigned int uint;
typedef unsigned char uchar;
#define GPIO_KEY P1
uchar KeyValue;
uchar KeyState;
void Delay10ms();
   char a;
   GPIO_KEY=0x0f;
   if(GPIO_KEY!=0x0f)
      Delay10ms();
      if(GPIO_KEY!=0x0f)
       KeyState=1;
       GPIO_KEY=0X0F;
       Delay10ms();
     switch(GPIO_KEY)
      case(0x07):KeyValue=0;break;
      case(0X0b):KeyValue=1;break;
      case(0X0d):KeyValue=2;break;
            case(0X0e):KeyValue=3;break;
GPIO_KEY=0XF0;
                        Delay10ms();
                        switch(GPIO_KEY)
                                case(0X70):        KeyValue=KeyValue;break;
                                case(0Xb0):        KeyValue=KeyValue+4;break;
                                case(0Xd0): KeyValue=KeyValue+8;break;
                                case(0Xe0):        KeyValue=KeyValue+12;break;
while((a<50)&&(GPIO_KEY!=0xf0))
       Delay10ms();
                                a++;
a=0;
return KeyValue;
void Delay10ms(void)
    unsigned char a,b,c;
    for(c=1;c>0;c--)
        for(b=38;b>0;b--)
            for(a=130;a>0;a--);
#include"reg52.h"
#define LCD1602_DATAPINS P0
uchar x;
sbit LCD1602_RW=P2^5;
sbit LCD1602_RS=P2^6;
sbit LCD1602_E=P2^7;
void LcdWriteData(uchar dat)        ;
void LcdInit();
    uchar a,b;
        for (; c>0; c--)
                 for (b=199;b>0;b--)
                          for(a=1;a>0;a--);
        LCD1602_E = 0;
        LCD1602_RS = 0;
        LCD1602_RW = 0;
        LCD1602_DATAPINS = com;
        Lcd1602_Delay1ms(1);
        LCD1602_E = 1;
        Lcd1602_Delay1ms(5);
        LCD1602_E = 0;
        LCD1602_E = 0;
        LCD1602_RS = 1;
        LCD1602_RW = 0;
        LCD1602_DATAPINS = dat;
        LCD1602_E = 1;
        LCD1602_E = 0;
void LcdInit()
         LcdWriteCom(0x38);
        LcdWriteCom(0x0c);
        LcdWriteCom(0x06);
        LcdWriteCom(0x01);
         while (*s)
                 LCD_Write_Char(x,y,*s);
                 s ++;  x++;
        if (y == 0)
         LcdWriteCom(0x80 + x);
                 LcdWriteCom(0xC0 + x);
         LcdWriteData( Data);
main.c(32): warning C206: 'Keydown': missing function-prototype
ID:888357 發表于 2021-6-21 22:18 | 只看該作者
   char a;
   GPIO_KEY=0x0f;
   if(GPIO_KEY!=0x0f)
      Delay10ms();
      if(GPIO_KEY!=0x0f)
       KeyState=1;
       GPIO_KEY=0X0F;
       Delay10ms();
     switch(GPIO_KEY)
GPIO_KEY=0XF0;
                        Delay10ms();
                        switch(GPIO_KEY)
       Delay10ms();
                                a++;
a=0;
return KeyValue;
ID:155507 發表于 2021-6-22 10:55 | 只看該作者
你這個程序不完整,沒法給你看是哪里出問題了!
ID:942477 發表于 2021-6-22 15:01 | 只看該作者
是不是有沒顯示出來的字符
ID:888357 發表于 2021-6-22 20:05 | 只看該作者
我是小白怎么滴 發表于 2021-6-22 15:01
是不是有沒顯示出來的字符
沒有都顯示出來了
ID:888357 發表于 2021-6-22 20:08 | 只看該作者
本帖最后由 hdfc 于 2021-6-22 20:32 編輯
不明白我明明引用keydown了還出現警告
ID:888357 發表于 2021-6-22 20:09 | 只看該作者
本帖最后由 hdfc 于 2021-6-22 20:35 編輯
他還是警告缺少函數原型
ID:888357 發表于 2021-6-22 20:11 | 只看該作者
angmall 發表于 2021-6-22 10:55
我發生于的程序了在回復里
ID:888357 發表于 2021-6-22 22:08 | 只看該作者
解決了,大小寫錯了
