查看: 1575|回復: 2
脈沖這個怎么調試.是在哪里啊
ID:939264 發表于 2021-6-17 14:45 | 顯示全部樓層 |閱讀模式
#include        <reg51.h>
#define  uint unsigned int
sbit        RESET                =        P3^7;
int                Price                =        70,        Mileage                =        0;
uchar        count                =        0;
uchar code tab_d[10]                =        {0x3F,        0X06,        0X5B,        0X4F,        0X66,        0X6D,        0X7D,        0X07,        0X7F,        0X6F};
uchar code tab_wei[8]                ={0x7f,        0xbf,        0xdf,        0xef,        0xf7,        0xfb,        0xfd,        0xfe};
//????ms
void        delay(uint t)
        uchar                i                =        0;
        while(t--)
                for        (i;        i<120;        i++);
   d : ???????
         x : ????????(0x80 ?? 0??
   w :?????
void        disp(uchar d,        uchar x,        uchar w)
        P2                =        0XFF;
        P2                =        tab_wei[w];
        P0                =        0;
        P0                =        tab_d[d]        | x;
        delay        (100);
void        refresh()
        disp(Mileage%10,        0,        0);//??
        disp(Mileage/10%10,        0x80,        1);
        if        (Mileage >= 100)
                        disp(Mileage/100%10,        0,        2);
        if        (Mileage >= 1000)
                        disp(Mileage/1000%10,        0,        3);
        disp(Price%10,        0,        4);
        disp(Price/10%10,        0x80,        5);
        if        (Price        >= 100)
                disp(Price/100%10,        0,        6);
        if        (Price        >=        1000)
                disp(Price/1000%10,        0,        7);
void timer1        ()        interrupt 1
        count++;
        Mileage +=        1;
        if(        count        ==        5)
                count        =        0;
                if        (Mileage        >        30)
                                Price +=10;
void init()
        P0                        =        0;
        P2                        =        0XFF;
        TMOD                =        0X0E;   //???????
        IT0                        =        1;                  //????
        TH0                        =        255;                //1?????
        TL0                        =        255;
        TR0                        =        1;
        IE                        =        0X82;
void        judgeReset()
        if(RESET        ==        0)
                Price                =        70;
                Mileage        =        0;
void        main()
                init        ();                //?????
                while        (1)
                        judgeReset        ();
                        refresh                        ();
ID:328014 發表于 2021-6-17 14:57 | 顯示全部樓層
你是不是要調整定時器的時間,你改這里即可 void timer1        ()        interrupt 1
ID:939264 發表于 2021-6-17 15:05 | 顯示全部樓層
51hei團團 發表于 2021-6-17 14:57
就是脈沖一次為一公里怎么改
