查看: 2291|回復(fù): 6
幫我看看單片機(jī)定時(shí)器程序,設(shè)置定時(shí)一秒,實(shí)際測出來比一秒快太多了
ID:787039 發(fā)表于 2021-6-19 19:32 | 顯示全部樓層 |閱讀模式
#include <STC12C5A60S2.h>
#include <intrins.h>
typedef unsigned char u8;
typedef unsigned int u16;
//stc15w408as共陽數(shù)碼管代碼
u16  mun, key=0,key_;//變量聲明
u8 code tab[16][10]=
{{1,1,0,0,0,0,0,0},
{1,1,1,1,1,0,0,1},
{1,0,1,0,0,1,0,0},
{1,0,1,1,0,0,0,0},
{1,0,0,1,1,0,0,1},
{1,0,0,1,0,0,1,0},
{1,0,0,0,0,0,1,0},
{1,1,1,1,1,0,0,0},
{1,0,0,0,0,0,0,0},
{1,0,0,1,0,0,0,0},
{1,0,0,0,1,0,0,0},//a
{1,0,0,0,0,0,1,1},//b
{1,1,0,0,0,1,1,0},//c
{1,0,1,0,0,0,0,1},//d
{1,0,0,0,0,1,1,0},//e
{1,0,0,0,1,1,1,0}};//f
sbit A_=P1^0;//斷碼
sbit B_=P1^1;
sbit C_=P1^2;
sbit D_=P1^3;
sbit E_=P1^4;
sbit F_=P1^5;
sbit G_=P1^6;
sbit H_=P3^7;
sbit GeWei=P2^6;
sbit ShiWei=P2^7;
void Delay10ms();
unsigned char Desplay(unsigned char mun,com);
void Delay1ms()        ;
void Time();
        {Time();//定時(shí)器初始化
                        if(key==60)
                        key=0;
           Desplay( key%10,1);
                   Desplay((key/10)%10,2);
void Time()
        AUXR &= 0x7F;                //定時(shí)器時(shí)鐘12T模式
        TMOD &= 0xF0;                //設(shè)置定時(shí)器模式
        TMOD |= 0x01;                //設(shè)置定時(shí)器模式
        TL0 = 0x00;                //設(shè)置定時(shí)初值
        TH0 = 0xB8;                //設(shè)置定時(shí)初值
        TF0 = 0;                //清除TF0標(biāo)志
        TR0 = 1;                //定時(shí)器0開始計(jì)時(shí)
        ET0=1;
        EA=1;
        {u8 i;
        for(i=0;i<8;i++)
                        switch(i)
                                        case 0:A_=tab[mun][7];break;
                                        case 1:B_=tab[mun][6];break;
                                        case 2:C_=tab[mun][5];break;
                                        case 3:D_=tab[mun][4];break;
                                        case 4:E_=tab[mun][3];break;
                                        case 5:F_=tab[mun][2];break;
                                        case 6:G_=tab[mun][1];break;
                                        case 7:H_=tab[mun][0];break;
                 switch(com)
                                        case 1:GeWei=1;ShiWei=0;break;
                                        case 2:GeWei=0;ShiWei=1;break;
                                        Delay1ms();
                                         A_=1;B_=1;C_=1;D_=1;E_=1;F_=1;G_=1;H_=1;
                                        GeWei=0;
                                        ShiWei=0;
void titn_time_ () interrupt 1
                        ++mun;
                        if(mun==50)
                        { mun=0;
                        key++;}
void Delay1ms()                //@11.0592MHz
        unsigned char i, j;
        _nop_();
        i = 11;
        j = 190;
        do
                while (--j);
        } while (--i);
ID:96682 發(fā)表于 2021-6-19 23:34 來自觸屏版 | 顯示全部樓層
隨意更改型號頻率肯定效果不佳
ID:939710 發(fā)表于 2021-6-20 11:45 | 顯示全部樓層
確定你的系統(tǒng)時(shí)鐘和你定時(shí)器+1和系統(tǒng)時(shí)鐘的關(guān)系,再用計(jì)算公式計(jì)算
ID:748788 發(fā)表于 2021-6-20 17:02 | 顯示全部樓層
408as的主頻是多少?12m或11.0592m應(yīng)該設(shè)置不同的定時(shí)器初值
ID:123289 發(fā)表于 2021-6-21 11:04 | 顯示全部樓層
計(jì)算時(shí)間是最最基本的能力,仔細(xì)算算,都會(huì)比較準(zhǔn)的。
ID:451718 發(fā)表于 2021-6-21 11:17 | 顯示全部樓層
你這個(gè)main函數(shù)里面, 沒有看到定時(shí)器的初始化操作哦
ID:941432 發(fā)表于 2021-6-21 11:22 | 顯示全部樓層
芯片的頻率不是12.0的,大概為11.多的
